Toytec Ultimate Lift Kit (ULK) Measurements
Discussion in 'Suspension' started by JOE1424USA, Jul 29, 2013.
  1. Jul 29, 2013 at 12:13 PM
    JOE1424USA
    JOE1424USA [OP] Active Member
    Joe
    SoFL
    13' MGM, TRD OR
    Toytec ULK
    Hey guys,
    I have a quick question or two:
    I recently installed a Toytec ULK and add-a-leaf to a 2013, 4wd (TRD OR), double cab, short bed. However, I forgot to take measurements before I got started. I am wondering what the measurements from hub to center is for a stock truck like mine, and what the measurements should be after the lift is installed. I adjusted the front to be similar to the rear measurements, but feel like I may have raised it too far (collar is approximately in the middle of threads) because the ride seems very stiff. Example: when going over a speed bump slowly the front suspension seems to really slam hard on the other side. Any help would be appreciated. I installed the shims in the rear, sway bar relocator, and differential drop. I searched the forum for measurements and found some results, but kind of wanted to explain my whole situation.
    Thanks,
    Joe
  2. Jul 29, 2013 at 3:47 PM
    Chakraj
    Chakraj Well-Known Member
    CA
    2013 DCSB TRD SPORT v6 auto 4x4
    Badgers, I don't need no stinking Badgers.
    didnt measure before but im at 23.5 with my toytec coil overs, what are you at now?
  3. Jul 29, 2013 at 6:59 PM
    JOE1424USA
    Joe
    SoFL
    13' MGM, TRD OR
    Toytec ULK
    Closer to 24" on the front and 25" on the rear. How's your ride?
  4. Jul 29, 2013 at 7:13 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Toytec ULK has an adjustable coil seat so the amount of lift would vary from person to person. That's the whole idea behind buying an adjustable coilover. :)
  5. Jul 30, 2013 at 2:34 AM
    JOE1424USA
    Joe
    SoFL
    13' MGM, TRD OR
    Toytec ULK
    Yeah, I understand that Mike, but was wondering what the measurement would be for 3" of lift from stock, or what the stock ride height was. I did not measure my starting height.
  6. Aug 1, 2013 at 2:48 PM
    Chakraj
    CA
    I was at 24 when I first set them up, it had to much preload and was skipping along the road on the flats, but the bumps were OK. I set it down to 23.2 or so and it rides much better, no more skipping.
