Toytec TSB AAL question
Discussion in 'Suspension' started by bigmooze, Oct 26, 2010.
  1. Oct 26, 2010 at 3:44 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Need some help with a strange question:
    I want to remove the Toytec TSB AAL I have. Only thing is, I don't have the "stock" centering bolts.
    When I remove the extra leaf, I plan to re-use the centering bolts that came with the Toytec AAL. Is there enough thread toward the bottom of the pin to allow me to use it, given that about 3/8" of steel will have been removed?
    I can't remember whether the centering bolts are threaded all the way up their length.
  2. Oct 26, 2010 at 3:49 PM
    P-Hill Tacoma
    P-Hill Tacoma Well-Known Member
    Missouri
    2010 DC Short Bed 4WD Off Road Barcelona Red
    Fr Bilsteins@1.75", Rr Bilsteins w/ 1.5" AAL & RideRite Airbags, Truxedo Lo-Pro Tonneau, Step Tubes, 1.25" Spidertrax
    Yes. I recently did the same thing.
  3. Oct 26, 2010 at 3:52 PM
    bigmooze
    Richard
    Belle River, ON
    Thanks for the quick response.
  4. Oct 26, 2010 at 5:12 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    Not to thread jack but why are you removing it? Unhappy or don't want the lift?
  5. Oct 26, 2010 at 5:34 PM
    bigmooze
    Richard
    Belle River, ON
    No problem... I removed the front lift (was set at 0.85" with eibach coils) due to front end growling. Now I don't like how high the back is. Figured I would revert to stock for a while and install air bags for extra support when towing/hauling my ATV.
    Not to mention, I'm not a big fan of the vibe I have at take off due to the lifted rear end. I know a carrier bearing drop and/or shims are a possibility, but I have a little too much rake.
  6. Oct 26, 2010 at 5:37 PM
    Jason'sLawnCare
    Thanks! I asked because I'm going to install some this weekend.:)
  7. Oct 26, 2010 at 6:02 PM
    bigmooze
    Richard
    Belle River, ON
    Good luck! It's fairly easy to do, especially with a second person.
  8. Oct 27, 2010 at 12:29 PM
    P-Hill Tacoma
    Missouri
    Late response. I removed mine for the same reason. The 1.5" was closer to 1.75" and the vibe at take off was worrying me. I bought the firestone air bags so I could adjust and gave me about 1" lift which is closer to what I wanted. And the ride is better.
  9. Oct 27, 2010 at 2:11 PM
    bigmooze
    Richard
    Belle River, ON
    That's what I had in mind. I'd like to run stock height now to avoid any vibes etc. I have seen that the minimum air bag pressure is 5 PSI for the ride rite bags - do you know what lift, if any, they provide at this minimum pressure?
  10. Oct 27, 2010 at 6:39 PM
    P-Hill Tacoma
    Missouri
    Haven't actually measured it. Looked good with about 10 psi. My bilseins are at 1.75.
  11. Oct 28, 2010 at 1:49 AM
    bigmooze
    Richard
    Belle River, ON
    OK thanks.
