TPMS Installation in unequipped truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wingsformyway, Feb 12, 2021.
  1. Feb 12, 2021 at 8:34 AM
    wingsformyway
    wingsformyway [OP] Well-Known Member
    Alex
    Vancouver Island, BC, CA
    2021 Tacoma TRD Sport DCSB 6MT Cement Grey
    Blackout badges & tailgate inserts; interior blackout (vinyl)
    Hi all,
    This may be odd to most of you but in Canada, some Tacomas do not come equipped with TPMS. I had it on my 2019 OR (AT) but my 2021 Sport (MT) does not have it. This is the case with all MT model Tacomas and (I think) some base model configurations.
    Anyway, how easy, costly and/or feasible would it be to install a TPMS? I have zero issues checking tire pressure myself (already had to because the dealership apparently couldn't or forgot to) but I do miss the convenience of it on the dash.
    Thanks
  2. Feb 12, 2021 at 9:48 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I'm pretty sure I have seen completely stand alone systems for vehicles that never had TPMS. I don't know what parts of the factory TPMS system your truck may or may not have.
    whatstcp likes this.
  3. Feb 12, 2021 at 9:55 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Thats weird that it doesnt... its been mandatory since 2007
  4. Feb 12, 2021 at 9:59 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Aftermarket tire pressure systems are available. I put one on the wife's RAV4 for use with her winter tires (wheels with no sensors). She likes it so we use it year around. No dash display, tho. It plugs into the cigarette lighter (due to PC that probably has a different name).
    Is there no display of tire pressures available on your vehicle? My 2020 (US model) has that.
  5. Feb 12, 2021 at 10:00 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
  6. Feb 12, 2021 at 10:04 AM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    My TPMS light has been flashing for 4 years. LOL!!
  7. Feb 12, 2021 at 10:04 AM
    CRSTRD
    CRSTRD Well-Known Member
    2020 Tacoma TRD Off Road
    I am not a fan of TPMS. Serves a statistically miniscule issue (preventing tire blow-out accidents from under-inflated tires) and can be so expensive to repair that most people simply ride around with the light on when it fails anyway.
    soundman98 and Gen3TacomaOBX like this.
  8. Feb 12, 2021 at 11:12 AM
    wingsformyway
    Alex
    I'm not sure. Is there a good way to tell? I know when I first brought the truck home I scrolled over on the info screen to where I was used to it being and there was something else there instead (perhaps it was blank? I'll have to double check). I have access to Techstream; maybe I can tell through that?
    That's incorrect. I've heard in the USA that's the case, but in CAN it's a nice-to-have-but-not-required feature.
    No, none at all. As I stated, some of the Canadian models do not have TPMS. The 'premium' (Sport, OR, Pro, Limited) AT models do but none of the MTs do. I'm just checking and it would appear the SR and SR5 models do lack TPMS regardless of transmission.
  9. Feb 12, 2021 at 11:17 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    :spending:
    MadJacks likes this.
  10. Feb 12, 2021 at 11:19 AM
    wingsformyway
    Alex
    These aren't bad solutions. Thanks. I'd rather it all be fully integrated than an extra piece of hardware but if that's too difficult or not possible I'll definitely consider.
    I liked it for the quick glance to see where the pressures were at, especially since the first winter I had with my OR the light came on because my tires were dropping under 25. It's also nice to be able to see how much more pressure is gained once I've been driving around a while and the tires (and air) have warmed up and expanded. I'm nervy about over or under inflated tires unless there's a specific purpose (like if one was offroading)
  11. Feb 12, 2021 at 11:21 AM
    wingsformyway
    Alex
    Tire thumpers! We use them on some of the equipment at work. So satisfying giving a good whack.
    I do carry a gauge with me for checking pressure. I don't use it often but when the seasons change it's nice to be able to keep an eye on things
  12. Feb 12, 2021 at 11:38 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    If your arms are long enough, u can check em while driving too.
  13. Feb 12, 2021 at 11:43 AM
    wingsformyway
    Alex
    Hahahaha! Sadly, I'm pretty small. Maybe if I can find one my size or larger...
  14. Feb 12, 2021 at 11:56 AM
    CRSTRD
    I will admit that the newer systems, where you can see the TP of each tire are nice to have. I was commuting home in my '17 F250 and had just come off a hwy exit when the warning popped-up on the dash as I must have just rolled over something because I could watch the pressure drop about a PSI a second...good thing those tires took 65 PSI and there was a tire store about 1/2 mile up the road.......:amen:
  15. Feb 12, 2021 at 12:00 PM
    wingsformyway
    Alex
    Yeah, I hear you. Two days before trading in my OR I was doing 100 down the highway when I heard something odd and shortly after the dash lit up and showed me exactly what was up and I was able to pull over safely and change it out. That's another reason I'd like to add it if possible. I'm going to see what the truck shows now and maybe dig around with Techstream later to see if it has the capabilites even.
    I doubt I'll get another flat anytime soon but I wasn't expecting that one so who knows
  16. Feb 12, 2021 at 12:07 PM
    wingsformyway
    Alex
    this is what the truck shows where it normally would have TPMS
  17. Feb 12, 2021 at 12:13 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    100kph* all u internet traffic cops
  18. Feb 12, 2021 at 12:34 PM
    CRSTRD
    You should travel the highway loop I take to work and back every day......100MPH is about the average.......really.....:bikewheelie2:
  19. Feb 12, 2021 at 1:06 PM
    calebc
    calebc Well-Known Member
    It would be interesting to know if your ECU even has it. I doubt it does but who knows? I think to get it fully integrated, your ECU would need to support it. Techstream should be able to show you if it's there.
  20. Jun 20, 2021 at 4:19 PM
    Tater1727
    Tater1727 Active Member
    Nate
    2021 Tacoma SR
    I'm having the same issue.. any fix yet? I only saw it the first several days.. now my screen looks exactly like yours.
