TPMS inaccurate?
Discussion in 'Wheels & Tires' started by codemancer, May 12, 2020.
  1. May 12, 2020 at 7:27 PM
    codemancer
    codemancer [OP] Well-Known Member
    Northern Utah
    2020 Tacoma OR DCSB Voodoo Blue
    KDMAX Pro, RCI sliders and skids, CBI overland bars, 255/85R16 Geolandars, Bestop Supertop 2, ARB Drawers, Uptop Bravo rack
    I've noticed my TPMS seems to read 2-3 PSI lower than tire pressure gauges. Is there a way to correct this?
    What usually happens is I air down to go on a trail with my ARB rapid deflator. That gauge usually reads around 19-20 when I stop. When I get in the vehicle and start driving it usually settles on 16-17. Then when I reinflate I use a slime digital pressure gauge with my Viair 400p until the slime gauge reads 30 psi then I stop. When I get in and drive for a bit it usually comes in at 27-28 psi per tire. So it seems to me like it is the TPMS that is off. I'd love to figure out how to calibrate it if that's possible.
  2. May 13, 2020 at 7:10 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    What elevation are you at?
    mosccat likes this.
  3. May 13, 2020 at 7:16 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    Here's one for you..
    What if the TPMS is correct but the other gauge is off :anonymous:
    joeyv141 likes this.
  4. May 13, 2020 at 5:04 PM
    codemancer
    Northern Utah
    I’m above 4000 feet in Utah.
  5. May 13, 2020 at 5:05 PM
    codemancer
    Northern Utah
    That’s why I mentioned that both the ARB and slime gauge seem to be off by the same amount so TPMS seems more likely.
  6. Apr 25, 2022 at 10:53 AM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    I know this is an old thread but this may help someone else…
    TPMS uses an atmospheric tire guage where as regular tire guages don’t take into affect the barometric pressure.
    Read this link and use the chart to compensate.
    @codemancer for you to get 30 psi inside the tire you would need to inflate to 32psi with your slime guage.
    Realistically your TPMS is actually reading correctly… @WZ00R2 ;)
    https://www.coyoteents.com/compensating-tire-pressure-readings-for-elevation/
  7. Apr 25, 2022 at 11:47 AM
    codemancer
    Northern Utah
    Thanks for the info! I never quite solved this problem so I'm glad I can choose TPMS as the more accurate source.
  8. Apr 25, 2022 at 12:52 PM
    mosccat
    Mark
    2020 OR
    I just had the same problem, was trusting my dedicated jaco pressure guage and my pressures were way out, 8,500 ft elevation.
