TPMS help needed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bikenut, Jan 27, 2021.
  1. Jan 27, 2021 at 12:14 AM
    Bikenut
    Bikenut [OP] Well-Known Member
    Ron
    West Michigan
    2016 White TRD Sport DCLB sunroof prem & tech
    I recently picked up a set of take off OR wheels & tires that included the tpms. Is there a DIY way to get the truck to recognize the different sensors? I've tried the reset procedure, but it's not working. The manual says new/different sensors require a dealer visit. I would like to work around that if I can. Anyone done this?
  2. Jan 27, 2021 at 12:56 AM
    kentchup
    kentchup Low Sai
    Kent
    San Jose
    2019 Super White TRD OR 4x4
    You would need have the tool to pair the new sensors to the car. Otherwise you are going to visit the deals. Correct me if I’m wrong.
    deadpocketss likes this.
  3. Jan 27, 2021 at 1:05 AM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    or just swap with original sensors
  4. Jan 27, 2021 at 4:58 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    The ID numbers of the new sensors need to be programmed into the truck's computer using a tool that connects to the OBDII port under the dash. You also need to know the new ID numbers which can be read with a trigger tool that you point at the valve stem.
    Dealer is not your only option for this. A good tire shop should be able to do it or you can buy a tool and do it yourself. I do it myself twice a year when I switch between summer and winter wheels.
    crbr, Big tall dave and texbaz like this.
