Toytec vs Wheeler AAL
Discussion in 'Suspension' started by rc2125, Jul 31, 2011.
  1. Jul 31, 2011 at 7:28 PM
    rc2125
    rc2125 [OP] Well-Known Member
    Indiana/Michigan border
    19 TRDor
    Recently added 5100's up front on my 09 dbl cab, set on 1.75". Since that raised the front a little much, I got some toytec AAL's. Those raised the rear too much now. Also got the driveline vibration at take off, just under 60,etc. I messed with the carrier bearing and got it set the best I could, got some shims on the way.
    Are the Wheeler 1.5" AAL's a different leaf than the Toytec AAL's? Toytec claimed around 1.5-2" lift, they raised mine over 2". Been a few weeks now, no settling, have hauled the horse trailer a few times and left it hooked up for several nights in hopes to settle the springs a little.
    I am thinking about ordering the Wheeler 1.5" AAL's, but would hate to find out they are the same springs or something like that....
    Any help/insight would be appreciated.
  2. Jul 31, 2011 at 7:43 PM
    Treedawg37
    Treedawg37 Well-Known Member
    Barry
    Central, Alabama
    '11 Tacoma DC 4X4 SR5 SB,
    BHLM, tinted tails, weathertech mats & visors, sportsman"s camo seat covers, diff breather mod.
  3. Jul 31, 2011 at 8:50 PM
    acdronin
    acdronin Well-Known Member
    Don't know about different leafs from the Toyotec, but I can saythat the Wheeler's 2 inch aal I put on hasn't settled more than the day it went on, and I loaded it a few times with rock
  4. Aug 1, 2011 at 5:51 AM
    rc2125
    19 TRDor
    Went ahead and ordered the 1.5" wheeler aal 's. Will post before and after pics, with measurements for future reference.
  5. Aug 1, 2011 at 5:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The 1.5" 3 leaf progressive AAL is awesome :)
  6. Aug 1, 2011 at 6:45 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    sub'ing, would like to know this as well.
  7. Aug 1, 2011 at 6:48 PM
    06TXED
    06TXED Well-Known Member
    Tony
    Colorado Springs
    2023 DCSB MGM TRD OR 4x4
    X2 why yes it is
  8. Aug 1, 2011 at 9:20 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    X3
    Don't think its made for weight, more for flex! It handles moderate loads pretty good though!
  9. Aug 1, 2011 at 9:37 PM
    Chazlom
    Chazlom Well-Known Member
    So Cal
    2010 DC TRD Off-Road 4x4
    My Wheelers 3 leaf progressives have seem to go flat. I have wheeled hard (flexed) out a bunch, but now I'm thinking of going with the Alcan or Deavers.
  10. Aug 1, 2011 at 11:06 PM
    Chazlom
    So Cal
    Stock springs, non tsb, opted to go without the bottom overload spring. Yes, I dont know how/why but mine are much flatter than the pack in your pic. :(
    Like you said, I'm very happy with the ride and they wheel great.
  11. Aug 2, 2011 at 9:00 AM
    Pugga
    Massachusetts
    So far they've held up great! I'm in the middle of a home renovation and have been towing a lot and hauling pretty heavily. The 3-leaf AAL has done a great job so far. I kept the overload in though so they'll only squat but so far. With a moderate load, I'm up off the overload, when loaded heavy, I barely kiss the overload. Hopefully they last a while!
  12. Aug 7, 2011 at 3:19 PM
    rc2125
    19 TRDor
    Got the "2 inch" toytec aal's swapped out with the "1.5 inch" wheeler aal's. Also added the toytec 3 degree wedges.
    The wheeler aal's were at least a few inches longer over all. Now the truck sits an inch lower in the rear, as I had hoped. It also feels suprisingly different when driving the same roads/bumps, a little less harsh or more cushy in the rear.
    The wedges helped a little with the driveline vibration on take off. Had to tinker a bit with the drive shafts and carrier bearing alignment to dial it in. Added 3/16" shims to the carrier bearing to help line things up, used an angle-meter app on the iphone to check driveline angles. Still messing with eliminating vibration.
    *update, didn't know the two front coil springs where different, til reading about it yesterday. Kinda wondered why the color codes were different when I took them to get compressed for the 5100's, didn't think much of it at the time. Swapped them out this morning, cuz of course, my 50/50 odds of getting them right by chance didn't work out.
    The passenger side front wheelwell "clearance" was around 7 inches, while the drivers side was about 6. After the spring swap, and driving around the yard to let them settle, both sides are like 6 3/4" now. Color code spring white pink is on the drivers side now. White orange on the passenger side. Both springs were exactly the same length measured, but when they were the other way, the drivers side sagged just over a half inch!
    5100's 1.75 wheeler 1.5" aal's:
    5100's 1.75 and toytec aal's:
    5100's 1.75 without aal's and one of the dd's:
