Tpms accuracy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hipster dufus, Jan 27, 2021.
  1. Jan 27, 2021 at 5:45 AM
    hipster dufus
    hipster dufus [OP] Active Member
    2020tacoma DC
    How accurate are the tpms sensors? Im setting mt tires to the 32psi required measured w a pretty good gage. Im off by 3 lbs
  2. Jan 27, 2021 at 5:58 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    My dash matches my gauge exactly . I set mine on 33 the other week and dash had all 4 on 33 .
    You say you are off by 3 pounds it's the gauge that's off .
  3. Jan 27, 2021 at 6:00 AM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    Same here, mine match the gauge spot on when checked cold.
  4. Jan 27, 2021 at 6:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    How did you determine you have a 'pretty good gauge'?
    Cross check with a calibrated gauge?
    Or it's a pricey gauge, like Intercomp?
    tinker_troy likes this.
  5. Jan 27, 2021 at 6:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Don't have a gauge just a light but I'm not impressed with the accuracy. Have my winter tires/rims on with no sensors and in about 14 miles it informs me that all 4 tires are flat.
  6. Jan 27, 2021 at 6:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    You are giving it nothing to be accurate with.
    philth likes this.
  7. Jan 27, 2021 at 6:32 AM
    philth
    philth .
    Some of these threads/posts these days are so mind numbing that all I can do is burst out in laughter and move on.
    “Not impressed with accuracy”. No sensors. LMFAO.
    rlx02, calebc, 71tattooguy and 2 others like this.
  8. Jan 27, 2021 at 6:36 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Poor practice to check the "accuracy" of a gauge against a gauge with unknown accuracy.
    You don't know which one is correct or closer to correct......
    Best you can hope for is to have matching readings.
  9. Jan 27, 2021 at 6:38 AM
    Zoey'sTaco
    Zoey'sTaco Art Jockey
    Noah
    Dirty Jersey
    2020 DCSB SR5, Daily, camper-hauler, blizzard chaser, rock bouncer, tool box
    6112/5160/Maggie SC Hammer Hangers Tom Woods 1 piece Shaft ARE-DCU ARE HD leafs Rear Seat delete
    my gauge indicates 32lbs and my tpms readings hover from 36-40lbs. somebody's not telling me the truth
  10. Jan 27, 2021 at 6:41 AM
    Knute
    I'd suspect neither gauge is correct.
    Use which ever gauge you want to inflate the tires, set the TPMS system at that point. Then ignore the readings from the other gauge.
  11. Jan 27, 2021 at 6:50 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I had a dial gauge on my air line to show the regulated pressure. I discovered recently that it was off by 10 psi! Now I know why my air tools didn't seem to have the power that they used to have.
  12. Jan 27, 2021 at 7:00 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well do you think it might just be able to detect there is zero pressure/reading? So what makes it decide after 14 miles or so that there is no reading or no pressure? These things have batteries so they in and of
    themselves they are the transmitters to the in dash system. Mine does not report the location only that somewhere there is a low tire. I just kind of think it should report in a little more timely manner. Now to it's benefit if it is driven more often it does often throw a code quicker or on startup. I don't really care because this is the only vehicle I have ever had with sensors so my tire pressure gauge lives in the glove box and is used often by habit.
  13. Jan 27, 2021 at 7:01 AM
    Knute
    These mass produced cheap gauges have "accuracy" numbers all over the place.
    Don't expect more than about 5-10% full scale accuracy. In other words, a gauge with 50 psi max will have an accuracy +/- 2.5-5 psi. So, the gauge won't know the difference between 45 psi or 55 psi.
    To cook it down for a little more clarity.
    Assume you have a gauge with a 50 psi full scale reading with a +/- 5% accuracy. The error range is +/- 2.5 psi. So, at a tire pressure reading of 32 psi means the actual pressure in the tire is 29.5-34.5 psi.
    There are other parameters to measure gauge accuracy........such as Repeatability, hysteresis, non-linearity. But those discussions are moot for tire pressure gauges, but relevant for lab grade gauges.
  14. Jan 27, 2021 at 7:02 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Accurate enough to be of no concern. In other words, if you run on the recommended pressure stated on the door label, you maybe looking at .5psi accuracy deviation.
    If you run 100psi, its like 3psi, not something to get OCD over as psi will fluctuate along with air temperature anyway.
    Moreover, the typical tire gauge stem outside the tire, maybe pushing into different atmospheric conditions than the sensor that is inside the tire.
    Hope that helps
  15. Jan 27, 2021 at 7:07 AM
    Clearwater Bill
    Billy
    Largo Florida
    15 miles is the default used when the TPMS is reset.
    While you may not have hit the reset button, the system is 'looking' for a reading. Any reading.
    You aren't giving it any, so the light comes on.
    If sensors are changed and the reset process doesn't work (say it's done improperly) the same thing will happen.
  16. Jan 27, 2021 at 7:29 AM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Just pick up a gauge by a reputable company. That may mean it's a little more expensive, but it's one of those things that can be worth the extra dollars depending on the features.
    FWIW, I use a Viair pressure gauge and it works extremely well (ha what else would it do?) and it is spot on w/ the TPMS on my truck.
    https://www.amazon.com/VIAIR-00032-...ure+gauge&qid=1611761292&s=automotive&sr=1-10
  17. Jan 27, 2021 at 7:43 AM
    OvrlndBigAl
    OvrlndBigAl Well-Known Member
    Alex
    Some where in Idaho!
    Cement 2019 TRD OR DCSB
    Just a Snug Top with Sportsman’s package 1 inch lift and 265/75-16 Duratracs.
    My TPMS is spot on and most cars I work on are really accurate too. I use a liquid filled Longacre gauge and it’s accurate to .5 PSI. I’ve checked it against other gauges and I fill enough cars at work to know that it’s accurate. Unless you own anything that requires really high PSI then the best is to get a gauge that’s 0-60 PSI or so. You get better resolution or accuracy on the readings vs a gauge that reads over 80 that most people will never use. Also, I’m just not a fan of digital gauges. Lastly after I fill or remove air from the tire, I always pop the chuck off and on the valve stem to check the PSI 2-3 times and make sure it’s a consistent reading. I guess I’m just OCD.
  18. Jan 27, 2021 at 8:15 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    My analog gauge agrees with two others that I have. The dash numbers are about 7 or 8 pounds lower. Which am I to believe? BTW the tires wear evenly.
  19. Jan 27, 2021 at 8:29 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    A wise man said a man with one watch always knows the time. A man with two watches is unsure.
    Pick one gauge and trust it.
    tacoman45 likes this.
  20. Jan 27, 2021 at 9:26 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    According to my digital tire gauge, vs the one on the trucks dash, the dash gauge reads 1lb. high.
