TOYWERX Custom Overhead Console
Discussion in 'HomerTaco' started by HomerTaco, Jan 8, 2017.
  1. Jan 10, 2017 at 5:46 AM
    #41
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    not a replacement, but you cut a hole, to fit 6 switches.
    https://youtu.be/yC88hp_vYng?t=197
    What about an Iggy panel? that is what I am running, in front of the cup holders
    Iggy, Camel51 and ChadsPride like this.
  2. Jan 10, 2017 at 5:51 AM
    #42
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I was planning to cut the hole out for the 6 panel. But having more space behind the switches for the wiring and connections is always a plus.
    I use that space to store things when on the road. So the space in front of the cup holders wouldn't work for me.
  3. Jan 10, 2017 at 6:29 AM
    #43
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    That is also a storage area for me. Most the time I put my wallet in there while driving
  4. Jan 10, 2017 at 7:49 AM
    #44
    Lilcarkid
    Lilcarkid Well-Known Member
    casey
    Ny/nj
    11 dcsb sport
    2 inch front and rear. 32" stt pro's 30.5 inch bumper led light bar Volant cai
    20160913_204152.jpgI did this with masking tape and a little hand held electric cut off wheel. Just keep your wiring tight on the back of the switch's. I shold have used flag terminals insted of straight push ons.
    fatfurious2 and ChadsPride like this.
  5. Jan 10, 2017 at 7:49 AM
    #45
    G.T.
    G.T.
    CONUS
    I'm sure you've seen the Australian options for inspiration and many of them have a small net on the side which if you place your radio correctly can act as a nice little storage spot for radio mic and their cables when not in use.
  6. Jan 10, 2017 at 7:50 AM
    #46
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Using this for later.
    ChadsPride likes this.
  7. Jan 10, 2017 at 7:51 AM
    #47
    Lilcarkid
    casey
    Ny/nj
    11 dcsb sport
  8. Jan 10, 2017 at 11:06 AM
    #48
    fatfurious2
    David
    Ashburn, VA
    I thought was @HomerTaco was trying to do, was make a CB mount where the sunglasses go o_O
  9. Jan 10, 2017 at 11:14 AM
    #49
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    But the lies the conundrum of where to put sun glasses
    Big Brutus, ChadsPride and Camel51 like this.
  10. Jan 10, 2017 at 11:24 AM
    #50
    fatfurious2
    David
    Ashburn, VA
    that is true! I actually use the sunglass holder, but I would put them somewhere else, if my CB was up there..
    ChadsPride and MSU Taco[QUOTED] like this.
  11. Jan 10, 2017 at 11:26 AM
    #51
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    I've almost never used them. I always put them on the visor until I got prescription glasses then I got transitions so I never have to swap glasses according to the lighting situation
    ChadsPride and fatfurious2 like this.
  12. Jan 10, 2017 at 11:34 AM
    #52
    Camel51
    Camel51 Well-Known Member
    Colorado
    2006 DCSB TRD-Offroad
    OME BP51's, Brute Force Fab
    I agree. They need a spot to go. Last resort Wet Okole seat covers have an option for glasses pouch on the side.
  13. Jan 10, 2017 at 11:37 AM
    #53
    fatfurious2
    David
    Ashburn, VA
    what about in front of the cup holders? or in the center console?
  14. Jan 10, 2017 at 11:37 AM
    #54
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    It's gotta be particularly bright for me to need them anyway. I have a layer of 30% with a 5% top strip. It was money well spent
  15. Jan 10, 2017 at 11:38 AM
    #55
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
    Solid choice. That's my trucks "junk drawer"
  16. Jan 10, 2017 at 11:45 AM
    #56
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Something like this but maybe not as radio aggressive would be nice. If it's shorter you could also accommodate Access cabs. ARB sells one for the FJ's that I've always wanted for my truck that looks like this.
    I think most folks want space for a radio and switches, but adding some overhead lighting and storage would be great too.
  17. Jan 10, 2017 at 11:50 AM
    #57
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    That's what she said.
    Have you thought about making a mount for gauges? Obviously a more limited market, but that would be a sweet alternative for those that don't want to use an a pillar mount or the steering wheel mount. Obviously would have to run more wiring, but up and out of the way would be nice.
  18. Jan 10, 2017 at 11:55 AM
    #58
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  19. Jan 10, 2017 at 12:02 PM
    #59
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Someone on here fit that console into a Tacoma. I'll see if I can find it. It needed some trimming to fit the contour of the Tacoma headliner, but turned out pretty good, wonder if you could cut the factory and this to blend the two together.
    ChadsPride, Camel51 and Iggy[QUOTED] like this.
  20. Jan 10, 2017 at 12:03 PM
    #60
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
