TPMS light came on again.. rear tire was losing air
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimmywestco, Nov 1, 2023.
  1. Nov 1, 2023 at 1:52 PM
    Jimmywestco
    Jimmywestco [OP] Well-Known Member
    James
    2019 SR AC
    Intermittant wipers, fog lamps wired like factory, remote entry via SE Toyota Dealers kit installed.
    rear tire losing air tpms light came on again..
    I aired back up to 34psi up front and 35psi in rear
    now what? what needs to be done to get this idiot light to go off?
  2. Nov 1, 2023 at 1:53 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    recheck and drive it a few miles, if it still doesn't go off, go to a shop with a TPMS scanner to check signal and battery strength.
  3. Nov 1, 2023 at 1:57 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Nov 1, 2023 at 1:59 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    When temperature drops, air pressure goes down. If you're putting in 34 PSI in the tire during the day when it is warm it could easily be closer to 25 PSI at night when the temperature drops. This is a common issue at this time of the year when it starts to cool off.
    Or you could have a bigger problem. If the light keeps coming on you may have a slow leak. Get the tire checked.
  5. Nov 1, 2023 at 2:10 PM
    Jimmywestco
    James
    2019 SR AC
    Yes I think one tire has a slow leak the RR it did this before and I did the reset thing by dropping each tire to 32psi did the reset button then aired them back up to 34/35 psi and eventually after driving around a bit the light went out. I don't drive the truck a lot because I have an older corolla that uses far less gas so the Taco sits in the driveway for sometimes a week or more without driving it. So the last time I tookl a longer trip after it was sitting a tire must have bled down enough that sure enough I got only around 10 miles and that darn light came on. Now I check the tires more often which is annoying for sure.
  6. Nov 1, 2023 at 2:11 PM
    Bishop84
    Bishop84 Well-Known Member
    At work I just set the pressures above threshold and leave the key on for 5 mins, usually clears itself no tools no buttons.
    HondaGM likes this.
  7. Nov 1, 2023 at 2:13 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Why don't you get the tire fixed? It's not safe to drive with a tire that could potentially fail during operation.
    Chew likes this.
  8. Nov 1, 2023 at 2:18 PM
    Jimmywestco
    James
    2019 SR AC
    Of course I will.. when time allows
    sdsurfer likes this.
  9. Nov 1, 2023 at 11:47 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  10. Nov 2, 2023 at 7:20 AM
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Adding more air is for sure the solution, it just hasn’t worked yet. Keep trying! The light is for sure the idiot here! Dig in and you’ll win this battle!
    Be an adult and get your shit fixed by a professional, in this case a 17 year old at Discount Tire, they take walk-ins. I’m not going to lecture you about safety.
  11. Nov 2, 2023 at 7:24 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Are you sure you're losing air and your dog didn't pee on the tire? :rofl:
    Chew likes this.
  12. Nov 2, 2023 at 8:36 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Take it to discount tire have them check the tire for leaks .
