SOLVED....TPMS goes off ONLY WHEN HEADED OUT TO ADVENTURE.. WTF??!?Help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GoodDogRUGER, Nov 7, 2021.
  1. Nov 7, 2021 at 5:55 PM
    GoodDogRUGER
    GoodDogRUGER [OP] 2021 SR ACCESS V6 4x4
    Heath
    SOCAL
    2021 SR Access Cab V6 4x4
    6112/5160, 285/75/17 BFG KO2 , SPC, Method 703s, BMC/CMC, ARE DCU,
    I have 5 Methods with sensors in all wheels. Spare is on a swing out. All is great until I load up to go on an adventure. Once I leave and am just down the road a few miles the check tpms system warning and light comes on. Drove for weeks and weeks with no problem. Load up to head to Moab and stupid light and warning comes on the whole trip. Get back, unload, wash it, clean it out etc and light and warning go away and all is well again. Works fine for a few weeks. Until I just loaded up for a camping trip and took off. TPMS comes back on a couple miles down the road. WTF? Seems weight related but how/why could that be? Maybe the stuff in the bed is blocking the signal?? Where is such a thing?? Anyone have any ideas? I am pretty sure it's going to go out in a day or two since I am just driving back and forth to work now. Next trip and it will come on for sure. HELP!
    SOLVED.
    Big thanks for those who tried to help me!
    Someone guessed pretty darn close.
    When I had to pull the headliner out so I could install (drill 12 freaking holes in my roof) my roof rack I saw the receiver box for the keyless entry AND the TPMS. Someone at some point mentioned it might be under there... Well it was. It is in the back left, about 10 inches in from the side, very near the back wall. This happens to be VERY near where I place my magnetic mount HAM radio antenna. Until now, I only set up my radio when I went out on a big adventure. In hind sight, this seems kinda obvious, but it didnt even cross my mind. Once I saw the box there, the big ding sound went off. No issues since getting rid of the magnetic mount and going hard mount to the roof rack. Have had a full load out, and broadcasted on the radio and error stays at bay. Fingers crossed but this sure seems like the issue is solved.
    Charvonia Design and Travlr like this.
  2. Nov 7, 2021 at 5:58 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    U sure it's the tpms and not something else?
  3. Nov 7, 2021 at 6:02 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Ignore the TPMS. :notsure:
    Woodini likes this.
  4. Nov 7, 2021 at 6:03 PM
    Woodini
    Woodini Well-Known Member
    Ray
    Daytona Beach Shores
    89 Pickup 22RE 4wd
    LCE i/h/e OME susp (install soon) 17” fn counter steer, gonna buy new rubber
    Use an old fashioned gauge and go?
    kgilly, DAS Taco and SR-71A like this.
  5. Nov 7, 2021 at 6:05 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Does it show it to be the spare? This is likely the answer. The receiver is, I think, under the headliner.
    I'd just ignore it.
    Man I'm glad my truck didn't come with any TPMS. No lights, no problems.
  6. Nov 7, 2021 at 6:07 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Works fine with 4 wheels on the truck?
    Gets screwed up with 5 wheels on the truck?
    The 3rd Gen cannot read 5 sensors at one time, only 4.
    whatstcp, SR-71A and ktbell444 like this.
  7. Nov 8, 2021 at 12:08 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Op, can you give a little more info? Is the display telling you that one or more tires are low? Is the display showing you the pressures of all of your tires?
    Also:
    The system is disabled under the following conditions (when the condition returns to normal, the system will work properly).
    1. When all of the tire and wheel assemblies that have tire pressure warning valve and transmitters registered with the tire pressure warning ECU and receiver have not been installed.
    2. When all of the transmitter ID codes are not registered with the tire pressure warning ECU and receiver.
    3. When the tire pressure is abnormally high (absolute pressure: 480 kPa (4.9 kgf/cm2, 70 psi) or more; relative pressure: 380 kPa (3.9 kgf/cm2, 55 psi) or more).
    4. When the tire pressure warning valve and transmitter battery is depleted.
    The system may become disabled under the following conditions (when the condition returns to normal, the system will work properly).
    1. When electric devices or facilities using similar radio frequencies are nearby.
    2. When a wireless device or other equipment operating at a similar frequency is in use in the vehicle.
    3. When a window tint that affects radio wave signals is installed.
    4. When there is a lot of snow or ice on the vehicle, in particular, around the wheels or wheel housing.
    5. When non-genuine wheels are used.
    6. When tire chains are used.
    7. When aftermarket tire repair sealant is used.
    • CAUTION: After use of tire repair sealant, replacement of the tire pressure warning valve and transmitter is required to ensure normal system operation. (Normal system operation cannot be ensured by only repairing or replacing the tire.)
    eurowner[QUOTED] and SR-71A like this.
  8. Nov 8, 2021 at 6:30 AM
    GoodDogRUGER
    Heath
    SOCAL
    Umm... Like what?
  9. Nov 8, 2021 at 6:32 AM
    GoodDogRUGER
    Heath
    SOCAL
    Would love to do this, but it is a huge display message that you have to acknowledge every time you start the truck. Then a blinking idiot light for a few min. Then a solid orange idiot light. Hate it.
  10. Nov 8, 2021 at 6:33 AM
    GoodDogRUGER
    Heath
    SOCAL
    Works with all five... I do understand it only can read 4, but it normally works fine with all five.
  11. Nov 8, 2021 at 6:34 AM
    GoodDogRUGER
    Heath
    SOCAL
    Would love to ignore it. Toyota made it too annoying to ignore...
    Receiver under the headliner?? I didnt know where it was. That is a hint maybe...
  12. Nov 8, 2021 at 6:35 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Have you tried switching the display to the tpms display with each tire’s pressure? What’s it say?
    kgilly likes this.
  13. Nov 8, 2021 at 6:35 AM
    GoodDogRUGER
    Heath
    SOCAL
    I am a bit insane when it comes to wanting all my tire pressures even. I always have a quality 0-60 dial gauge in my glove box and in my garage.
  14. Nov 8, 2021 at 6:40 AM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Tpms solid light only comes on after 30min of driving with no communication from the sensors.
    I run non tpms winters, truck is fine around town and parked in front of the garage where the summer wheels are stored. 30min out of town the light comes on solid. Stays on until I get back to the tpms wheels.
  15. Nov 8, 2021 at 6:41 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Well.. if it can only read 4, it does NOT work with all 5...
    Just a guess, but possibly the truck randomly 'picked' 4 sensors to read, one of which was your spare. When you load up the truck possibly theres just enough camping gear between the spare and the receiver where it looses connection with the spare.
  16. Nov 8, 2021 at 6:44 AM
    GoodDogRUGER
    Heath
    SOCAL
  17. Nov 8, 2021 at 6:45 AM
    GoodDogRUGER
    Heath
    SOCAL
    Cant... SR model. I would love to do that. Someone mentioned in another thread when I was searching for info on this that the toyota app on your phone would show all pressures even though it a SR. I cant see where to read the pressure and I sure tried hard.
  18. Nov 8, 2021 at 6:51 AM
    Grindstone
    Grindstone Requires Adult Supervision
    Check your PSI when 'normal' (no TPMS light) and check the next time you load up and the light comes on. My TPMS doesn't come on until I lower it to 24-25 PSI. I normally keep them at 35-40. I've loaded over 1k pounds in the bed, no TPMS issue.
    Probably your aftermarket wheels causing the issue.
  19. Nov 8, 2021 at 7:25 AM
    eurowner
    eurowner Duke Sky
    Scoty
    You are experiencing exactly what the 3rd Gen TPMS does when there are 5 sensors. It “crashes” seeing the 5th sensor.
    SR-71A likes this.
  20. Nov 8, 2021 at 7:28 AM
    GoodDogRUGER
    Heath
    SOCAL
    The very much less than random nature of this makes me think what you are saying is incorrect. However, I sure do hope you are correct. I guess I will have to pull the sensor from the spare and see what happens. Thanks for what sounds like a confident answer on this issue.
