TPMS light staying on 2010 Access Cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a2cntryboy, Jun 29, 2022.
  1. Jun 29, 2022 at 1:19 PM
    a2cntryboy
    a2cntryboy [OP] Member
    2010 Access Cab
    Kenwood radio upgrade.
    My TPMS light was staying on so I did the blue wire to the red/white wire process now my Airbag light came on can anyone explain what happened ?
    Went back after 3hrs and the Airbag light is off but still spending the $29 for new sensors for in the future.
  2. Jun 29, 2022 at 1:35 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The battery in at least one of your sensors is bad. Buy new sensors and put the wiring back to stock. Problem solved.
    I don't understand what is so hard about this. Your factory sensors lasted 12 years, a new set will cost you about $80. That works out to less than $7/year to have working sensors. Guys bitch about $80 every decade for working sensors but think nothing of spending $800-$1200 every 3 years or so for new tires. You're spending more than that for a tank of gas right now.
    IEsurfer, PzTank and 4x4spiegel like this.
  3. Jun 29, 2022 at 1:42 PM
    a2cntryboy
    2010 Access Cab
    I've been around this world a few times and I dont need a light to tell me my tires are low.
    allenn likes this.
  4. Jun 29, 2022 at 1:48 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Jun 29, 2022 at 2:23 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I don't know if this applies to you but in NH, if it's standard equipment in the truck, it needs to be working. Also, no lights can be illuminated..
  6. Jun 29, 2022 at 2:27 PM
    allenn
    allenn Well-Known Member
    2020 TRD Pro
    Can’t afford any having to buy 80$ tanks of gas
    AJKlug1 likes this.
  7. Jun 29, 2022 at 2:53 PM
    TnShooter
    Deogee
    STOCK
    If the light is off, is it working or is it not working?:D
    Do they scan each tire for a signal? Or only if the light is on?
    I half serious to the answer, as I don’t have any inspection in my state.
    I’m not sure if it’s because half of the vehicles here would fail, or my state still thinks we’re smart enough to take care of ourself. If I were to guess, it because half would fail, and no one would fix their cars. And they’d still drive until they were arrested. In which case, the jails would fill up and only cost the state more money. I’m not kidding.
  8. Jun 29, 2022 at 3:01 PM
    garcm329
    garcm329 Well-Known Member
    Mario
    Rancho Cucamonga
    06 T4R
    Icon 2.5 front coils, toytec aluma series 2.0 rear shocks and toytec HD springs. ARB air locker in the rear. 285 70 R17 Kenda Klever RT tires on IVD bronze 6 speed 17” wheels. Wilco spare tire carrier.
    Check the PSI in the spare sometimes it’s as easy as that :D
  9. Jun 29, 2022 at 3:16 PM
    a2cntryboy
    2010 Access Cab
    garcm329
    No sensor in the spare but the light is off for now but i am still getting new sensors for the future they are chep on Ebay.
    garcm329[QUOTED] and TnShooter like this.
  10. Jun 29, 2022 at 4:36 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    the cheapest fix is electric tape over the light
    allenn likes this.
  11. Jun 29, 2022 at 4:40 PM
    TnShooter
    Deogee
    STOCK
    Cheap eBay sensors are just about as scary as having the light on.
    I’d check the reviews first. I’ve been the cheap route. Some times it pays, other times it doesn’t.
    I don’t have a tire machine, so I’d be put sensors and break down + mounting.
    Basically another $100.
  12. Jun 29, 2022 at 4:40 PM
    PzTank
    Above the Notches
    They wouldn’t scan each tire, just check the dash for warning lights.
    If you had a fog light out and took out the other on the way to get it inspected, they would tell you both fogs need to be working cause it’s original equipment to the vehicle …
    TnShooter[QUOTED] likes this.
  13. Jun 29, 2022 at 5:57 PM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    True story, it’s New Year’s Day I’m driving back home about 300 miles into a semi rural area and the TPMS light comes on I got enough early warning to prevent a blow out. It also gives you a heads up on slow leaks so I don’t have a problem maintaining the system. I got sensors through tire rack because they have a nationwide warranty.
    Raylo and IEsurfer like this.
  14. Jun 30, 2022 at 5:03 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I really like having TPMS, but not the lame cheap way Toyota implemented it with one light that doesn't tell you which tire is low. It is way better with something like a ScanGauge 2 programmed to read individual tire pressures so if you get the light, you can easily scroll through to find the problem child. It is a bit of a hassle to set up and program the Xcodes the first time, but only takes a bit more time than checking your tires with a gage once. ScanGauge reports TP1, 2, 3 and 4 so to identify the correct tire, you need to bleed some air and then name that data field appropriately. I use the convention PLF (pressure, left front), PRF, PLR, PRR. Then when you rotate tires, you can rename them again with takes a couple of minutes, or just make a note of the swap.
    The other benefit is that you don't have to randomly check your tire pressures. I leave one of the four ScanGauge 2 data fields set to one of the tire pressures. In the absence of a problem all the tires leak down about the same, so it is easy to see when you need to air up your tires.
