TPMS Batteries on the way out '06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cmoore, Mar 4, 2020.
  1. Mar 4, 2020 at 3:26 AM
    cmoore
    cmoore [OP] Well-Known Member
    Charlie
    Dallas, Texas
    PreRunner
    On my way back from Tulsa yesterday my TPMS light started blinking. I stopped and checked my tires and they were all good. Tire pressures were fine when I got home so I guess I have one or more sensors with low batteries. Any idea what the cost is to have all the sensors replaced?
  2. Mar 4, 2020 at 3:35 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Too dang much! :D
  3. Mar 4, 2020 at 3:49 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I don’t know what they charge but I would just go to discount tire. That way if something happens a month later, you just go back and they fix it.
  4. Mar 4, 2020 at 4:35 AM
    cmoore
    Charlie
    Dallas, Texas
    PreRunner
    Yea, I was poking around on the website at Discount Tire. I'll give them a call.
  5. Mar 4, 2020 at 4:59 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    When I got my new tires and rims, I kept my old rims and tires mounted with the TPMS intact, so I had to buy new sensors. I purchased 4 AC Delco TPMS for $22 a piece and Costco programmed them when they installed the new tires. No problems as of yet, knock on wood, I had them installed back in January.
  6. Mar 4, 2020 at 10:45 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Have a link ?
  7. Mar 4, 2020 at 11:04 AM
    Micbt25
    TM
    REDdawn6[QUOTED] likes this.
  8. Mar 4, 2020 at 11:59 AM
    photoguy
    photoguy Well-Known Member
    08 Tacoma TRD
    I bought a set of 4 new Toyota/Lexus sensors on eBay recently for $60. I was replacing tires and the shop installed them and made sure that they were working. Other than the need to break down the tire from the wheel to access them, installation is pretty simple and quick....actually they just need to break the bead so that they can reach inside the tire.
    https://www.ebay.com/itm/4X-Genuine-TIRE-PRESSURE-SENSOR-TPMS-For-Scion-Toyota-Lexus-42607-33021-PMV-107J/392569526471?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
    TACOMA2NDGEN and REDdawn6 like this.
  9. Mar 4, 2020 at 12:43 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    FYI
    Discount charge in FL for me was 60 per sensor installed and loaded in ECU.
    7 year warranty. I get tires there and they have a road force balance.
  10. Mar 4, 2020 at 1:48 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can buy 4 for under $90. If you're in need of new tires soon just wait until then and any tire store will install them free when they mount tires. If you don't want to wait figure about $40-$50 for instillation for all of them.
    https://www.amazon.com/MOBILETRON-M...37------------&vehicleName=2006+Toyota+Tacoma
    Around 10 years is typical, you got lucky getting 14 years out of a set. The ones in my 07 are still good, but I'll buy new sensors before I buy my next set of tires and have them ready to install even if they don't fail before.
  11. Mar 4, 2020 at 2:23 PM
    gr8t_white_taco
    gr8t_white_taco Well-Known Member
    Ethan
    2015 Tacoma TRD Off Road
    Stage 9 Icon suspension, full CBI aluminum armor and skids, prinsu roof rack, vtx wheels, dorkel, etc...
    Funny, it never crossed my mind that these have batteries... duh.. That's pretty decent though, 14ish years.
  12. Mar 4, 2020 at 2:44 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Mine died a few months ago. Tossed them, deleted the TPMS and never looked back. Never was fond of such a useless feature!
  13. Mar 4, 2020 at 2:54 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    With all due respect the number of people who think this is useless blows my mind. How can you possibly say this? Even if you're checking your tires every morning, which you're not, you can't know nearly as much about them without this feature as you can with this feature. And it's ridiculously cheap for what you're getting.
  14. Mar 4, 2020 at 3:51 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Had a issue on my wife’s 08 CRV three years ago. One was out so I bought 4 Honda ones on Amazon for like 100.
  15. Mar 4, 2020 at 3:53 PM
    ARB1977
    North Texas
    There not useless. Granted most of us check our pressures or at least I do every month or before a trip.
    six5crèéd likes this.
  16. Mar 5, 2020 at 3:25 AM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    I wonder how many people actually check their tire pressure? I’d say most don’t.
  17. Mar 5, 2020 at 3:36 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    Just a FYI...... Denso supplies Toyota with the TPM sensors and Pacific Industries actually manufactures them for Denso.....
    Note - The sensors for alloy wheels are different than the steel wheels....
    Torspd likes this.
  18. Mar 5, 2020 at 3:46 AM
    cmoore
    Charlie
    Dallas, Texas
    PreRunner
    Thanks for all the information. Discount tire quoted me $80.00 per wheel installed. When I fired up the truck after work yesterday the blinking tire pressure light stopped. I guess the system started communicating again so I'm going to let it ride and see what happens.
  19. Mar 5, 2020 at 4:04 AM
    spitdog
    Ouch! I guess the time to replace them is when you buy tires. You could probably get a better deal. 2 birds with one stone as they say.
    REDdawn6 and EdgemanVA like this.
  20. Mar 5, 2020 at 5:44 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Two sets of tires back, Costco asked if I wanted the batteries replaced when I did the tire install. Of course I said yes. They didn't mention replacing the TPMS batteries when I bought my current tires last year, so I asked about replacing them and why they didn't ask. The guy told me they just do it automatically now, and the price of the batteries are already included in the price of the tires/installation.
    Yeah, Costco will remain my "go to" tire store!
    spitdog[QUOTED] likes this.
