TPMS interchange
Discussion in 'Wheels & Tires' started by PR45, Sep 1, 2009.
  1. Sep 1, 2009 at 12:37 PM
    PR45
    PR45 [OP] Well-Known Member
    Los Angeles
    PreRunner SR5 4cyl
    Can TPMS sensors from steel wheels be used in alloys by turning them around? Or is it mandatory to have the alloy version only in Toyota wheels?
    Thanks...
  2. Sep 1, 2009 at 1:18 PM
    Tex FF Taco
    Tex FF Taco Member
    Denton, TX
    Helo's with 285/75 R16 Revtech 3" lift w/AAL K&N Drop in Air Filter Subwoofer
    When I bought my aftermarket wheels (alloys), I had the TPMS moved from my steel wheels to the new alloys. They had to reverse mount them to fit. Just be careful when buying new tires though, if you pop the bead of the tire on or off near the sensor it will break the sensor (per discount tire).
  3. Sep 2, 2009 at 10:52 AM
    PR45
    Los Angeles
    PreRunner SR5 4cyl
    Anyone else do this? Results?
    Thanks....searched far and wide, can't find others who've done this.
  4. Sep 3, 2009 at 11:48 PM
    PR45
    Los Angeles
    PreRunner SR5 4cyl
  5. Mar 14, 2018 at 7:30 PM
    PR45
    Los Angeles
    PreRunner SR5 4cyl
    Fwiw I ran steel wheel tpms turned 180 degrees in the sport 17 inch alloy wheels for over 7 years without a hitch.
