ToyTec ultimate lift kit installed today
Discussion in 'Suspension' started by uncleART, Jun 2, 2013.
  1. Jun 2, 2013 at 11:32 PM
    uncleART
    uncleART [OP] Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    DeBadged, Toyota Bedmat, TRD exhaust, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, Bora wheel spacers, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, {REMOVED-Goodyear Duratrac 285/70-17 LR-D & REMOVED-Procomp 7089 wheels}, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, Back-Up light mod, ECGS bushing, Redline Hood Struts, Leer 100XR, BFG TA KA2 265/70-17 LR-C, FJ Steel wheels
    I installed my ToyTec ULK, LR UCAs, and Dakars today. I pulled the truck into the driveway at noon (got home @ 5am from my night shift). And it took me about 9 hours to do it, not including a run to the store to pick up a 32mm socket for the new ball joints & a meal break. It was all very easy, just a lot to do.
    For the LR UCAs, I just cut the old bolts and put new ones in ($12 ea). Removing them this way was incredibly easy (cutting wheel), I had each bolt out in about a minute with no effort. I highly recommend this method.
    I still need to adjust the bilsteins another inch to get my full 3" of lift. It looks like I got a 2 1/2" lift from the Dakars.
    My kit came with 3* axle shims, but they were wrong. The hole was too small for the center pins & the pins were too short anyway. So I skipped them.
    This just not gonna work! *** EDIT*** What I should have done was clamp and remove the center pin. Then reinstall it through the shim.
    Dakar next to the stock Sport spring
    I took a test drive at various speeds and didn't notice any driveline vibes - I don't think. (I might have a tiny one around 38mph, but I'm not sure - time will tell).
  2. Jun 3, 2013 at 2:34 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
  3. Jun 3, 2013 at 2:51 PM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    good job on the install. truck looks pretty awesome man. get you some biggger rubber on there and it will be done!
  4. Jun 3, 2013 at 3:45 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Was the threaded part of the center pin too large to fit?
  5. Jun 3, 2013 at 8:01 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    No. It would have worked. Fail on my part. I didn't know I needed to clamp the springs and remove the center pin then reinstall through the shim. The problem that I have now is if I decide to put the shim in, the center pin will be too short. I cut off the long threads so my stock bump stop would fit. Haha. So should i need to install, I'll need to buy new pins. Not a big deal - they're only about $7.
  6. Jun 3, 2013 at 8:04 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thank you.
    I had fun. It was a lot of work. Motorsport Technology is swamped and my Bora wheel spacers are about another week out. Then I can get my 285s!
  7. Jun 3, 2013 at 8:11 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    The alignment went really well. The tech was very accommodating with my info & instructions on the LR UCAs. I set them at -1 and rolled the LCAs forward. I got 2* of caster and 3" of clearance behind the tires.
    Here's a final pic as it is now.
  8. Jun 3, 2013 at 9:36 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Lift results:
    Front
    coil-overs adjusted for 3" lift
    Hub center - wheel well 23"
    Rear
    Dakar leafs gave about 2 1/2" lift
    Hub center - wheel well 24 1/2"
    Frame clearance measured on alignment rack @ cab & bed mounts
    Front: 17"
    Rear: 17 1/2"
    This gives me 1/2" of rake based on the truck frame.
    It seems a lot of people level their trucks based on wheel well measurements only. When I was taking my baseline measurements, I found that if I made my hub to well dimensions the same (front to back), I would have 1" of reverse rake (I have a dclb). I also noticed this in a lot of pictures here on TW, of "level" trucks - the front end looked a little high. I know some really like the front end higher, but I don't. I don't care for the bro-lean look. This is part of the reason that I chose the ToyTec setup - it gave me full convenient control over my front height (it's my picky nature).
    So anyway, I'm happy. I got it where I wanted it!
  9. Jun 3, 2013 at 10:13 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    Lookin' good!
  10. Jun 3, 2013 at 10:16 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thank you! I can't wait to put my new tires on.
  11. Jun 3, 2013 at 10:38 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3
    Looking good man. I have a question about how you cut the bolt for the UCA. I read many post about how others have done this but I was wondering if you loosen it all the way out then cut it? I know stupid question lol. Then how do you put the new one in? Same way the old on came out? Or from the back? I like how you measure from the frame. Sometime when I look at my truck, it looks like I have a bro lean.
  12. Jun 3, 2013 at 11:08 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thanks. For the UCAS bolt, I considered bending my wheel well like most people do. But my bolt heads were mostly inside the wells! A lot of bending. So I just got new ones. They were cheap.
    I removed the nut completely. Slid the bolt up as far as it would go ( about an inch). Then I used my small grinder with a cutting wheel. I made sure to have a good grip on it so as to have total control. I only wanted to cut the bolt! Haha Then I used a file to knock off the burr and slid them back out of the UCAs.
    Now on the drivers side, I had to remove two small bolts retaining the brake lines at the top rear of the well. Then I pushed half of them towards the engine. As I was pulling the bolt out I also moved the forward leg of the uca towards the engine, helping the removal angle if the bolt. This was all very easy.
    The passenger side was even easier. I just had to put slight pressure towards the engine on a coil of brake tube with my thumb. Bolt slid right out.
    Then the new ones went in from the back, like how the old ones came out. It was all super fast & easy.
  13. Jun 20, 2013 at 5:42 PM
    SSG665
    SSG665 Well-Known Member
    Georgia
    03 Tacoma Limited Prerunner
    Tires installed yet?
  14. Jun 20, 2013 at 6:06 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Yepp!
    ImageUploadedByTapatalk1371776751.634680.jpgImageUploadedByTapatalk1371776761.051697.jpg
  15. Jun 22, 2013 at 6:43 AM
    SSG665
    Georgia
    Wow!!!That looks great.Im trying to hold out for the Gen 3 but seeing yours makes it hard.
  16. Jun 22, 2013 at 12:17 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thanks! I'm really happy with it.
  17. Sep 19, 2013 at 12:25 PM
    2012SilverSport
    2012SilverSport Well-Known Member
    Guam
    2012 Silver TRD Sport Double Cab
    CS Jumpers LED's throughout the cab and marker/DTRL's weather techs/seat covers. Head unit Pioneer AVHX5500BHS, Speakers, Front, Polk Audio DXi 6500 component, rear Polk Audio DXi 650s Subwoofer Sound Ordinance B-8PS, Amplifier Alpine KTP 445U. Front ICON extended travel 2.5 remote resi, Camburg UCA's. Rear ICON 2.0 remote res rear. Wheelers 3 leaf HD progressive AAL,
    Looks great!!! how is the ride with the ULK adjusted to 3". I have heard it can be really rough and causes too much pre-load on the springs.
  18. Sep 19, 2013 at 4:38 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thanks. It's only a little stiffer than the stock Sport ride. It's not bad even with the Load Range D Duratracs. I wouldn't call it a rough ride, but it certainately is not an Icon suspension. In spite of this, it's still more comfortable than my Corolla. Ha.
  19. Sep 21, 2013 at 8:39 AM
    2012SilverSport
    Guam
    LOL, thanks brother.
  20. Sep 21, 2013 at 8:47 AM
    elk340
    elk340 Well-Known Member
    Justin
    Fort Collins, CO
    '11 Tacoma TRD Off-Road
    Toytec ULK; OME Dakar leaf packs; Light Racing UCAs; OME carrier bearing drop; Toytec 3 degree axle shims; Toytec sway bar relocate kit; Toytec extended rear brake lines; ARE CX topper; BAMF rear differential skid; BAMF LCA skids; BAMF sliders; Budbuilt IFS, mid, transmission, and gas tank skids; HomerTaco mesh; River Rat 69 satoshi grille; Toyota Land Cruiser radiator grille emblem; tinted windows; Toyota all-weather floor mats; Toyota bedmat; I-Pod interface; block heater; ATO hi-lift bed rail mounts; HL-605 Hi-Lift; RotoPax 4-gallon gas can and bed rail mounts; mattgecko sliding window security bar; Sockmonkey decals.
    Congrats man! You'll love that setup. I know I like it :)
