TPMS information needed.
Discussion in 'Wheels & Tires' started by reidster, Jul 24, 2021.
  1. Jul 24, 2021 at 4:20 PM
    reidster
    reidster [OP] New Member
    I have a 2014 Taco I just bought. It has steel wheels and I bought a set of TRD Pro's off a 2019. I understand the TPMS sensors can't be moved from the steel wheels to the TRD's. Is this correct? If not, what should I do? Which sensors should i buy and should they be rubber pop in or the bolt in? Was looking at Schrader brand.
  2. Jul 25, 2021 at 8:58 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'm sure someone will correct this....
    You need 315 Hz for communication, steel wheel set (different mount angles than for alloy wheels), either valve stem will work.
    If off-road in harsh terrain, the bolt on valve stems maybe more robust.
    Try to stick with the Denso brand.
  3. Jul 25, 2021 at 10:03 AM
    reidster
    Thanks man for your reply! I guess the reason the ones from my steel wheels won’t work in the TRD’s must be the sensor part inside the wheel must hit the inside wall.
  4. Jul 27, 2021 at 3:35 AM
    johnbisfunny
    johnbisfunny Member
    2021 SR Double Cab
    I have steel and converting to alloy and need some advise on this as well.
    2021 to 2019 alloy, not pro though.
