TPMS 2006
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006whitetacoma, Dec 4, 2019.
  1. Dec 4, 2019 at 6:38 AM
    2006whitetacoma
    2006whitetacoma [OP] Well-Known Member
    2006 White SR5
    A month ago I got new tires from a trusted shop. Yesterday morning on one of our coldest mornings so far I got into my truck and had a low tire warning. I checked all my tires and they were fine. In the afternoon I tried to reset it only to find that it won't go out.
    Does the spare have a sensor? What are the chances of a bad sensor?
  2. Dec 4, 2019 at 6:52 AM
    DG92071
    DG92071 Well-Known Member
    I've read the spare tire does have a sensor. My truck doesn't have that option.
  3. Dec 4, 2019 at 6:54 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    yeah, your spare will probably have a sensor
  4. Dec 4, 2019 at 8:15 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    If your sensors haven't been changed since new, the chances are at least one is faulty. Mine went out at about 6 or 7 years.
  5. Dec 4, 2019 at 8:23 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You can order Denso ones on Amazon for replacement.
  6. Dec 4, 2019 at 8:26 AM
    azreb
    azreb Geezer
    TN
    Or do like a lot of us and live with the light. Just check your tire pressures periodically.
    I decided to add an aftermarket TPMS to the truck--cheaper than new sensors.
  7. Dec 4, 2019 at 8:28 AM
    Muddinfun
    Muddinfun Well-Known Member
    Yes, you’re 2006 has sensor. They stopped putting a sensor in the spare sometime around 2010. I’m betting that you just need to add air to the spare. Hopefully someone has put it in the truck valve stem side down.
