tpms issue...
Discussion in 'Wheels & Tires' started by linkfeeney, Dec 8, 2008.
  1. Dec 8, 2008 at 8:19 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    aberdeen, nj
    09 Doublecab TRD Off-Road! Magnetic Grey!
    ok so its cold here this morning in expensive NJ!
    like around in the high 20 degress... I turned my truck to warm up and saw the TPMS came on. So ok, I'll go fill up air later... then it warms up so I drove it out on the interstate, the light went away! WTF?!
    I guess I'll check my PSI later. anyone has issues?
  2. Dec 8, 2008 at 8:22 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    It is very possible that with the temp. change the pressure changed enough to set off the sensors. I wouldn't worry about it, just keep an eye out.
  3. Dec 8, 2008 at 8:22 AM
    tarheelfan_08
    tarheelfan_08 Carolina Alliance
    Justin
    North Carolina
    2010 White 4x4 Double Cab Tacoma Short Bed
    Chrome Grill, Chrome accessories(door handles and mirror covers), LEER Super White Cover, Mirrors with Turn Signals, Window Vent Visors, Step Rails, WeatherTech Digital Floor Mats, Mini Maglight Holder, Chrome Bull Bar
    My truck does crazy stuff in the cold to! No big deal! If it goes away after it warms up you should be fine! If not then you got problems
  4. Dec 8, 2008 at 8:29 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    if not then I've got a problem??? are u talking about new sensors problems or simple as filling up air problems???
  5. Dec 8, 2008 at 8:32 AM
    tarheelfan_08
    Justin
    North Carolina
    Both possibly(more then likely the air pressure)! But im 99% sure its just due to the cold weather!
  6. Dec 8, 2008 at 8:32 AM
    tarheelfan_08
    Justin
    North Carolina
    Sorry didnt mean to scare you!
  7. Dec 8, 2008 at 8:32 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    i know the air is dense in the cold, I dont see it how it possible causing the PSI. It was just weird. Man, so cold outside that I dont even want to to check my tire pressure.. :D
  8. Dec 8, 2008 at 8:34 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    yeah I dont have time to go back to the dealers and bitch at them right now... at least after the holidays.
  9. Dec 8, 2008 at 8:36 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    The air becomes less dense in extreme colds therfore less psi. when the tires are ran they warm up then the air expands again! if you want to avoid this have your tires filled with nitrogen... or just don't worry about it:D
  10. Dec 8, 2008 at 8:42 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    yeah the nitrogen is cold thou. how does it work? the problem if lets just say I'm in the middle of nowhere in NJ.... i heard I cannot mix air with nitrogen. then i would be SOL no?
  11. Dec 8, 2008 at 8:43 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Maybe just add a pound or 2 of psi and see what happens, our sensors have some play I think something like 3psi in either direction before they go off. Being it is cold the psi should be dropping thus adding a few extra psi may keep it in the zone. However that is alot to do for just curiousity sake. I'd let it ride.
  12. Dec 8, 2008 at 8:45 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Yes you would be SOL!!!:) that is the neg of it:(.... but that it wat a spare is for..
  13. Dec 8, 2008 at 8:46 AM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    My thoughts exactly.^^^^^ luke.
    i was too slow on that
  14. Dec 8, 2008 at 8:51 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    ok about i lost 2 tires due to some hobos left shards of glass all over the road! How about this scenario people??!!!
  15. Dec 8, 2008 at 9:32 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    okay you win:D
  16. Dec 8, 2008 at 9:37 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    u call 20 degrees cold....its -4 here with wind chill.
    and TRD man is absolutly right. The molecules come closer together in the cold, being more dense and causing less PSI. when u drive the air warms up and expands...creating more PSI. if u filled up this morning i would take some air out when u have a chance because when it warms up....ur PSI will be very high.
  17. Dec 8, 2008 at 9:49 AM
    linkfeeney
    link the stink!
    aberdeen, nj
    man, it is so depressign when the weather outside is that cold!! Sometimes i wonder why didn't my parents live in South cali in the first place?!?!? well good thing i didn't fill anything up
  18. Dec 8, 2008 at 9:59 AM
    Clelsdah
    Clelsdah Western Alliance: Yeehaw Division
    No California Foothills
    08 SR5 4x4
    Bed mat, tube steps, Ipod interface, Ride-rite air springs
    My wife's 05 4Runner has done the same thing every winter. We live in the foothills of CA with lows in the high teens/low 20's. The Toy tech explained the TPMS monitors for equal pressure within all the tires and 5 psi less in any one will set off the light. It has been resolved with checking and equalizing all tires including the spare. Regarding filling up in the morning (cold) and increased pressure when it warms up, the pressure change is only a couple PSI not enough to worry about. My Taco was bought this spring, we'll see if it does it this winter.
  19. Dec 8, 2008 at 10:07 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    yup -24 with the wind chill not fun tacoma is in the shop cars, trucks off the road everywhere, salt didn't work freak sudden cold makes the roads ice rinks!! yipppeeeee. But hey its gonna be 54 on weds with rain!!! WTF
    Back on topic..
    Isn't there a TSB for the TPMS I saw here recently??? Exactly the prob Link describes. Worth a look see.....
  20. Dec 8, 2008 at 11:42 AM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
    has to do with the sensor in the spare tire. mine is setting my light off right now cuz i been too lazy to drop it down and fill it. i don't think the 09's have them in the spare anymore...too many people bringing in vehicles to have the spare tire aired up.
