Toytec Ultimate Lift too light?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fr33Ma$on, Feb 10, 2020.
  1. Feb 10, 2020 at 3:40 PM
    Fr33Ma$on
    Fr33Ma$on [OP] Well-Known Member
    Eastern Washington
    2006 Indigo Ink Pearl TRD Sport Tacoma
    Got the ultimate lift kit a while back and worked well until crazy heavy off-road bumper was installed. Now the front sags pretty low, and the ride is very rough, actually broke the motor and bumper mounts once from the harshness. Now what I would like to know is what options I have for changing springs on the coil overs to possibly offset the symptoms the new bumper bestowed upon my truck lol. I’ve been looking at OME 886 coils as they seem like they’d work quite well, however I don’t know how compatible they are with the Toytec/Bilstein 5100s, not a whole lot of resources on the site. I would appreciate any help greatly, want to fix the ride and lift before the bumper falls off again lmao.
  2. Feb 11, 2020 at 8:35 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
  3. Feb 11, 2020 at 9:51 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    You can pair 886 with the Bilstein 5100. The only difference is that the toytec Bilstein 5100 has the top plate spacer. You may be able to get away with running it but I would probably install with oem tophats at the toytec top hat may reduce travel. The best option is to run 6112 with the 650lb 2.5" 14" eibach springs. Larger shock to improve suspension feel and to handle the extra weight.
