TPMS - effects anything else
Discussion in 'Wheels & Tires' started by Bizarroterl, Dec 10, 2009.
  1. Dec 10, 2009 at 8:26 AM
    Bizarroterl
    Bizarroterl [OP] Well-Known Member
    SJ, CA, USA
    2009 Accesscab 4cyl 2wd, 2010 Xrunner
    DJM 3/3, Hellwig rear sway, Rear Spoiler, Truck Covers USA tonneau, rear spoiler. Dynolock tailgate electric lock. Pioneer avic-z110bt. Xrunner is stock for now
    I replaced my steelies with some aluminum wheels. No TPMS sensors were installed. Now my TPMS light is lit.
    Does this affect anything else in the truck? Traction control?
    I'm not concerned about the light (I can fix that) and I'm not going to spend >$200 on new sensors.
  2. Dec 10, 2009 at 11:26 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It's just the light that it triggers. No worries elsewhere.
  3. Dec 10, 2009 at 11:28 AM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    Nothing to worry about. There is like 100 threads that explain it all. Good Question!
  4. Dec 10, 2009 at 11:28 AM
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    What he said.
  5. Dec 10, 2009 at 12:58 PM
    Bizarroterl
    SJ, CA, USA
    I did do a search and there's a lot of stuff about how to disable the light and complaints. I wasn't able to find anything about if/how it could effect other systems though.
  6. Dec 10, 2009 at 4:37 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    About this subject,
    I went to get my smog done here in California, and the mechanic said: if the TPMS aren't there it won't pass smog.
    I have no idea how accurate the guy was, or how much sheet he eat.
    Take care
    vbibi:(
  7. Dec 11, 2009 at 2:58 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Do you still have the sensors? You know you can use the ones from the steel wheels on aluminum wheels, right?
  8. Dec 11, 2009 at 2:24 PM
    jeremiekc
    Jeremie
    Vilseck, Germany
    Some one spent a little to long smoking the crack pipe. The TPMS system has absolutely nothing to do with any other system.
  9. Dec 11, 2009 at 3:37 PM
    spp
    spp OC, Kalifornia
    OC California
    They do check saftey stuff at the same time I think.
  10. Dec 11, 2009 at 3:57 PM
    Bizarroterl
    SJ, CA, USA
    From what I've read they're not compatible. The steelies are 20deg and aluminum wheels are 40deg. The 20s won't fit on aluminum wheels. I suppose there are exceptions.
    Either way, it doesn't matter. The original wheels are sold and long gone.
  11. Dec 12, 2009 at 2:47 AM
    jeremiekc
    Jeremie
    Vilseck, Germany
  12. Dec 12, 2009 at 3:35 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The effects of the removal of the TPMS will only affect yourself with the annoyance of the dashlight being lit everytime you drive.
  13. Dec 12, 2009 at 4:23 AM
    FoxySandChick
    Kristin
    Henderson, NV
    Yes they are different, but they still work. I've had mine from the steels on alloys for over a year now with no problems and so have many others.
    But now you know.
