Toytec Ultimate lift kit V.S. Bilstein Adjustable lift kit with 5100 shocks
Discussion in 'Suspension' started by whiteboytoy05, Apr 4, 2011.
  1. Apr 4, 2011 at 11:01 AM
    whiteboytoy05
    whiteboytoy05 [OP] Member
    Florida
    05 tacoma SR5 sport
    I have been doing research on lift kits and have narrowed it down to toytec due to the adjustability. However I am on a fixed budget and the $500 dollar diffrence in these lifts makes me lean towards the bilstein adjustable lift kit with 5100 shocks. Can anyone clearify why there is such a diffrence in pricing between this and the ultimate lift kit, and if the price diffrence is worth it? I am not a serious off roader but would like the lift to last, as well as having a smooth ride. Any help would be greatly appreciated.
  2. Apr 4, 2011 at 2:43 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The Toytec adjustable coilovers have an adjustable collar so you can set them at any height you like (0-3") while they are still on the truck.
    The bilstein 5100's have 4 distinct settings, 0",0.85", 1.75", 2.5", and they need to be removed from the truck and taken apart to adjust.
    The Toytec coilovers actually use the Bilstein 5100's as the shock, so the extra $$ you are talking about is solely for the convenience of adjustability.
  3. Apr 4, 2011 at 2:44 PM
    DrewH
    DrewH Well-Known Member
    I'd listen to him... he knows stuff about stuff.
  4. Apr 4, 2011 at 2:45 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    x2
  5. Apr 4, 2011 at 3:43 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    lol i'd x3 this statement
  6. Apr 4, 2011 at 4:29 PM
    fjrmurph
    fjrmurph Well-Known Member
    ok so ball park what is the difference in price to have the convenince of the adjustable lift height ?? I am just about to go for the Toytec ULK is it worth it??? THKS
  7. Apr 4, 2011 at 4:36 PM
    CdnSldr
    CdnSldr Well-Known Member
    Josh
    Northwestern Ontario (the only good part of ON)
    '96 Sex on Wheels ;)
    Deckplate mod, Bilstein 3" C/O's, NWO 2.5" rear leafs w/ overload, OME greasable Shackles, 33/12.5/15 Dura trac's, 15" Wheelers Steelies Type "B", Sat. Radio, Diff breather mod
    The ULK comes ready to go. As in, you dont need a spring compressor to assemble the strut.
    I believe that if you dont get the ULK you will need to get a new upper strut mount and bushing or reuse the stock one. I am not 100% about this tho. I got the ULK so the install was sh*t simple.
  8. Apr 4, 2011 at 4:45 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Just save yourself some money and buy the 5100 alone the ULK is garbadge for the price all your getting is 5100's with some threads to adjust and from what I hear there a PITA to adjust if you want real adjustable coil overs go buy icons or kings and if not just get 5100's. Just my 2c
  9. Apr 4, 2011 at 7:02 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Another option would be the $650 package with eibach springs, aal and 5100s all around. You would just need a spring compressor to install them. That would be better than setting the 5100s at 2.5 on your stock springs. There is also a radflo package for the same price as the toytec set up but dont know many running those shocks. I really like my toytec's and I off-road frequently. Sounds like you are interested in the adjustability and that's why I got them. You can compersate for the lean and tire fitment too. New UCA's will most likely save you headaches in the long run.
  10. Apr 4, 2011 at 7:11 PM
    KPT
    09 Prerunner
    You can indeed re-use the old top plate and bushings.
  11. Apr 8, 2011 at 11:19 AM
    whiteboytoy05
    Florida
    05 tacoma SR5 sport
    Thanks for all the input, looks like im gonna save myself some money and just rent a spring compressor and go with the $650 setup
  12. Apr 8, 2011 at 12:15 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    I sold my ULK and went with RCD. After I adjusted my ULK the ride was too rough and it increased my CV angle too much causing me to blow CV boots.
  13. Apr 8, 2011 at 12:41 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Look into the 1/4" spacer for the taco lean as it seems most people are using those!
  14. Apr 8, 2011 at 12:45 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Im with Jlee... I have installed and attempted to adjust more than one self of the toytec coilovers. Unless you are dead set on some oddball adjustment setting just stick with 5100s. With other coilovers you get a lot more than just adjustability. You get valving and spring rates made specifically for your truck. So just put the 5100s on til you can save enough money to get a set of real coilovers. The Toytecs are a nightmare to adjust on the truck because you have to hold the sleeve while you turn the large nut.
    As for the spring compressor. I highly suggest you take your shocks to a shop and have them swapped for you. Its not terribly expensive and far far far more safe then renting or borrowing a set of suicide sticks.
  15. Apr 8, 2011 at 1:36 PM
    K1992f
    K1992f Well-Known Member
    Kanon
    Dirty Hanover pa ...
    2012 tacoma TRD sport fully loaded
    6" fabteck 20" fuel hostage 33" nitto MTs
    I wold rather pay another 400 and get the rcd lift :)
  16. Apr 8, 2011 at 5:47 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    I guess people have had issues with toytec but mine are easy to adjust and perform well! I can only speak from my experience but doubt its a fluke I got a good set, but it is what it is. You just have to decide if you need a high end off road shock or not. 5100s set at 2.5 would be easy but sounds like they don't ride as good as upgrading the springs. Great idea from the FJ dude on having a shop assemble them, will make things much easier....and safer. Thats what I did.
  17. Apr 12, 2011 at 2:11 PM
    Rob2.7Taco
    Rob2.7Taco Well-Known Member
    Rob
    Bay Area, CA
    2010 Tacoma Prerunner
    What height would i set the front 5100's to level my stock prerunner?
  18. Apr 12, 2011 at 2:19 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I've got the ULK and I really like it. I haven't messed with adjusting it just yet but I will be adjusting the passenger side very soon. The passenger side is currently sitting higher than the driver's side.
    Juhn421 likes this.
  19. Jul 4, 2011 at 5:12 PM
    2005tacoma
    2005tacoma Member
    I have a stock 2005 double cab that im looking to lift. if i go with the bilsteins can i adjust it to a 2" lift in the front? and if i do that will i still need UCAs and the diff drop?
    Thanks
  20. Mar 14, 2015 at 5:10 PM
    dchaney389
    dchaney389 New Member
    Boulder
    09 superwhite "Lana"
    Does anyone know why Toytec says the ultimate kit adjusts from 0-3" while the bilstein website says the 5100 adjustable strut only goes up to 2.5"? Is it not the same part?
