TPMS and cold weather
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CemenTaco2019, Oct 24, 2019.
  1. Oct 24, 2019 at 2:49 PM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    I’ve experienced it many times in many models.
    It will go away when the tires warm up.
    Tonered has adequately explained this at least twice in this thread. Regardless, now watch this smolder over into Friday where it will become a full fledged dumpster fire.
    tonered and DWD484 like this.
  2. Oct 24, 2019 at 2:54 PM
    CemenTaco2019
    CemenTaco2019 [OP] Active Member
    2019 DCSB SR5
    None yet
    Yup. Tacomaworld. Flamethrowers and lack of patience mandatory...
    My question wasn’t about cold vs warm tires, I think we all get how that works. God knows there’s enough hot air in TW. Wanted to know if anyone experienced this and if it was normal or bad TPMS.
    tcjacado likes this.
  3. Oct 24, 2019 at 3:11 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    From the owners manual:
    When the tire pressure warning system is initialized, the current tire inflation pressure is set as the benchmark pressure.
    So if you had different pressures in your tires when the system was initialized (or reset) then you can see a warning for one tire and not another.
    In other words the TPMS system will give you a warning when the pressure drops a certain amount below the "benchmark pressure". I don't know what the drop is that causes the warning.
    tonered and mattehww like this.
  4. Oct 24, 2019 at 3:17 PM
    DanoT
    DanoT Well-Known Member
    Victoria, B.C in summer. Sun Peaks, B.C. in winter
    2019 TRD 4X4 AC OR 6M/T
    Another reason to move to Canada where TPMS is not mandatory and likely not even available as an option on some vehicles. Also, AC OR MT is only available in Canada, yet another reason I like living here.
  5. Oct 24, 2019 at 3:26 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Man, when I go off roading I love the TPMS to be able to keep an eye on air pressure when I'm aired down. Also 29 PSI isn't great for tire life or gas mileage on the road so it's literally doing its job and trying to save OP from other issues. Problems are pretty rare and usually easily and cheaply fixed.
    tcjacado, eurowner and tonered like this.
  6. Oct 24, 2019 at 3:30 PM
    mattehww
    mattehww Well-Known Member
    Minneapolis, MN
    2018 SR5 Access Cab 4x4
    This is the correct answer. Whatever the pressure was in each specific tire is what gets programmed into the system. So unless every single tire was at the same pressure when programmed, then it'll alarm at different levels when low.
    tonered likes this.
  7. Oct 24, 2019 at 3:33 PM
    CemenTaco2019
    2019 DCSB SR5
    None yet
    I don’t keep it at 29...that was the cold pressure after a thirty degree drop. Same tire was 34 this afternoon.
  8. Oct 24, 2019 at 3:40 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Just push the reset button and get on with your life.
    tonered likes this.
  9. Oct 24, 2019 at 3:40 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip: Gratzie!
    Stop it! :D
    There's another piece of internetz wisdom, sort of. One of the proper inflation tests besides chalk is the difference between cold inflation and warm while driving. I'm guessing that you are talking mainly about the afternoon temp in general. But as far as heat in a tire, a good pressure is usually about 10% higher, warmed up on your typical roads versus cold. A lot of riders swear by that.
    I do it the dumb way and just balance wear and feelz. :burp:
  10. Oct 24, 2019 at 3:46 PM
    CemenTaco2019
    2019 DCSB SR5
    None yet
    Thanks, I should give the chalk test a whirl.
    tcjacado and tonered[QUOTED] like this.
  11. Oct 24, 2019 at 4:19 PM
    tcjacado
    tcjacado Well-Known Member
    If air pressure wasn't important, nascar wouldn't worry about taking 1/2 pound out or add air on the right front to make it turn better.
    tonered[QUOTED] likes this.
  12. Oct 24, 2019 at 4:27 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    People do laugh at me, but I do like digi gauges that read tenths. Just because I like to be within 1psi cold. 0.5psi or more just doesn't work for me side to side.
    I built @Shellshock 's i deflator / inflator with a nice digi gauge. Damn nice esp with the valve clamp that he recommends.
    tcjacado[QUOTED] likes this.
  13. Oct 24, 2019 at 4:38 PM
    Shellshock
    Iowa
    people underestimate air pressure for sure. 5lbs can make a huge difference in every day driving
    on the trail, 15 psi vs 25 vs 35 psi can be the difference between a good day or a very bad day
  14. Oct 24, 2019 at 4:57 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true.
    :cheers:
