TOYWERX 05-11 Made-To-Order Satoshi Grills
Discussion in 'HomerTaco' started by HomerTaco, Aug 9, 2011.
  1. Mar 28, 2012 at 6:14 PM
    #1001
    Crdoublee
    Crdoublee Member
    Oahu
    SW TRD Sport Double Cab
    In progress
    The suspense is killing me....been waiting patiently since November. Can't wait to finally get that pm from Homer.
  2. Mar 28, 2012 at 6:16 PM
    #1002
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    You and me both bro! :D
  3. Mar 29, 2012 at 7:41 AM
    #1003
    la0d0g
    running for the hills
    For crawling not hauling
    Thanks Homer, grille showed up Tuesday :woot: Swapped out the mesh for the one I've been prepping at home. Saving the other one for a backup. Hard to tell with the crappy pics but the letters are outlined in MGM. Now I just need to relocate my horns and paint the radiator. Hopefully the weather cooperates this weekend, fingers crossed.
  4. Mar 30, 2012 at 9:06 AM
    #1004
    chris duby
    chris duby This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    Awesome work as usual... Thanks Craig. It was well worth the wait. :D
  5. Mar 30, 2012 at 9:36 AM
    #1005
    la0d0g
    :spy: MGM in the background
  6. Mar 30, 2012 at 9:41 AM
    #1006
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Did you install the TOYOTA letters yourself, or did Craig make it that way? Looks awesome! Both of them! :cool:
  7. Mar 30, 2012 at 9:49 AM
    #1007
    la0d0g
    Installed myself. Bought the FJ emblem and then cut it apart with the dremel. Epoxied some hardware to the back of each letter and then attached it to the mesh I had previously bought from Craig.
    About 1/2 way through cutting the letters
    With the hardware attached
  8. Mar 30, 2012 at 9:57 AM
    #1008
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    That's great! My grill order is gonna change 20 times before I come up on deck. :eek:
    What mesh is that and do the screws go through the holes or do you have to drill?
    Thanks for the response. :cool:
  9. Mar 30, 2012 at 10:15 AM
    #1009
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    He has M1. :cool:
  10. Mar 30, 2012 at 10:17 AM
    #1010
    la0d0g
    ^^ like he said :)
    Screws fit right through and then I used a washer and nut with some loctite on the back.
  11. Mar 30, 2012 at 10:19 AM
    #1011
    LMR
    LMR GO JETS GO
    Lee
    In The True North
    2008 Tacoma DCSB TRD
    Shorty antenna, Weathertech digital fit, tonneau cover
    Would most emblems fit through the M4 holes?
  12. Mar 30, 2012 at 10:34 AM
    #1012
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It all depends on how they are attached...
    If you purchase a stick on emblem like the stock ones then there is no issue at all.:D
  13. Mar 30, 2012 at 11:10 AM
    #1013
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Grills on the left are the batch currently in production.
    There is a bit more fab work to do on them but that will be completed this weekend.
    The outer surrounds and mesh will be back by the end of next week if not sooner and I'll start shipping them out.
    We have the Easter Holiday weekend coming up so that may goober me up a bit. - We'll see :notsure:
    The grills on the right just came in (way early too) So I'll be PM'ing the next batch maybe this coming weekend?
    Thank you,
    ~ Craig
  14. Mar 30, 2012 at 11:19 AM
    #1014
    Saskquatch11
    Saskquatch11 TRUCK YEAH
  15. Mar 30, 2012 at 4:02 PM
    #1015
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Wow.
    With the black grill, is it really worth the time and effort to separate the letters? I have the same badge for mine, but from looking at your pictures, unless it's backlighted, it doesn't seem that the background would be noticeable on the truck.
    BTW: For anyone that wants the part number... 75311-90K00 will get you the FJ grill badge with white lettering.
  16. Mar 30, 2012 at 5:04 PM
    #1016
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    SAWEET! Thanks Rich! :cool:
  17. Mar 30, 2012 at 6:11 PM
    #1017
    Rich91710
    Rich
    Los Angeles
    08 Base
    Here's some details on how it looks out of the box.
    There's a number of ways to be creative with the mounting. I had planned on leaving the "fin" spacers on the badge to hold it out from the mesh to keep the edges of the letters from abrading the paint on the mesh.
    Hard to see in the pictures but the parts on the ends look like they snap into a hole in the grill. Center, as can be seen, is drilled for a screw.
  18. Mar 30, 2012 at 7:51 PM
    #1018
    bebopblues
    bebopblues Well-Known Member
    Los Angeles, CA
    09 PreRunner SR5 DC/SB
    I wanted to somehow screw on my emblem too, but I just ended up glue it on, it's just much easier. If my truck was white, I would've went with those white TOYOTA emblem too, looks great on your truck. Here's mine with the tacoma emblem just glued on today:
  19. Mar 30, 2012 at 8:06 PM
    #1019
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    All I did was grind down the center notch on the back to the fins you're refering to. Then it just snapped into the M1 mesh like it was made for it, but I addad a little epoxy to the back side of the mesh to make it permenant. It took a whole 15 minutes.
  20. Mar 30, 2012 at 8:09 PM
    #1020
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    http://www.youtube.com/watch?v=3YmMNpbFjp0&feature=youtube_gdata_player
