Toytec vs Sway-A-Way coilovers
Discussion in 'Suspension' started by dylandercole, Sep 21, 2009.
which coilovers?
  1. Toytec
    68 vote(s)
    38.4%
  2. Sway-A-Way
    109 vote(s)
    61.6%
  1. Sep 21, 2009 at 1:38 PM
    dylandercole
    dylandercole [OP] Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    So I want coilovers to replace my spacers, i have and Ive been looking at the toytec coilovers for $700 http://www.toyteclifts.com/index.ph...ategory_id=63&option=com_virtuemart&Itemid=72
    But 4 wheel parts owe mes a favor and said they can get me Sway-A-Way 2.0 coilovers for $600 flat http://www.swayaway.com/VehicleMake_4.php Which ones should i go with. I need a full 3'' of lift which i know the toytecs do but i really have no information on the sway-a-ways. any experience anyone? Which one!?
  2. Sep 21, 2009 at 2:04 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    dude, dont start 2 threads on the same topic. i helped you out in your other one and this one i'm gonna say your dumb.
    your dumb. ;)
  3. Sep 21, 2009 at 2:22 PM
    dylandercole
    Dylan
    i didnt mean to...? it said the first one didnt post.
  4. Sep 21, 2009 at 3:24 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    it's cool man, i was just messing w/ ya. but seriously, go w/ the SAW's
  5. Sep 22, 2009 at 4:44 PM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    i had the toytecs before i got my saw's wish i woulda just bought the saw's the first time
  6. Sep 22, 2009 at 4:49 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    Fixed it for ya ;)
    haha (just messin with you)
  7. Sep 22, 2009 at 7:50 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    AH!!! now I'M dumb too :D
  8. Nov 16, 2009 at 1:31 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    Could you explain the difference's...thanks.:)
  9. Nov 16, 2009 at 2:24 PM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    plus, don't forget about how often you need to rebuilt the SAWs.
    I guess you have to ask yourself, what are you doing with your truck? going to work, or 4wheeling on rocks?
    ToyTec Lifts offers a better warranty than SAW's - LIFE TIME!!!
    some food for thought..
  10. Nov 16, 2009 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They are also available in a 2" shock.
  11. Nov 16, 2009 at 3:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, the Sway-A-Way's are gonna ride pretty stiff set at 3".....Most people recomend 2.5" max. They a use a 650# spring, where as the Toytec CO's use a 620# spring (some have a 600# spring). Despite the extra spring rate, they should still ride a bit better, as the 5100's are more valved for a stock spring, with a little preload added, and the SAW's are designed for their spring rate.
  12. Nov 16, 2009 at 3:36 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    We had the same experience with the toytecs over the mod day weekend. IMHO the design is pretty poor. The spanners bent very easily. Part of the problem is the threaded sleeve rests on the 5100 c-clip. It is not attached to the shock. this means you have to use two spanners to turn them. you need to hold the sleeve to keep it from spinning while you adjust the large nut. We also installed a set of Icons the same day. the design was far superior. The threaded collar part is on the top and attached to the hat that bolts to the coil bucket and holds it firmly in place to allow you to just turn one nut. The SAWs are a similar design. We ended up having to take the toytecs apart so we could relieve the pressure from the spring and adjust every thing by hand. IMHO they are no better than just buying standard 5100s and adding the eibach spring. Unless you want the fine adjustability for the taco lean in that case you should make sure to get them set where you want the first time you install them.
  13. Nov 16, 2009 at 3:37 PM
    ToyTec Lifts
    Rocky Mountains
    All our adjustable coilovers use a 600lb spring!! (except for the new tundra's, they use a 700# coil)
    Those 620's you see on the group buy, are NOT what we use in our coil over. That's just a new spring we are selling separately.
    I just want to make sure he has the accurate information about the c/o's.
  14. Nov 16, 2009 at 4:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good to know. Last set I saw had a 620# rate, so I asmumed it was the coil that came on it.
  15. Nov 16, 2009 at 6:52 PM
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    I have the SAWs and they are pretty sweet, i would definetly recomend them, they are a little stiff set at 2.5 which is what i left mine at but it was still quite a bit better ride than stock.
    Also, am i correct in saying that the toytecs arent rebuildable?
  16. Nov 17, 2009 at 3:52 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Yes.
  17. Nov 17, 2009 at 6:25 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Been riding on my Sway 2.0 since Nov 07...still no rebuild granted mine is on road, low miles prolly 10k since my 02 has 58000 miles on the odo and it is always cleaned and recoated with anti rust so the coilovers looks new but I am in Nor Cal so all I see is rain no snow, sand...
  18. Nov 17, 2009 at 7:27 AM
    tmolina
    tmolina Well-Known Member
    Thomas
    AZ
    '02 Tacoma dbl cab Prerunner
    2 inch lift with SAW's on front, AAL on rear
    have had my SAW's on since late '05 and no rebuild and they ride really nice at 2.5" for my prerunner. Not too much offroading just when I go hunting or fishing...
  19. Nov 17, 2009 at 9:04 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    x1000000 My exact feelings.
  20. Nov 17, 2009 at 12:42 PM
    The Parts Whore
    The Parts Whore Slinging parts since '03
    So...I when the Bilstein are blown, you'd replace them for free? :D
    If not, then what does the warranty cover?
