tpms and lugs for 17" sport rims
Discussion in 'Wheels & Tires' started by Rhody76, Mar 21, 2011.
  1. Mar 21, 2011 at 8:14 AM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    Hey guys,
    I'm about to buy some 17" sport rim with no tpms and no lugs. What's it going to cost me to buy this stuff? Can the tpms from my stock steel wheels be converted to work with the 17" alloys? Can my lug nuts be used with the new rims? Thanks
  2. Mar 21, 2011 at 8:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm assuming you have stock steel wheels? There have been mixed success/failure stories converting the steel wheel TPMS sensors to an alloy wheel. Some installers were able to twist them so they work. Another option would be to get wheel straps. It's a steel strap that goes around the inside of the wheel. Your TPMS sensor would get attached to that and you'd use standard valve stems for filling. Buying new sensors can be expensive and you'd have to reprogram your truck to read the new sensors (unless you have the tools to do so yourself).
    Not sure about the lugs, but I'd think the lugs are different from steel to alloy wheels. If you get a used factory set, you might be able to get the full set in the $50 range. New you'll get raped on the price. Check your local junk yards or keep your eyes open in the buy/sell/trade section.
    Edit: Here is a link to the straps I was talking about.
    http://www.revolutionsupply.com/steelstrap.aspx
  3. Mar 21, 2011 at 2:51 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    Wow those straps seem like a bitch. What if I didnt want to use the sensors at all? Would removing them cause any problems?
  4. Mar 21, 2011 at 3:54 PM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    your warning light would stay on and the shops may not want to install the tires without the sensors.
  5. Mar 22, 2011 at 3:35 PM
    Rhody76
    Rhode Island
    2011 SR5 DCLB 4x4
    What about the factory lug nuts from my stock steel wheels? Will they work with 17" sport rims?
  6. Mar 22, 2011 at 8:28 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Are they shank and washer:
    Or conical seat?
    Sport rims take shank and washer.
  7. Mar 22, 2011 at 8:32 PM
    azntha1one
    azntha1one Well-Known Member
    Sean
    Long Beach
    06 Prerunner
    A few
    steels come with tmps with 20 degree offset
    alloy come with tmps with 40 degree offset
    you need different lugs for the alloys.
