Toytec Ultimate lift kit question
Discussion in 'Suspension' started by jrobson, Feb 19, 2009.
  1. Feb 19, 2009 at 5:02 PM
    jrobson
    jrobson [OP] Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I just sold my 07 TRD sport DC 4x4 and bought a new 09 model. I was originally going to go with a 6 inch kit and 35s but after realizing if I go 6 inches that there is no returning to a lesser kit, I have decided to look at a 3 inch kit. I have heard a few people say "stay away from coil overs, they ruin your ride." Then I have heard others say they cant tell a difference. Is any of this true??? I am looking at Toytec's Ultimate lift kit. They said it should clear 33s. What do you guys think? Will it still maintain a close to factory ride? I need some input from the gurus on this one. Also Fabtech told me they have a 6 inch kit for the new 09 in the works, but currently their systems dont fit the new 09 because of the VRSC or something like that.
  2. Feb 19, 2009 at 5:07 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Whoever is saying that coilovers ruin your ride must be smoking crack... :laugh:
    My coilovers (camburgs) ride amazing... I can't compare it to factory because that was a long time ago and can't remember what the stock ride was like...
    The ultimate kit will clear 285s (basically 33s). Whenever you do anything to the suspension, it will change the ride characteristics... put load E tires on and it will definitely ride differently... too many factors that can change the ride...
    VSC gets fukt apparently...
  3. Feb 19, 2009 at 5:16 PM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    So is Toytecs Ultimate lift kit seem like a good way to go? I figure if I still want more lift I can still go to a 6 inch system and sell the toytec.
  4. Feb 19, 2009 at 5:21 PM
    myrcrocks
    myrcrocks The Reasonable One
    New Brunswick, Canada
    2009 Tacoma SR5
    From a 3-inch lift?
  5. Feb 19, 2009 at 5:22 PM
    Delmarva
    Tucson, AZ
    thought I read something about it over at TN...
    Probably has to do with bigger tires... but I'm not too sure... no VSC on my 06 :thumbsup:
  6. Feb 19, 2009 at 5:23 PM
    Delmarva
    Tucson, AZ
  7. Feb 19, 2009 at 5:24 PM
    Delmarva
    Tucson, AZ
    with that kit, you would need to notch the crossmember for your front diff.
  8. Feb 19, 2009 at 5:57 PM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    That is definately something to consider. Has anybody used toytecs ultimate kit though, and what size tires are you running?
  9. Feb 19, 2009 at 5:59 PM
    Delmarva
    Tucson, AZ
    Lots of folks here have that kit... do a search to find them...
    they run 285s or 265s...
  10. Nov 19, 2009 at 6:19 PM
    tvaddict11
    tvaddict11 Member
    T
    bama
    06, taco, sr5, 4wd, xcab, borla, trd intake
    Light racing UCR's Bilstiens, Dif drop, Custom drop brackets on brake lines and Brake sh%t, Toytec ultimat lift. Bolrla single TRD intake pipe. Toyota valve stem caps lol
    My ultimate just arrived from toytec con lr uca's nice stuff. I cant wait to get started. Anyone says anything about the lr arms isnt an engineer. I am and the stuff is bullet proof. I cant wait to load this stuff on my taco. I'm gonna post pics. I'm runing 265's so i can bounce my sh8t here in bama..
  11. Nov 20, 2009 at 1:51 PM
    baldy77
    baldy77 Well-Known Member
    Albuquerque, NM
    05 TRD Offroad Doublecab Speedway Blue
    3" Toytec Adj Coilovers w/Bilstein 5100's front and rear, Toytec TSB AAL, LR UCA, Avid Weld-on Sliders, A.R.E. CX Topper.
    Congrats on receiving your lift. Mine just got shipped today so i'm hoping to get started on the install next week. I'll be running 265's too. Good luck, can't wait to see it.
  12. Nov 20, 2009 at 5:31 PM
    tvaddict11
    tvaddict11 Member
    T
    bama
    Got the rear lifted in 3 hrs by myself. I wish the kit contained spring pack bolts about 1/4" longeron the heads. The 3 degree spacer takes up all the stud length and It leaves a question as to contact with the hole in the spring perch on the axle. Wasted 45 minutes having to cut the U bolts to the right length. If you dont cut then you will be leaving some bad hang points. Gonna have to fab bracket for brake line Tee on axle to allow for travel down at lowest extended position. All in all went as advertised looks sick. 3 hrs,3 beers.lol Front tomorrow. uca's and coil overs..Will post when completed will include pics of mods.
    TV
