tpms light look like?
Discussion in 'Wheels & Tires' started by DBTaco, Oct 27, 2013.
  1. Oct 27, 2013 at 7:05 PM
    DBTaco
    DBTaco [OP] Well-Known Member
    NC
    '08 4x4 TRD off road
    Yesterday my wife cranked my truck up to let it warm up. It was the coldest morning yet at 28 degrees. I got in my truck and noticed my light was on. Its the same light that tells you its time for an oil change, the one with the ! In it. My truck didnt come with a manual so i drove it down the autozone to let them run the codes and they said it was my tpms light. I said can you just check to be sure? So the ran the test and NO codes found which was good. I went to sheetz and put air in my tires. Some had 25 psi and some 27 psi. I bumped all up to 35 psi. Is that a good pressure to keep at? I got back in and my wife said after i pumped up the left rear tire which had 25 psi the light went out. Is this the same light?
  2. Oct 27, 2013 at 9:37 PM
    The Stig
    The Stig Well-Known Member
    That's the TPMS light. And 35 is fine
  3. Oct 27, 2013 at 9:45 PM
    AR15xAR10
    AR15xAR10 #blackriflesmatter
    Heh, wouldn't you like to know
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    TSB leafs, rear 5100s, front 5100s with OME883x coils set on 0" and Headstrong Offroad driver's side spacer, 1k rear SumoSprings. Mobtown Offroad Ifs and Trans skids (steel). Cooper ST Maxx in LT265/70R17 E on 17x8 FN Konig Six Shooters in Gunmetal Grey. WeatherTech Floor liners front and rear(grey) with TRD Sport badges, AVS in channel vent visors, OEM Bed Mat, TRD (oiled) air filter, ultragauge MX1.3 with trans temp, remote start, OEM Tow Package hitch, 4pin OEM harness, Chrome bumper plasti derp'd matte black, Grom Ipod interface, quickfists on custom bedrail mount to hold axe/shovel, EBC Dimpled/slotted sport rotors with Duralast Gold ceramic low dust pads, Rokblokz regular mud flaps with black hardware, Superbrightleds map and dome LED lights, led marker lights, fog light anytime mod, rear diff breather relocation mod, redline tuning Elite stainless hood struts, AFE Mach Force XP 2.5" catback, Ionic Soft Trifold Tonneau, OEM LED tail lights, amazon LED reverse light mod, FULL synthetic fluids (BG Racing/Mobil 1), TOYWERX thin lip satoshi, Trail Toys gas tank skid, TRD Shift knob, BAMF behind the grill light bar mount, K&N Washable Cabin air filter, and many STEEKERS.
    It'll be fine. I run 32 in mine because of the fluctuation in temps where i live. You most likely also have a RESET button under your steering colum if the light really bothers you, you can reset it if it doesn't go off soon enough to suit you.
  4. Oct 28, 2013 at 6:25 AM
    DBTaco
    NC
    The light went off by itself. I haven't seen it com back on and I didn't press the reset button either.
  5. Oct 28, 2013 at 6:50 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, HomerTaco Raptor grill, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Toyo AT2, Avid light bar
    Tpms light will go off by itself once the tires have correct pressure.
  6. Oct 28, 2013 at 6:53 AM
    Sandman614
    Sandman614 LRGRNR
    Boone, NC\Garner, NC
    '06 SR5 Off Road
    This weekend at Steven Toyota it was 20* one morning. My TPMS light was on and I checked the tire pressure and it was quite a bit lower than what I had it set at. When it warmed up the tire pressure came back up and the light went off.
    Unless you guys were just screwing with me :spy:. Op check your tire pressure when it's warmer out and you should be good.
