Toytec ultimate lift installed.
Discussion in 'Suspension' started by goride, Nov 15, 2009.
  1. Nov 16, 2009 at 10:54 AM
    goride
    goride [OP] Well-Known Member
    Josh
    UTAH
    22 4dr lb white off-road
    Tint, sliders, puddle pods, on my way to more….
    No spacers, my tires do rub on a full turn on the uca's and inner frame.I plan on getting some new wheels here in the near future to correct the problem.Also Thanks to all for the positive feedback.
  2. Nov 16, 2009 at 11:16 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Looks great!....job well done and the installation was free!
  3. Nov 16, 2009 at 12:17 PM
    eschors
    eschors Member
    e
    Denver
    07 tacoma 4door trd-offroad
    Smokin!
    I am contemplating the same set up for my tacoma, ToyTec UL w lr UCAs... Tech guy from the shop told me w the UCAs i should be able to get 285/75/16s on the stock wheel without rubbing... what size tires are you running?
    Do you have any idea how much extra roof clearance your truck needs after-lift? I have about 4.5/5" clearance in my garage now w stock truck, i need to figure out if the truck will still clear with lift and bigger tires before i pull the trigger..
  4. Nov 16, 2009 at 12:18 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Very nice! Looks great!
  5. Nov 16, 2009 at 1:32 PM
    gouge44
    gouge44 $DO WORK$
    FloRiDa
    08 prerunner TRDsport DoubleCab
    Tinted windows, toytec ultimate 3inch lift- front c/o rear aal, 18" black rockstar rims, 275/70/18 toyo opencountry mt's, BLUE dome light, 6000k H4 HID bixenon, kenwood kvt-514 headunit,black badges, satoshi grill :] sold it and now have a wrangler....
    umm it could be close... depending on the tires u get
  6. Nov 17, 2009 at 11:46 AM
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    The lift looks good. I just ordered the same lift so i'll be installing mine soon. Do you have it cranked to the full 3"?
  7. Nov 17, 2009 at 11:51 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Looks bueno!
  8. Nov 17, 2009 at 1:47 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    Looks Awesome Bro, saving up for mine, OME thou!!:D
  9. Nov 17, 2009 at 2:02 PM
    goride
    Josh
    UTAH
    I'm running 285/70/17 and I rub on a full turn, it would be close on the clearance in your garage.
  10. Nov 17, 2009 at 2:11 PM
    goride
    Josh
    UTAH
    Yea it comes from toy tec set to 3" i beleve, I do have to do some adjusting ,because i have the tacoma slight driver side lean.
  11. Nov 17, 2009 at 2:43 PM
    757southpaw
    757southpaw Well-Known Member
    Jay
    757
    07' DC LB TRD Sport 4x4
    BAK BakFlip Tonneau cover, 30% front tinted windows, AVS vent shades, Black Billet Grill,Pop& Lock, secondary air filter removed, Goodyear Duratrac's, Billies @ 2.5" on front, Billies on back w/ 1.5" AAL, Toytec Diff drop, NOKYA Hyper Yellow fog light bulbs, LaminX Weathertechs, Rear diff breather mod, BHLM
    I vision mine looking very similar. Looks good bro!
  12. Nov 17, 2009 at 2:57 PM
    baldy77
    Albuquerque, NM
    Once you've got it adjusted, let me know what your settings were. I'll be receiving mine unassembled so i'll have an idea where to begin.
  13. Nov 17, 2009 at 4:00 PM
    goride
    Josh
    UTAH
    With the adjustments you just raise the drivers side slightly or lower the passenger side slightly to even the lean out, but the coil overs come preloaded at 3" so I dont beleve the adjusting will change this much, I could be wrong,I just dont know.
  14. Nov 19, 2009 at 8:59 AM
    eschors
    eschors Member
    e
    Denver
    Did you put the 17" rims on with the lift? Do you happen to know the offset?
