toytec vs icon
Discussion in 'Suspension' started by kilgoja, Jan 16, 2010.
  1. Jan 16, 2010 at 10:28 PM
    kilgoja
    kilgoja [OP] Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    how much of a difference is there between these two coilovers?...the toytecs are $800 and the icons are around $1000....just wondering if the icons are worth the extra $200 or if they are only a little better
  2. Jan 16, 2010 at 10:30 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    I just replaced my ToyTecs with ICON extended travel coils. I've just recently started to go offroading more. How much offroading do you do?
  3. Jan 16, 2010 at 11:27 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    You can get the Icons for like $880 shipped from downsouthmotorsports. I would imagine the Icons are a little stiffer than the Toytecs because the shock valving is super tight and Icon also uses a 700 lbs. spring.
  4. Jan 17, 2010 at 12:05 AM
    kilgoja
    Alabama
    :mudding:
    oh ok good info...i don't want stiffer.....i don't off road much ...just every once in awhile...mostly on road as a daily driver...what is the spring rate of the toytec?
  5. Jan 17, 2010 at 12:17 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I don'tknow about the Totec's, but I love my Icons. Don't have anything to compare them to, but I don't find the ride to harsh at all.
  6. Jan 17, 2010 at 12:22 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    I have gone gone from stock shocks, to bilstein 5100s (toytec), to Icon 2.5. Without a doubt the best ride you will ever get is the ride you left the dealership with. Replacing your shocks with Icon or Toytec will give you a more firm ride which is ideal for offroading. I personally love my Icons when I offroad and have come to accept the stiffer ride I get on the highway. If you want to put a lift on the front of your truck to level it than I recommend the bilstein 5100s for their affordable price. They are only slightly stiffer than your stock shocks.
  7. Jan 17, 2010 at 12:39 AM
    kilgoja
    Alabama
    :mudding:
    yeah at first i was gonna go with the 5100s and use the stock springs but i read some complaints that it was kindof a stiff ride when hitting cracks and such in the road since it compresses the stock springs to provide the lift....the toytec coilovers have 5100s in them but i've heard they ride good and not too stiff....i have no idea as i've never used it either way....is there any difference in using the 5100s with the stock springs set at 1.75" and using the toytec coilovers set at 1.75" ?....i don't know how different the springs are on the toytec coilovers than on the stock springs...all i can go by is what people have said on here in different threads....the conclusion i came to is that the toytec coilovers would be a better ride....anyone have experience with both?...i figure i'd be ok since my car is a mitsu evo ix mr with bilstein shocks....it's alot stiffer than my truck...truck feels like you are floating on the road so a little stiffer wouldn't hurt....i just don't want it to be too stiff where it gets annoying
  8. Jan 17, 2010 at 12:59 AM
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    1.75" is a good setting even if you are using your stock springs and 5100s. I never had a complaint until I went to 2.5" lift. That's when you really need to consider spring rates.
  9. Jan 17, 2010 at 8:07 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    I had no complaints with my toytec's and they were a little softer than my friend's Camburg's. They aren't a bad ride for on road or a little offroading by any means.
  10. Jan 17, 2010 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Toytec uses a non rebuildable Bilstien 5100 shock, and a 600# spring. The Icons have a rebuildable shock, and a 650# spring. Increasing the spring rate, increases the stiffness of the suspension. Both are valved accordingly for the springs they use.
  11. Jan 17, 2010 at 8:18 AM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    Chris saves the day
  12. Jan 17, 2010 at 8:22 AM
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    the advantage to Icons is that you can rebuild them. so a few years down the road when your bilsteins droop and fade, you'll have to drop some $$$ to get new ones. but with icons you send them back and they redo them. IIRC it's like 60$ and the price of shipping.....so way less than the cost of new shocks.
    I'm not saying the bilsteins suck, I have the 5100's for my rear shocks. they just have a softer ride, and a little lower quality.
    The advantage to stiff shocks is that the car recovers faster and you get less body roll or bouncing over big bumps. at least in my experience thats the change I noticed
    EDIT: Chris beat me to it :pout:
  13. Jan 17, 2010 at 9:07 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    icons are so worth the extra $200. i wouldn't buy anyother OE replacement coilover
  14. Jan 17, 2010 at 9:09 AM
    jandrews
    '09 FourDubDee TRD OR
    Icons are my planned suspension components when it's lift time. When things cost more, 99% of the time there's a good reason for it.
  15. Jan 17, 2010 at 9:13 AM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    no comparison IMO
  16. Jan 17, 2010 at 11:50 AM
    kilgoja
    Alabama
    :mudding:
    ok thx for the replies...i have a reg cab so i think the toytecs would be better for me since my truck doesn't weigh as much as an ac or dc...plus i mostly drive on road and only off road sometimes...my truck is a daily driver...good info though for those trying to decide...i talked with toytec and they said they have an option for a 500lb eibach spring that i could use on my reg cab so it wouldn't be so stiff since the regular spring on the coilovers is 600lb
  17. Jan 18, 2010 at 12:42 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Go with the Icons, they will last forever since they are rebuildable, and they are also revalvable so you can change how stiff or firm you want them to be.
  18. Jan 18, 2010 at 3:29 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    IMO the toytecs are an over priced threaded bili 5100 with and eibach coil. reg 5100's are adjustable anyways and you can buy your own coils for $100 and have close to the same thing for half the price. i'm sure they are a good product but Icon's are gonna blow your mind. i'd drop the extra $$$ and go with the tried and true race proven (back when the were donahoe racing) design.
  19. Jan 18, 2010 at 3:41 PM
    kilgoja
    Alabama
    :mudding:
    yeah i'm sure they are better off road but the spring rate would be too stiff for my reg cab and for mostly driving on road as a daily driver
  20. Jan 18, 2010 at 3:48 PM
    tmat
    tmat Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    I read something about the bilsteins "drooping" eventually. About how long will this take to happen?
