Toytec ultimate lift
Discussion in 'Suspension' started by DEDAFLO670, Oct 1, 2015.
  1. Oct 1, 2015 at 10:35 PM
    DEDAFLO670
    DEDAFLO670 [OP] Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    Is it normal for the ride to be a little stiff I have the coils set to 3inchs..anybody have the same issue?
  2. Oct 1, 2015 at 10:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    3" is maxed out and well documented to have a poor ride. Putting it closer to 2" sould improve it significantly.
    Edit: did you change the tires as well?
  3. Oct 1, 2015 at 11:47 PM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    Ya I'm running 265/70/17 ko2s
  4. Oct 1, 2015 at 11:54 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you get the C-load or E-load tires? E-load are going to have a much harsher ride than C.
  5. Oct 2, 2015 at 9:39 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Hmm, all the good off-road tires that I'm looking at are E load. Any good C load OR tires out there?
  6. Oct 2, 2015 at 9:49 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not sure on your wheel size since you have changed from stock.
    16s 265/75/R16 Duratracs in C-load
    17s 265/70/R17 BFG KO2s in C-load
    I chose my wheel size (17s) based on the tires I wanted to run so I could get C-load tires.
  7. Oct 2, 2015 at 10:08 AM
    T-Rex266
    T-Rex266 SpaceX Director Moderator
    Elon
    What PSI are u running?
  8. Oct 2, 2015 at 10:17 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I've got the Toytech Boss kit and have the shocks cranked to 3" lift. The front end is sort of like riding on a jackhammer. Gonna dial 'em back a little OR take 'em off and go a different route. Good product, but 3" is stretching them just a tic farther than they should be IMHO. I'd bet you're suffering from the same thing.
  9. Oct 2, 2015 at 10:19 AM
    T-Rex266
    Elon
    If you have it on the last thread, (about 3.5") it's going to be a stiffer ride due to the preload.
  10. Oct 4, 2015 at 4:43 PM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    This is how it sits now
  11. Oct 9, 2015 at 2:17 AM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    Anybody else is set like this?
  12. Oct 9, 2015 at 2:50 AM
    tagaman670
    tagaman670 Hafa Adai!
    joey
    Saipan, CNMI
    White "BAJA" DCSB
    performance shift knob +5hp decal Tint Rockford Fosgate 6x9's JL Audio 8" Sub RockFord Fosgate POWER 550x amp
    Bro, probably just need to break in the suspension lol.. Also check your tire pressure because I Know for my Baja PSI according to the door jam is supposed to be set at 45! Per BFG KO's which makes it for a very stiff ride. So I had to knock it down a few ride was much better
  13. Oct 9, 2015 at 11:34 AM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    Alright I'll try that bro thanks!
  14. Oct 11, 2015 at 4:20 PM
    TacomaRockStar
    TacomaRockStar Well-Known Member
    LUCA
    Bayville, NJ
    2024 OR
    Interior carbon overlay, TRD Skid plate, lasfit switchback DTRL, glove box fix, 5% ceramic tint, SXTH Element trail pipe, Lower front fascia delete,
    Looking to add a 3" on my 2015 TRD off road. Is toytech still a good way to go with light racing UCAs. I had this set up on my 2011 but wasn't the ultimate kit.
  15. Oct 11, 2015 at 4:46 PM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    It is a great way to go, I'm just fine tuning my front coil overs right now but installation an quality is great!
    T-Rex266 likes this.
  16. Oct 12, 2015 at 4:29 PM
    TacomaRockStar
    LUCA
    Bayville, NJ
    2024 OR
    what is the main difference from toytec ultimate lift and 3 inch lift kit (TTHA-CK)
  17. Oct 12, 2015 at 7:03 PM
    DEDAFLO670
    Manuel
    Waipio
    15 Trd sport
    If I'm not mistaken the (ttha-ck) it's not adjustable an the ultimate is
  18. Oct 29, 2015 at 4:38 PM
    TacomaRockStar
    LUCA
    Bayville, NJ
    2024 OR
    what are the alignment specs after installing a 3" lift?
  19. Oct 29, 2015 at 4:51 PM
    fletch97
    fletch97 Well-Known Member
    NJ
    2020 Tacoma TRD Sport
    Boss lift kit set at 2.5", full leaf pack with 3rd leaf removed, 265/75/16 Cooper st Maxx load e. Rides a little tougher then stock but typical truck ride. More jumpy/squirrelly above 65 when hitting bumps. No complaints otherwise.
  20. Oct 29, 2015 at 11:05 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Should have gotten Icons.
