TPMS issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by refrigerationguy, Apr 28, 2024.
  1. Apr 28, 2024 at 10:46 AM
    refrigerationguy
    refrigerationguy [OP] New Member
    Taylor
    2018 Tacoma TRD Off Road
    Hey guys new to the tacoma world. I recently had a tire go flat. I took to shop and had it repaired and I put the tire back on. None of my TPMS sensors are reading anymore. I have done well over 100 miles of driving and it still isn't showing anything. I have tried holding down the tpms button and its not doing anything. Do you have to do some sort of procedure every time a tire is taken off to get the TPMS to work again?
    HondaGM likes this.
  2. Apr 28, 2024 at 11:01 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Here’s to page from the manual outlining the exact procedure. Hope it’s helpful!
    It’s also worth noting that if one of the sensors is dead or missing none of the pressures will show up like you’re describing
    HondaGM likes this.
  3. Apr 28, 2024 at 11:09 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    They probably messed up your sensor during the repair.
    Unfortunately, it's not that uncommon.
    The tire shop should be able check it electronically without dismounting the tire.
    Chew, musicisevil and HondaGM like this.
  4. Apr 28, 2024 at 11:13 AM
    refrigerationguy
    Taylor
    OK thanks guys
  5. Apr 28, 2024 at 1:40 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    welcome......it obviously had something to do with the tire repair.....go back to the tire shop
