TPMS light flashing then solid, no changes to tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikeshardtacoma, Oct 26, 2020.
  1. Oct 26, 2020 at 9:28 PM
    mikeshardtacoma
    mikeshardtacoma [OP] Member
    2011 Grey Tacoma TRD Offroad DoubleCab
    Today while driving, the TPMS light came on flashing, then went solid. checked the owner's manual, and it says to bring the truck to toyota. obviously, I don't want to deal with a dealer service center, so what do i do? bought the truck in july of this year, no changes to the tires have been made. The weather did just cool down significantly where i live (high 80s-low90s to high 60s), but if this deflated a tire the light wouldn't blink. am i overthinking things here?
  2. Oct 26, 2020 at 9:30 PM
    Bishop84
    Bishop84 Well-Known Member
    Top them up first.
  3. Oct 26, 2020 at 9:32 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Check the tire pressure then ignore the light. Mines been doing it for years. Just be sure to check ur pressure every now and again to make sure ur all good.
  4. Oct 27, 2020 at 1:17 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    TPMS are battery powered and at 8-10 years the batteries can start to die and the light may blink due to loosing contact with the sensor reader then feeding this data on.
    Dealer and all tires stores have a TPMS reader/scanner and they can walk past each wheel and see if TPMS is working. Many posts on TPMS function, pressures, resetting, cost etc on this site so just type it in the search at top right.
    TOMB likes this.
  5. Oct 27, 2020 at 1:39 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Flashing at first then going solid is a sure sign that you have a bad sensor.
    If it's solid all the time, low pressure.
    b_r_o and TOMB like this.
  6. Oct 27, 2020 at 1:40 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    Battery dead, bad sensor
    TOMB and super_white like this.
  7. Oct 27, 2020 at 2:19 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Correct.
    The replacement sensors I bought (OEM from Toyota) have what looks like a bigger battery so maybe they will last longer?
    TOMB likes this.
  8. Oct 27, 2020 at 3:21 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    If you want to save some money, the Toyota sensors are made by Pacific Industries who supplies Denso and they in turn supply Toyota. They can be found on Amazon. Be aware that the sensors for alloy and steel wheels are different.
    https://www.amazon.com/dp/B00NQ05U2...wVehicle=1&vehicleId=2&vehicleType=automotive
  9. Oct 27, 2020 at 4:08 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I found that out when I switched from steelies to Level 8 Mk6 wheels.
  10. Oct 27, 2020 at 5:58 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    FWIW - I just went through this issue and it was two (2) bad sensor's. You can have a tire shop detect which sensor(s) are bad (Discount Tire for example).If you go to a tire shop, have them double check the spare tire as some 2nd Gen's came with a sensor in the spare. Mine did not as I found out while diagnosing my issue. Mine is a 2011 SR5 4x4. I am no longer on stock wheels or tires.
    TOMB likes this.
  11. Jul 26, 2023 at 1:25 PM
    boatflower
    boatflower Member
    Second Generation Tacoma 05-15 TPMS Light On and Blinking
    If TPMS light flashing then solid, make sure to go professional tire shop and ask service person to check all tire sensors and the spare is working properly with correct inflation psi usually located inside driver side door flange. If sensor needs replacement or battery price range is around $50-$75 each. Check TPMS light again, if light does not reset tire professional service person has a device to re-learn tire sensors to communicate with computer chip. Check tire light again, if sensor is still blinking service person must connect OBD to input port usually under the dash and allow computer to communicate with tire sensors. If you buy a sensor from a tire shop service professionals are usually happy to perform the pre-mention step. Now my TPMS light is off and working properly.
    Patdante and TOMB like this.
  12. Jul 26, 2023 at 3:43 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    More like $15 each.
    Amazon.com: MORESENSOR 315MHz TPMS Tire Pressure Sensor 4-Pack | Compatible with Lexus & Toyota Select Models | Replacement for 42607-33011 | Clamp-in | NX-S008-4 : Automotive
    I put these in my truck a little over 2 years ago when I was buying new tires. No extra charge to install them at that time. I have used this brand on 2 other vehicles. The oldest one 5 years ago. Never had a problem. I replace mine proactively when I'm buying tires if I feel the new tires will outlast the sensors in the truck. Around 7-10 years is typical, but I've seen some last 12-13 years.
    They are cheap enough and easy enough to replace I don't see the point in waiting for one to go bad.
  13. Jul 26, 2023 at 4:29 PM
    R.G
    R.G Member
    Richard
    2007 Red Tacoma TRD
    Have you checked your spare for pressure, i had the light and found my spare was low
  14. Jul 26, 2023 at 4:40 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Mine, it sometimes blinks and then goes solid and then........overnight the problem will go away. There is a "weak" sensor that reports in to the system when it is in a particular stopped position - clears the false reading - then sometimes days later the fault will reappear. PITA!!!!
    Discount tire fellow told me all of the sensors worked - but I don't think they can tell what the signal strength variance may be.
  15. Oct 24, 2023 at 10:20 AM
    gthupman
    gthupman Well-Known Member
    Greg
    Raleigh, North Carolina
    '17 DCSB Super White Offroad
    any follow up on this? I’m having the same issues and discount tire has also told me all sensors are fine
  16. Oct 25, 2023 at 5:41 AM
    ID_IFD_3431
    ID_IFD_3431 Well-Known Member
    2009 Access Cab 4WD
