Tpms has anyone upgraded
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myth01, Feb 9, 2012.
  1. Feb 9, 2012 at 5:24 PM
    myth01
    myth01 [OP] Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
    Has anyone upgraded their Tpms system to a real time pressure display system?
  2. Feb 9, 2012 at 5:26 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    I want to disable my TPMS for good.
  3. Feb 9, 2012 at 5:31 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Not me, I think the TPMS is a pain in the ass.
    My light comes on all the time. It's been on for a year now. Got tired of resetting it.
    I can set the pressures in all tires and it comes back with in a month.
    Recheck the pressure and it is still the same.
    Some one said it might be the spare tire. Who knows.
    I give up.
  4. Feb 9, 2012 at 5:32 PM
    Noslow100
    Noslow100 Well-Known Member
    Josh
    VA
    08 SR5 4x4
    Toytec 3 Inch lift kit with Bilstein 5100's, and more
    Indeed mine is a pita. I have just learned to ignore the tpms light.
  5. Feb 9, 2012 at 5:34 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    its sucks because with my 16x8 and 315's i need to be at 18-20 psi to not wear the tires shitty and the fucking light bothers the hell out of me. if i ever take the cluster out either i will remove the bulb of electric tape it
  6. Feb 9, 2012 at 7:24 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    Ok here is a little info. First your spare is monitored as well, add air and your light should go out. If you need to change running pressure, there is a pressure set button below the steering wheel. Set your tire pressure turn key to on but not the engine, hold the set button do I think ten seconds and that should do it. I'm looking for active pressure read out, like a number display
  7. Feb 10, 2012 at 6:56 AM
    myth01
    south sf, ca.
    08 taco Trd sport
    Nobody?
  8. Feb 10, 2012 at 7:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm pretty sure most people are aware of how to reset the light. The issue becomes going to aftermarket wheels and the TPMS not being compatible. The only way to get the light to turn off then is to remove the LED or create a pressure vessel in the cab and keep the TPMS in them (like a wheel barrel tire).
    Also, not all the Tacomas have a sensor in the spare, only through 2009 I believe.
  9. Feb 10, 2012 at 7:15 AM
    stockplus
    stockplus Well-Known Member
    L.J.
    Way way north of Redding
    06 4x4 SR5 Access Cab
    TC, ToyTec, Boztec, All-Pro, ATO
    I ran the Orange TPMS system for about 2 years. It worked relatively well, and the display was nice. The only problem I had was that between the Orange and two digital tire gauges, none could agree on what the real tire pressure was. They were within 3-4 PSI usually but never exactly the same. Also, don't expect realtime updates to pressure and temp with this particular system.
    Somebody broke into the Taco last summer and stole the display unit :eek: rendering the system pretty much useless. I wasn't happy about it but I also didn't really miss having it either. :) It's a good for giving you an estimate of your pressure situation...but it's pretty easy to just get out and use a gauge.
  10. Feb 10, 2012 at 8:04 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    But why wouldn't anyone want to keep the spare properly inflated?
  11. Feb 10, 2012 at 8:07 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Because some people enjoy the "oh shit" feeling when they go to change out a flat and realize the tire with the hole in it has more air pressure than the brand new, never been used spare.
  12. Feb 10, 2012 at 8:19 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    my 2008 has one in the spare,
  13. Feb 10, 2012 at 8:24 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I don't have TPMS sensors in my wheels. I need to pull the LED to get that light to go away.
  14. Feb 10, 2012 at 9:43 AM
    Pugga
    Massachusetts
    Full size spare FTW!
    Although I've found you're more apt to need/use a tire plug kit than the spare.
  15. Feb 10, 2012 at 9:52 AM
    rpking
    rpking Well-Known Member
    Roger
    Ohio
    Tacoma 4x4 TRD off road
    painted engine cover, bed cover, color match door handles, window tint, seat covers, weather gaurd floor mats, TRD stainless steel cat back exhaust, front skid pan, bug deflector, custom holster mount in center console, OME 884X springs and shocks, 2" AAL, OME shocks
  16. Feb 10, 2012 at 4:04 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    Btw the the button under the dash is a set button not reset, the pressure sensors when brought to proper inflation reset themselves. I run 33's and used the set button to calibrate the sensors to 36 psi. I even deflated to test it
  17. Feb 10, 2012 at 4:24 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Set all 5 tires (if your spare has a sensor) to 20 PSI. Turn the key on and hold the "set" button until the tire pressure indicator light shuts off/stops flashing. Then turn the key off. Fill your tires to 35 PSI ( or whatever). Now the light should only come on when the pressure in a tire drops to 20 PSI. You might disable it by locating the TPMS (tire pressure monitoring system) computer and unplugging it. (Do not touch the button after setting your tires to the correct amount of air.)
    You have to thank car owners who drive their cars with very little air in a tire, have a blowout and have/cause an accident/rollover (Ford Explorer). This system comes on all new cars.
    I work at Lexus and have cars come in all the time with the light on.
  18. Feb 10, 2012 at 10:29 PM
    TnShooter
    Deogee
    STOCK
    My TPMS button was below the gas pedal. I hit it with by boots (Big Feet, I guess?) a few times. So I popped it out and stuck it up under the dash. A buddy of mine has a 2011 and his TPMS is in a whole different place. I guess I'm not the only one that kick the poo out of the switch?
    2007 Tacoma here....
    I'll air the spare when I get a chance to lower the tire. The valve stem is on top
    and I can not get to it.
  19. Feb 11, 2012 at 4:44 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    My real time "system"...:p
  20. Feb 11, 2012 at 5:04 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Well I am thankful then no sensors in rims on truck besides spare. I have no light on I read somewhere the radio signal can reach a
    50 mile rad I have yet to go more then 50 miles from my spare
    set that have sensors ? No light yet would bug me to have it on
