TPM idiot light on dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sgt.Tee, Jul 23, 2019.
  1. Jul 23, 2019 at 12:11 PM
    Sgt.Tee
    Sgt.Tee [OP] Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    i had my summer tires installed without the TPM. I read some where you can not swap to alloys from steal any way
    But the reason for this thread I still do not see any lights on my dash. I am riding without the TPM. Does it take some time for this to happen?
  2. Jul 23, 2019 at 12:13 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Mine light starts flashing after a day or so when I do the swap.
  3. Jul 23, 2019 at 12:14 PM
    Sgt.Tee
    Pete
    NE Pa
    Does it do it everyday? And then go out? Maybe I am missing the light?
  4. Jul 23, 2019 at 12:15 PM
    BINK05TRD
    Massachusetts
    Everyday.
    Your lucky now don’t jinx it.
    Sgt.Tee[OP] likes this.
  5. Jul 24, 2019 at 10:32 AM
    Sgt.Tee
    Pete
    NE Pa
    Too late, light came on today and I am sure the Toyota dealer reset something to make it visible. Lol
    How ever, I just turned over 1500 miles and the truck is running great. It is holding first gear much longer and I do not see 4K rpms any more.
    Maybe they did something to it on the recall,but no mention of it on the invoice
  6. Jul 24, 2019 at 10:48 AM
    hoch
    hoch Well-Known Member
    Desert
    18 DCSB OR 6MT
    I’ve read some were able to turn the sensor upside down to make it fit to steel rims. But since tire shops only charge few $ for them, I’d just get replacements.
  7. Jul 24, 2019 at 11:35 AM
    Sgt.Tee
    Pete
    NE Pa
    I just have them for my winter tires, which are mounted on the steel rims the truck came with. I don’t mind seeing a small yellow light and if it does start to bother me I will make a black dot to cover it, they also sell these dots just for this purpose, good luck to you
  8. Jul 25, 2019 at 10:51 AM
    Sgt.Tee
    Pete
    NE Pa
    I have to hit a button now to get my normal screen. The button below the up and down control to view your mileage you are getting etc.
    I guess I will have to do this every time I start the truck. I took care of the small yellow light on the cluster by putting a small piece of tape covering it, then I was surprised it comes up on the cluster where my speed limit is, thus Hitting that button to get back to normal screen. Maybe there is a way around this. This should be a option for the driver. No need to tell me my tires need air.
  9. Jul 25, 2019 at 11:17 AM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    Take your four original sensors, build a pvc heavy duty can and put them in there and pressurize the heavy duty can to 29 psi and throw the can in the truck somewhere. Its got to be sealed well though or you'll be airing it up all the time.
    Google this, "how to build a tpms canister".
  10. Jul 25, 2019 at 12:03 PM
    Sgt.Tee
    Pete
    NE Pa
    My originals are mounted on my winter tires with the Steele’s. I did here of this practice and once I burn the skins down on the winter tires I will consider this. Thanks
