tpms 2 broken valve stem sensors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bludweiaer, Jun 2, 2015.
  1. Jun 2, 2015 at 1:02 PM
    bludweiaer
    bludweiaer [OP] Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    so i had new nire put on my Pro last sat,, tire shop broke 2 sensors,, got 2 new ones from napa,, after they were installed my tpms light is on,,, the guy tried to reset it with there laptop with there software,, did not work,, told me to come back when there other guy was there cus he knew how to use the equipment better,, havnt been back yet.. the new tires have a lower pressure rating,, will i have to lower the spare tire pressure also before they attempt to reset the tpms , so the light goes out,, these systems are a pain in the ass,,,,,,,,will they be able to fix it without me going to the dealer ,,
  2. Jun 2, 2015 at 1:50 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Sounds like the tire shops problem so it is on their dime. I wouldn't worry about who fixes it as long as they fix it.
  3. Jun 2, 2015 at 2:02 PM
    Texas Aggie
    Texas Aggie Well-Known Member
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    King 2.5's Front and Rear 700# coil, 2" wheelers aal, 315/75R16 BFG KM3's Pelfreybilt Front and Rear Steel Bumpers, All Pro Sliders, 4.56 Gears
    No, you will not need to lower the tire pressure of your spare. Toyota's are a pain to reset the TPMS on! Easiest way is to use a code wiper that plugs into the obd port to wipe the TPMS readings. Then they scan all the sensors starting from the LF (left front) and going around the vehicle clockwise ending at the LR...then they plug their scanner into the obd port and write the ID's and locations to the vehicle. Then it's all done.
  4. Jun 2, 2015 at 4:31 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I hear the TPMS is no longer on the spares as of a few years ago. Maybe someone that knows for sure can chime in.
  5. Jun 2, 2015 at 5:02 PM
    Texas Aggie
    Michael
    TEXAS
    2013 SR5 4x4 Lifted
    Well mine doesn't have one, nor does my neighbors 2014. I can't think of ever having to reset a tacoma with a sensor in the spare.
  6. Jun 3, 2015 at 1:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I know that 2012 and up do not have a sensor in the spare. Why didn't the tire shop replace the TPMS, they broke it?
  7. Jun 3, 2015 at 2:02 AM
    bludweiaer
    pa
    i said they replaced them both in my post......
  8. Jun 3, 2015 at 4:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I misunderstood this part, it sounded like you purchased them from NAPA. I would have thought the tire shop would have them on hand.
