TPMS in the spare from the factory?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TXTRDPro, Dec 26, 2019.
  1. Dec 26, 2019 at 3:13 PM
    2011TXTRDPro
    2011TXTRDPro [OP] Well-Known Member
    Bob
    2011TXTRDPro
    None
    My son just bought a 2014 Tacoma
    Do they come from the factory with a TPMS for the spare?
  2. Dec 26, 2019 at 3:14 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
  3. Dec 26, 2019 at 3:15 PM
    2011TXTRDPro
    Bob
    2011TXTRDPro
    None
    Thanks for the fast reply.
    replica9000 likes this.
  4. Dec 26, 2019 at 3:21 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    My 2008 had a sensor in the spare, but my 2014 does not.
  5. Dec 26, 2019 at 3:22 PM
    Tacoma Mike
    Southern Maine
    No
    2010 was last year
    Muddinfun and ImMrCrash like this.
  6. Dec 26, 2019 at 3:49 PM
    replica9000
    2019 T4R ORP
    I guess I was wrong. My 08 had it in the spare. Figured these days it was standard. :notsure:
    It's a pain to drop the spare just to check the air pressure when the TPMS light comes on.
  7. Dec 26, 2019 at 4:05 PM
    2011TXTRDPro
    Bob
    2011TXTRDPro
    None
    Yes the light is on but the 4 tires are correctly inflated. Didn’t drop/check the spare.
    Guess a low battery or faulty sensor.
    I need to go and have them scanned.
  8. Dec 26, 2019 at 4:10 PM
    Tacoma Mike
    Southern Maine
    Does it flash when you start it up
    Also what pressures you set them at
  9. Dec 26, 2019 at 4:41 PM
    2011TXTRDPro
    Bob
    2011TXTRDPro
    None
    Yes it flashes then stays on.
    Don’t recall what the pressure was, but he said it is inflated a little higher.
  10. Dec 26, 2019 at 4:44 PM
    Tacoma Mike
    Southern Maine
    You may have a dead sensor .
    Flashing on startup means the system has an issue..
    I’m waiting for mine to start the death wink...
    ImMrCrash likes this.
  11. Dec 26, 2019 at 4:45 PM
    Muddinfun
    Muddinfun Well-Known Member
    Flip the spare over.
  12. Dec 26, 2019 at 4:46 PM
    Griffin26
    Griffin26 Active Member
    Virginia
    '19 Tacoma TRD OR DCSB
    Maybe my memory is bad but I seem to remember reading here that the system can only have 4 sensors registered at a time. I was looking at a second set of tires is why I was wondering. If it can only handle 4 then why would there be one in the spare? I'm 2013 fwiw
  13. Dec 26, 2019 at 5:16 PM
    Muddinfun
    TPMS started in the Tacos in 2006 with 5 sensors. Sometime around 2009, they discontinued the sensor in the spare. If you have a 5 sensor truck, you must have 5 working sensors to keep the light off. If you have a later 4 sensor truck, you can only have 4 sensors programmed. If you have a 2nd set of tires with sensors, you either need to buy the stuff to program the truck yourself each time you swap, or go to Discount tire and get them to program your truck for you.
    ImMrCrash and TRDSport10 like this.
  14. Dec 26, 2019 at 5:51 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I must be lucky. My 07 still has 5 working sensors. And I do have to air up the spare occasionally to turn the light off. Since I brought it up one of them is sure to die before the end of the week.
  15. Dec 26, 2019 at 5:55 PM
    furiousbob
    furiousbob Well-Known Member
    Ron
    Apparently you need 5 for your sensors to function. I was missing a spare on my '14 and the TPMS light was always on. Got a new set of tires and threw an old tire under the bed. Light finally went off.
  16. Dec 26, 2019 at 6:04 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Yes that’s an option but it places the nice side of the wheel into the elements. It is possible to check and service spare if you position it properly and don’t mind laying on your back with good light to see and feel what you are doing. I replaced the ugly steel wheel spare with matching alloy of other four. Maybe I’m overthinking this
  17. Dec 26, 2019 at 6:06 PM
    replica9000
    2019 T4R ORP
    Supposedly, the sensor für the steel spare was different than the alloy wheels, but I had mine removed, and all 5 were the same.
  18. Dec 26, 2019 at 6:18 PM
    Muddinfun
    So, then the elements just sit there and fester on top of the nice side of the wheel. I keep my nice spare wheels in the shop and have a powdercoated steel wheel for a spare under the truck.
    TRDSport10 likes this.
  19. Dec 26, 2019 at 6:19 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    In my 2011 it only came with 4. Once a tire pressure got to about 26psi the light would come on and after reflating the low tire the light has to be reset it will not go out just by inflating tire. I have not done this in some time but the rest process is something like holding the button in and cycling the key to on and waiting for light to flash the turning key off.
  20. Dec 26, 2019 at 6:19 PM
    replica9000
    2019 T4R ORP
    Surprisingly, my unused spare looked pretty good after 11 years of New England weather.
