Toytec Ultimate Tacoma lift for 95.5-04 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ktaco, Mar 25, 2009.
  1. Mar 25, 2009 at 1:06 PM
    Ktaco
    Ktaco [OP] Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Hey guys,
    Alright so i'm new here. After ALOT of searching and comparing I think i finally chose the lift I'm looking for. I was looking at drop bracket kits at first (Fabtech 6'' & Tuff Country 5"), but I only want to run 33's and really drop brackets are more for looks then beating in the Trails IMO. So this ultimate lift for my tacoma looks like it might do the trick. Couple of questions.
    1. Any one running this kit? Pictures?
    2. If I crank them to 3'', will I be able to run a 33x12.5 tire? I plan on using my stock rims for now. Imput? (this is a biggie. I don't want to go under a 33'' tire so I want to make sure this lift can handle them.)
    3. I will get the kit with the full new OME leaf pack instead of AAL or anything like that. However i'm unsure about the front coils. Should I go with light (500lb) or Med (600lb) coils. I plan on adding a bummper and winch on my truck down the road...might only be in a year's time though. How will the Med coils affect my ride and performace if it's only stock weight for now?
    Haha my friends are getting fed up with me on this lift thing. When I do something I want to do it right, hence not going for the much cheaper coil spacers or something like that.
    Thanks for any help.
  2. Mar 25, 2009 at 3:24 PM
    Youngunner
    Youngunner Well-Known Member
    Yellowstone National Park
    2003 Tacoma
    The standard expedition setup...
    I just pieced together my own lift and it just so happens to be everything in that ultimate kit. I didn't have a choice of coils tho so I can't help you there. Like any higher weight rated coil, ride will get stiffer. If you're adding the bumper and winch, probably a good idea to go with Med.
    So far it's been awesome on and off road. PM member Neubs and he might be able to get you a deal.
    I've attached a before and after. Hope it helps.
  3. Mar 25, 2009 at 4:16 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got the coilovers, but a AAL in the rear. But I love the shocks they ride great, you shouldnt have any issues with running a heavy bumper with these. If they sag a little you can just crank them up to adjust for the weight. You should be able to run that size tire, only if you get wheel spacers or new wheels with a 4" or less back spacing.
    Here are some pics of them!:D
  4. Mar 25, 2009 at 4:18 PM
    maddog61
    maddog61 Member
    Revelstoke,BC Canada
    04 4x4 2.7 Tacoma
    Must be nice no rust??? Good looking truck!
  5. Mar 25, 2009 at 4:23 PM
    ETaco23
    Evan
    PNW
    Nope! Thanks!
  6. Mar 25, 2009 at 6:23 PM
    Ktaco
    Nice looking taco. How much do you have those cranked up? Any CV problems since you've been running the lift? I think you're right about needing wheel spacers for those tires, i might check into 10.5 ones. I'm thinking of going with the Med coil's, it's only another 100lbs difference so i can't see it being too stiff even without extra weight on the front.
    Thanks for the reply.
  7. Mar 25, 2009 at 6:26 PM
    Ktaco
    what are yours cranked to youngunner? looks good with the lift.
  8. Mar 25, 2009 at 7:37 PM
    ETaco23
    Evan
    PNW
    Im at 3" lift. I had a spacer lift before and didnt like the ride, so I got these. No cv problems, I had a small leak on the inners but got it taken care of. Ofcourse I have the diff. drop kit.... highly recemended if you go 3".
  9. Mar 25, 2009 at 10:57 PM
    Youngunner
    2003 Tacoma
    I was at 3" when i first set it. I'll have to re-check now they're broken in. I have the diff drop too, no problems at all. My wheels are stock 265/70/16. I'll be going with 32/1150/15s soon.
  10. Mar 26, 2009 at 11:53 AM
    Ktaco
    alright thanks for the help guys. I assume installation was smooth.
  11. Mar 26, 2009 at 4:55 PM
    ETaco23
    Evan
    PNW
    Yep! pretty smooth! Just remember to disconect the sway bar so that your suspension can fully droop. Bc the coilovers are a bit longer then stock. But thats about it!
  12. Mar 26, 2009 at 4:57 PM
    ETaco23
    Evan
    PNW
    Def. check them! mine went down almost 1/2"
    My front measures 38-3/4" or 7/8" from the ground, although I have 285/75/16.
  13. Mar 26, 2009 at 5:00 PM
    Ktaco
    Yeh I was wondering about that to... once these start to "sag" i might run into trouble with my 33's. Are they hard to ajust once it is on the truck?
  14. Mar 26, 2009 at 5:12 PM
    ETaco23
    Evan
    PNW
    not really... I just jack it up and adjust. ofcourse also taking the wheels off...:) Just need a little muscle.
  15. Mar 26, 2009 at 5:18 PM
    Ktaco
    I also see that you have aftermarket UCA's. I've heard that I might not be able to align the front with stock UCA's if I go 3'' or higher. Heard anything like this before?
  16. Mar 26, 2009 at 5:24 PM
    ETaco23
    Evan
    PNW
    yep! I had stock UCA's for awhile. Les Schwab got really close to spec and I didnt notice it, until a little while later it started to wonder and pull a little. So I decided to get them so I didnt have any issues. But I would maybe run you're stock UCA's first to see how they do, you might not have any issues. Your camber will def. be off a little, but just dont go higher then 3" lift.
  17. Oct 20, 2009 at 10:18 PM
    Trdman98
    Trdman98 Member
    98 tacoma 4x4 6"
    3" body, Toytec Coilovers, Dakars, Bilsteins, 33"BFGs, Intake, Exhaust
    mine with a body lift and 33s
  18. Oct 21, 2009 at 6:25 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Ideally you want 4" to clear 33's but people are clearing 33's w/ 3" of lift and some minor trimming for full lock. Anytime you adjust your coilovers you may need to consider a re-alignment.
  19. Oct 21, 2009 at 8:37 AM
    asdf
    asdf Well-Known Member
    Charleston, SC
    03 PreRunner
    3" in front, stock in back, 285/75/16 BFG KM2,5% tint all around, UWS black low profile, DTRL,line-X, deckplate...
    evertaco, how much did your toytec coilovers, shocks, and TC UCA's cost all together if you dont mind me asking
  20. Mar 23, 2011 at 7:56 PM
    dirtridermc
    dirtridermc New Member
    tacoma 4x4 4cyl
    3in lift, 31s
    how much total lift do u got???
