TPMS how they work by air preasure or tire revolution
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob01, Nov 28, 2010.
  1. Nov 28, 2010 at 8:04 AM
    rob01
    rob01 [OP] Active Member
    Winnipeg, Canada
    2010 silver Crew cab TDR sport
    Can someone tell me how the TPMS works. Does the sensor simply read preasure in the tire or is it through the abs system where it measures tire revolution.
  2. Nov 28, 2010 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    They read the pressure in the tire.
  3. Nov 28, 2010 at 8:18 AM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    T - Tire
    P - PRESSURE
    M - Monitoring
    S - System
    :D
  4. Nov 28, 2010 at 9:09 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    That's not really helpful. Toyota has TPMS systems (like in the 1st Gen Highlanders) that use passive TPMS rather than active TPMS. The Tacoma has active TPMS.
    The passive TPMS does not measure air pressure. It measures tire rotation to determine whether a tire is underinflated.
  5. Nov 28, 2010 at 9:19 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
  6. Nov 28, 2010 at 9:29 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  7. Nov 28, 2010 at 10:08 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    ????WHAT???? So how fast does the spare under the truck need to rotate?
    The TPMS will go off if that tire is low.
    It measures pressure. :rolleyes:
  8. Nov 28, 2010 at 10:13 AM
    Taco11
    Taco11 Well-Known Member
    Seattle WA
    On a passive system the spare is not measured. He is correct. Unless your joking and I just dont pick up on that.... :cool:
  9. Nov 28, 2010 at 12:38 PM
    JKD
    JKD Well-Known Member
    You're going to need to pull your foot out of your mouth after you read this.
