TPMS DIED at age 9 (almost)!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by David K, Oct 12, 2018.
  1. Oct 12, 2018 at 6:08 PM
    David K
    David K [OP] Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I seriously tried to search to add my findings to an existing thread... but for now, let just report that my 2010 Tacoma (purchased in December 2009 or 8 years and 10 months ago) with 116,000 miles on it just had the first TPMS unit die (the light came on and all my tires had 34 psi, per normal).
    Went to Discount Tire where they have a device that reads the TPMS and 3 gave the tire pressure and one gave an X. So it is either a dead battery or the unit failed (was on the front right tire).. they said this is typical that they die between 7 and 10 years. You can't replace the battery, you just replace the unit... $64!
    I have three more to look forward to!
    I was just curious how many other 2nd Gen Tacomas have had to replace their TPMS and what was the truck's age when their's failed... ???
    Please give me a link if there is another thread for this and I will repost there.
    Thanks!
    GHOST SHIP and Biscuits like this.
  2. Oct 12, 2018 at 6:44 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Why can’t you just check your tire pressure with a gauge?
  3. Oct 12, 2018 at 7:05 PM
    Hunter4950
    Hunter4950 Well-Known Member
    Lol that might work
    Biscuits likes this.
  4. Oct 12, 2018 at 7:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I would recommend replacing all 4 as a set. If 1 battery went bad then the other 3 are probably not far behind.
  5. Oct 12, 2018 at 7:39 PM
    perryp
    perryp Well-Known Member
    Perry
    Great White North
    2013 TRD Off Road
  6. Oct 12, 2018 at 8:02 PM
    1cleanFG
    1cleanFG DialsGarage
    DialsGarage
    PNW
    2023 Sport 4x4 DCLB
    Toytec Alumaseries Coilovers OME El111R Camburg UCAs Scs sr8 17” 285/70/17 KO2
    Yup, 8-10 years is about right for those TPMS batteries. I wrenched for Toyota for about 7 years. Completely normal.
    David K[OP] and whatstcp like this.
  7. Oct 12, 2018 at 10:22 PM
    Concrete_cowboy
    Concrete_cowboy Member
    Tom
    Durango, CO
    2009 4x4 v-6 taco w/ trd offroad & supercharger
    Cobra CB radio with hood mounted antenna (CBI offroad fab bracket with firestik whip)
    Or kick the tire!
    Mr.Franko and Armed in Utah like this.
  8. Oct 12, 2018 at 10:25 PM
    Concrete_cowboy
    Tom
    Durango, CO
    I'm fixing to put snow tires on separate rims and I got 4 OEM TPMS sensors for my taco for just 140 total from www.tpms.com
    Biscuits and whatstcp[QUOTED] like this.
  9. Oct 13, 2018 at 4:51 AM
    Markcal
    Markcal Well-Known Member
    I have the original TPMS monitors with my Tacoma just turning 12 years old. They aren't required to pass inspection in my state, so I plan to use electrical tape over the light for my repair. I figured I got through 18 years without them on my last truck so I don't feel the money spent to replace them is justified IMO.
    1cleanFG likes this.
  10. Oct 13, 2018 at 5:21 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Can you do that while driving 70 mph? The TPMS isn't meant to replace a tire gauge, but to warn you of a sudden loss of air pressure while driving.
    I know they can be a PITA, but the principle is a good one. In 2011 I was driving on an interstate hwy at 75 mph when my light came on. I pulled over ASAP and within 30 seconds of the light coming on my right rear was completely flat. I'd hit something in the road that punched a 1/2" hole in the tire. Without the TPMS I'd have had a blowout at 75. That could have been bad. THAT is what the system is designed to do.
    My only complaint is that replacement sensors are more costly than I think they should be. It is possible to find aftermarket sensors in the $40-$50 range if you look around. I had to replace a set on a Jeep a few years ago and went that way.
    So far my 2007's sensors are still working. Mine has one in the spare tire and if it gets low will trigger the system even though the 4 on the ground are fine.
    Blais03 and tAcomaPueblo like this.
  11. Oct 13, 2018 at 5:32 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    I'm really considering my next tire/wheel pkg......next month......
    ditching the sensors.....I have more than one tire gauge.......
  12. Oct 13, 2018 at 6:48 AM
    drjaxvstrom
    drjaxvstrom Well-Known Member
    Jack
    Rutland county Vt.
    '06 Tacoma XtraCab 4x4 MGM
    Rims & tires, cheap leer cap, Jeep YJ Rear bumper
    This is a topic I have discussed with the dealership ...".the system " as they call it isn't perfect. That was the reply in 2008 when Both left side sensors went bad...at 143.00 apiece to replacein 2010 the dealership dammaged the Right rear one.. changing the snow tires over and at Vt. state inspection time...another 118.00 .... 2016 and three of the four died....
    Nope, no more sensors... Tire gauge..
    Armed in Utah likes this.
  13. Oct 13, 2018 at 6:56 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    You can buy the correct Denso sensors on Amazon for $34 each. Discount will install and program them free if you pay for tire remount and balancing. Just did that last month.
    OneFastGeek and PzTank like this.
  14. Oct 13, 2018 at 7:14 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Some states like NH require all installed equipment to be working in order to pass inspection...
    OP, I had my TPMS sensors replaced at about 10 years with 290,000 miles on it. I think I paid about $30 or so each, aftermarket from a chain up here Town Faire Tire... They said the sensors were one of the most common used so I'd shop around for the best price...
  15. Oct 13, 2018 at 9:15 AM
    David K
    Good morning! Wow, I guess this was in need of being a new thread?
    OK, first off, I do use a precision tire gauge... the TPMS in my 2010 does not report to the dashboard the tire pressure (that would be cool)... it only warns you of lower than normal pressure. There is not one on the spare. The TPMS is valuable because it alerts you when your tire is going flat BEFORE it is not drivable. This gives you time to find a safe place to pull over. I actually was able to plug a hole before the tire was flat... and I keep an MV-50 air pump with me to add air back in, quickly.
    TacomaMike37 likes this.
  16. Oct 13, 2018 at 9:43 AM
    David K
    At $64 each, installed, doing just one at a time is fine with me.
    Yes, I see that I can buy them for $30 but that does not put them in the wheels and then tune the frequency to match the truck.
    Is Discount Tires charging too much to do this? Any other options in North San Diego County, CA?
  17. Oct 13, 2018 at 9:44 AM
    Bebop
    Nick
    Well it’s usually a 500 dollar or more tool they use to program the sensors. So sounds like you are coming out ahead
    David K[QUOTED][OP] likes this.
  18. Oct 13, 2018 at 10:03 AM
    perryp
    Perry
    Great White North
    2013 TRD Off Road
    Or you can order this online ....
    https://www.ebay.com/itm/Mini-VCI-J...h=item41f0041934:g:lNoAAOSwcWtbuke1:rk:7:pf:0
    Get a large C clamp , remove the tire valve, empty tire of air,...compress with a C clamp,....remove old tpms with a 7/16 deep socket...
    reinstall new sensor,...inflate tire...
    Get a cheapy laptop with windows xp or 7 (even 10 will work)....
    Load Techstream (the Toyota miracle software)...
    Here is the software (available, and Legal ) from Toyota...
    https://techinfo.toyota.com/techInf..._CA&resource_url=https://techinfo.toyota.com/
    And reprogram your truck for under $100,....including sensors, software, laptop etc!...
    Toyota don't give a shit about protecting their dealers anymore...
    The software is almost open source (almost free if you look a little on the internet)...
    https://cartechnology.co.uk/showthread.php?tid=38078
    Those intending to install winter tires on different rims can now get my point...VERY CLEARLY...
    Be creative...
    Biscuits and drjaxvstrom like this.
  19. Oct 14, 2018 at 10:13 AM
    Armed in Utah
    2003 Lexus LX 470
    Utah dropped their annual safety inspection last year.......
    remember that when you're driving down I-15 at 75 mph.......
    next to some piece of schidt vehicle..........
  20. Oct 15, 2018 at 9:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This is what I did.
    I previously had bypassed the system after having one sensor die. "I can check my own damn tire pressure", I said.
    After having two flat tires on my work vehicle and having the TPMS alert me while there was still time to exit the freeway and find a comfy place to put the spare on, I decided to fix my personal vehicle.
    I have in my maintenance log the whole deal cost me $285. I have 5 sensors total, including spare tire.
    Truck was 11 years and 85K miles.
    David K[OP] and b_r_o like this.
