TPMS Battery Died After Tire Change? Meineke Screwing Me?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by octrockville, May 13, 2020.
  1. May 15, 2020 at 8:20 AM
    #61
    Tacoma-toy
    Tacoma-toy Master Auto/ASE Tech
    Danny
    Michigan
    2017 Tacom Pro cement
    rock lights, BFG's, Overhead console USB port
    They just don't know what their doing or they done want to pay for a sensor. If you were at my shop I would tell you exactly what was needed at no charge, It's just good business. That's how you know you found a good honest shop, I hope you find someone that can tell you what's wrong.
  2. May 15, 2020 at 8:21 AM
    #62
    Scott W
    Scott W Well-Known Member
    Scott
    Saranac Lake, NY
    2018 Tacoma TRD PRO. Calvary Blue.
    TRD Performance Air Intake. TRD Shift Knob. KTJO 4X4 Red TRD Push Button Start/Stop. Calvary Blue FOBIK by AJT Design. 12volt Solutions Remote Start with CAR:LINK Smartphone Remote Start and GPS app. Sprint Booster V3 Throttle Response Enhancer. AFE Silver Bullet Throttle Body Spacer 46-38010. 2" Supreme Suspension Lift Kit. TOYO 265/75R16 Open Country A/T2. EGR Matte Black In-Channel Vent Visors. REK GEN Offroad Mud Guards. AMP RESEARCH Power Steps. JDMastar 10000lumes LED Low Beam Lighting T1. JD Mastar Raptor LED Lighting. TRUXEDO Tonneau Cover.
    Good luck
  3. May 15, 2020 at 8:22 AM
    #63
    Tacoma-toy
    Danny
    Michigan
    This is how it should be handled, not giving excuses and just taking care of the customer. (not to say the customer's always right)o_O
  4. May 15, 2020 at 8:22 AM
    #64
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    It's not that hard to break the bead yourself, and inspect the TPMS. There is no dismounting required, that can mess up the balancing.
  5. May 15, 2020 at 8:26 AM
    #65
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    First thing they teach you is to Mark the tire and rim while breaking bead to prevent changing balance
    octrockville[OP] likes this.
  6. May 15, 2020 at 8:26 AM
    #66
    Muddinfun
    Muddinfun Well-Known Member
    The fact that it’s 2 sensors, I think you’re pretty safe. The sensors were fine before the tire swap. The chance of them damaging 2 sensors with no visible signs of damage is winning lottery type of odds.
  7. May 15, 2020 at 8:32 AM
    #67
    Muddinfun
    The bigger issue is, if they couldn’t communicate with the TPMS, how do they expect to program the new sensors?
    b_r_o and octrockville[OP] like this.
  8. May 15, 2020 at 8:38 AM
    #68
    octrockville
    octrockville [OP] Well-Known Member
    Dave
    Monroe, CT
    2010 Regular Cab 4x4 4cyl Pyrite Mica
    They said they can program new ones. Not sure why they couldn’t read the module but they can program new sensors. If they CAN’T program a sensor then back to the dealer I go and they’ll have to reimburse me.
    Muddinfun[QUOTED] likes this.
  9. May 15, 2020 at 8:52 AM
    #69
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
  10. May 15, 2020 at 9:15 AM
    #70
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    you're overthinking this, if they aren't visually broken then meineke didn't break them
    They're either broken (like cracked or broken off) or the batteries are dead. There really isnt any other way for a sensor to fail.
  11. May 15, 2020 at 11:11 AM
    #71
    M4sshole
    M4sshole Well-Known Member
    Evil
    Marshfield MA
    2019 Tacoma Limited
    Time is money and for what you may have saved here you have certainly given back and then some with your efforts. I hope this ends well for you but either way, you have had to spent a lot of unnecessary time, thought and energy on this.
  12. May 15, 2020 at 11:26 AM
    #72
    octrockville
    Dave
    Monroe, CT
    Oh don’t get me wrong, if I can go back in time I would go to a place that specializes in tires. But this is the situation I put myself in and I am dealing with it without getting charged.
    But as far as the effort and time being equal to actual money, for me that doesn’t equate. I also am learning from this mistake so what I’m putting in in effort I’m getting back in knowledge.
  13. May 15, 2020 at 11:32 AM
    #73
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    yea. dont sweat it too much. i ended up letting Costco install five new sensors in my truck..and that place specializes in $1.50 hotdogs, gallon ketchup cans, and flavorless rotisserie chickens. all ended well.
  14. May 15, 2020 at 7:50 PM
    #74
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Why not replace all 4?
  15. May 15, 2020 at 7:56 PM
    #75
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    The batteries in the sensors only have a 6-10 year life span. And yes, when you deflate the tires it causes the sensor to “activate” and will use up battery life. It is common for something like this to happen. In fact, the very same thing happened to one of my customers with a 2012 Camry just 2 days ago.
    -Stephen F.
    -Assistant Manager, Discount Tire Company TXA03.
    Skyway likes this.
  16. May 16, 2020 at 4:16 AM
    #76
    octrockville
    Dave
    Monroe, CT
    Because it’s an unnecessary expense.
  17. May 16, 2020 at 4:20 AM
    #77
    octrockville
    Dave
    Monroe, CT
    Interesting that the three dealers I called haven’t heard of this. Hope it’s not the case but we’ll see in a few hours! I can see how this would be possible as it’s constantly sensing psi but only broadcasting the signal when there’s a problem.
    edit: let me revise it a bit. I COULD see how this might be possible but I don’t know if these sensors are engineered that way.
  18. May 16, 2020 at 4:27 AM
    #78
    Th6nh
    Th6nh Let's taco bout it
    SoCal
    2020 4x4 Tacoma TRD OR
    I had sensor sitting there for couple months and the battery never died...
  19. May 16, 2020 at 7:12 AM
    #79
    octrockville
    Dave
    Monroe, CT
    Ok so here it is. Sensors are not damaged. I’m at Meineke now and we just popped open the tires. He was able to get a reading on all 4 sensors now that he can actually touch his snapon tool to the sensors. Weird thing is, the dealer said the front left and right rear were not reading. But now at Meineke it’s saying that both front sensors have low batteries and both rears are fine and communicating normally. It would cost around $500 to replace them all and I’m not going to do it. I’m either going to ignore the light or disable it. Of course Meineke is not responsible for covering any costs.
    BigWhiteTRD likes this.
  20. May 16, 2020 at 8:19 AM
    #80
    octrockville
    Dave
    Monroe, CT
    Thanks for all the help guys. Funny thing though, as I left my passenger airbag light came on...haha. Turned out I have my trailer ball under the seat and when they moved the seat back to bring the car in the garage (I’m short) it must have disconnected the plug. I took it off and plugged it back in and we’re good to go.
    Done with this for the time being, but now I might make a post about my transmission noise...ugh.
