tpms in spare????
Discussion in 'Wheels & Tires' started by brutalguyracing, Dec 21, 2009.
  1. Dec 21, 2009 at 3:28 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ky
  2. Dec 21, 2009 at 3:43 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    his spare was probly flat. becasue he needed to use it. and wondering if it had a tpms sensor
  3. Dec 21, 2009 at 3:48 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    For you guys with 08's and earlier, take the spare down and flip it over. Leave the valve stem toward the back of the truck. Not so much of a PITA to add air to the spare. (it wouldn't be a bad idea for the new model guys to do the same, just check out the spare every now and then so your not screwed if you get a flat)
  4. Dec 21, 2009 at 3:52 PM
    98tacoma27
    Ben
    Not Beech Creek
    Good point
  5. Dec 21, 2009 at 3:59 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Has anyone checked to see if Toyota would be willing to remove the sensor and reprogram the trucks that have them in the spare? I'm assuming it wouldn't be a safety issue for Toyota since they no longer put them on. The sensor in the spare is a pain in the ass!
  6. Dec 21, 2009 at 4:28 PM
    TacoSupreem
    Hayden
    Kentucky
    I have a dual foot fill chuck that i can get to the spare with! Also have a dual foot tire pressure guage! That makes an easy fix.
  7. Dec 21, 2009 at 4:41 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    [​IMG]I put one of these on my spare and drilled a hole beside the trailer connector to mount the valve.
  8. Dec 21, 2009 at 4:46 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    no i didnt have to use the spare but i want to use the spare as a replacement rim...
    and thanks but no good. to the rims for sale guy in ky
  9. Dec 21, 2009 at 4:47 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    hey i can take out the tpms thing from the damaged rim and install it on the spare and so on right????
  10. Dec 21, 2009 at 4:49 PM
    johnw
    john
    orlando florida
    yes im pretty sure
  11. Dec 21, 2009 at 5:03 PM
    TacoSupreem
    Hayden
    Kentucky
    yes u can, but be careful because they are easily damaged and will set off you dash light! they arent cheap either!!
  12. Dec 21, 2009 at 5:22 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    this is what i did took all of ten mins to do.i couldn't figure out why my light wouldn't go off.i was about to take it to the dealer and then it hit me check the spare.
