Toytec top plate spacer 3/4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by titian36, Feb 23, 2016.
  1. Feb 23, 2016 at 2:08 PM
    titian36
    titian36 [OP] Well-Known Member
    Looking to level out the front with the toytec top plate spacer with stock coils which gives a small lift at 3/4inch. If anyone has experience with them does it lift it 3/4 or more like 1inch? I was looking at the 5100 but I will change out my stock shocks when they have a lot more miles on them and probably go to adjustable coilovers down the road.
    Roddy13 likes this.
  2. Feb 23, 2016 at 3:19 PM
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
    Roddy13 likes this.
  3. Feb 23, 2016 at 3:20 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Whatever thickness the spacer is, you get approx. twice that in lift.
  4. Feb 23, 2016 at 3:26 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    I have the toytec spacers on my truck
  5. Feb 23, 2016 at 5:06 PM
    titian36
    Awesome! Love that color! Did you measure before putting on the spacer and after? If so did you get 3/4inch of lift or more?
  6. Feb 24, 2016 at 3:51 AM
    Aussiek2000
    2016 Offroad AC
    I measured after i did the work and it was right at 3/4". not sure if it ended up settling or not. but doesn't appear to have
  7. Feb 24, 2016 at 4:14 AM
    Oey12
    Oey12 Well-Known Member
    Joe
    New York
    SOLD:2012 TRD Sport 2017 SR5 4Runner
    Toytec 1/2 spacers, A.R.E Z, Firestone airbags
    I have the 1/4 Toytec spacers on both sides in my 2nd generation dcsb with stock coils and it gave me exactly a 1/2 inch of lift.
    gargamel05 likes this.
  8. Feb 24, 2016 at 4:15 AM
    Aussiek2000
    2016 Offroad AC
    the spacers for 3/4" lift are only about 3/8-1/2" thick
  9. Feb 24, 2016 at 4:38 AM
    Oey12
    Joe
    New York
    I don't know what the exact thickness but Toytec refers to them as 1/4 inch spacer. I know my spacers don't provide 3/4 inch of lift. I was just trying to let the OP know that the Toytec spacer has been accurate for their lift amount for a very similar product.
    Aussiek2000[QUOTED] likes this.
  10. Feb 24, 2016 at 1:02 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    I got a question.. why do you all want to go thru all the same amount of work to put spacers on when you could just do a lift kit with struts and springs?? I'm asking genuinely not trying to be a dick.
    I know the lift kits are a lot more $$ than spacers but all that labor it would make more sense to just upgrade the suspension, am I wrong??
    Sig Taco and kgilly like this.
  11. Feb 24, 2016 at 1:15 PM
    titian36
    For me I just want to level the front 3/4 to 1inch. I don't want to change out my front stock shocks yet since there still only 3000 miles on it. I will change them out when needed. If I wanted to do a 2 to 3inch lift then I would replace the shocks and struts.
    Oey12, jeffmansion and Wheelie like this.
  12. Feb 24, 2016 at 1:45 PM
    Aussiek2000
    2016 Offroad AC
    For me it came down to 3 reasons
    1. I'm a dealer tech so labor was free. I have the tools and space to do the work
    2. Bilstein 4600 and 5100's are valved the same. So why take off the bilsteins that i already paid extra for on my TRDOR.
    3. I eventually have plans for 2.5-3" lift and didn't want to spend a ton on parts that will be coming back off
  13. Feb 24, 2016 at 2:15 PM
    xTacoma16x
    TRD sport 2016
    It's a lot more work to disassemble strut compared to just adding top spacer.
    MountainManGuy likes this.
  14. Feb 24, 2016 at 2:39 PM
    Aussiek2000
    2016 Offroad AC
    It's the same amount of work. Have to disassemble the strut to change the studs in the top
    CaptainBart45 likes this.
  15. Feb 24, 2016 at 2:47 PM
    xTacoma16x
    TRD sport 2016
    No need to change studs if your spacer is 1/2 or less with new top nuts
  16. Feb 24, 2016 at 2:51 PM
    Aussiek2000
    2016 Offroad AC
    Studs don't even stick through the frame with the toytec 3/4 spacers
  17. Feb 24, 2016 at 2:55 PM
    xTacoma16x
    TRD sport 2016
    Interesting, mine was ok! I only had to replace studs after adding 1/4 taco lean spacer
    Like I said if you have new nuts stock studs will still work. Stock nuts have spacer under each nut, if that makes sense
  18. Feb 24, 2016 at 2:58 PM
    Aussiek2000
    2016 Offroad AC
    The studs in mine were only 3/4" or so long. The toytec ones were like 2"
  19. Feb 24, 2016 at 3:07 PM
    xTacoma16x
    TRD sport 2016
    I'll measure mine when I get home
  20. Feb 24, 2016 at 3:14 PM
    Aussiek2000
    2016 Offroad AC
    Maybe there is a difference between the Hitschi and bilstein shocks
