TPMS light staying on
Discussion in 'Wheels & Tires' started by PhilRR, Nov 17, 2011.
  1. Nov 17, 2011 at 7:14 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    Hey guys. A few weeks ago I bought an 2007 Tacoma. I just had the tire pressure gague go on. I filled up my tires and looked on yahoo how to reset it. But, its still on. Do I have to drive around for a bit? And do I also need to fill my spare? Cause if so, how the hell do I get under there to get it filled? Thanks
  2. Nov 17, 2011 at 7:18 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    Yea there is a sensor in the spare. Check that first
  3. Nov 17, 2011 at 7:18 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    the TPS sensors on these trucks are crazy. it tells you how to reset it in your owners manual. and yes, there would be a sensor in your spare. there is a tool bag that should be under your back seat with your jack. you should be able to take that out, put the rods together, slide them in the slot above your licence plate, into a joint that when you spin will lower the tire down so you can check it then.
    now, i also have a 07 tacoma to which after i bought it the tps light came on. after doing all that stuff i just told you, it was still on . . . and that was a year ago. you get used to it if you cant figure it out. just a little extra light in the dark.
  4. Nov 17, 2011 at 7:20 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    Flip your spare tire to make it easy to access the valve stem in the future. :)
  5. Nov 17, 2011 at 7:24 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    Will it go on if you put to much air in? On the truck door it says 29 psi. But these are 4 brand new tires that say 44
  6. Nov 17, 2011 at 7:26 AM
    mjp2
    NJ
    Should only come on if there's too little air.
  7. Nov 17, 2011 at 7:33 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    What the chances of it being the spare?
  8. Nov 17, 2011 at 7:35 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    See, that's why you get paid the big bucks! :thumbsup:
    Is the 44 PSI the max rating for the tire? If so, you should not be running that much pressure. The Tacoma is a light truck and should not require that kind of pressure unless you're running D or E-rated tires.
    Also, I think I read the TPMS works on pressure differential. So if it's reset at 35 PSI, it will get tripped if one tire drops a certain percentage below the set value. That being said, I don't know what would happen if you set the spare too far below or above the other 4 tires. I run 2-3 psi lighter in the rear and have not tripped the light yet.
  9. Nov 17, 2011 at 7:36 AM
    johneman
    johneman Life is good!!
    Ken
    Warwick, PA
    2007 AC 4X4 2.7L 5 speed SR5
    Weston tube steps, EXtang Black Max tonneau cover, Wet Okole's, Front WeatherTek mats
    If all the other tires are at the proper pressure I would say 99% it's your spare...
  10. Nov 17, 2011 at 7:36 AM
    Pugga
    Massachusetts
    F-150 Mod
    Chances are very good that it's the spare if that's the only tire you haven't checked yet.
  11. Nov 17, 2011 at 7:36 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Ha 2nd gens!
  12. Nov 17, 2011 at 7:37 AM
    Pugga
    Massachusetts
    F-150 Mod
    Fixed it for ya :thumbsup:
  13. Nov 17, 2011 at 7:39 AM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Hey at least 2nd gens will tell us before we die!! Right?
  14. Nov 17, 2011 at 7:39 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Drat!
  15. Nov 17, 2011 at 7:44 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    The only thing is, what if the trucks gauge is set for 44 PSI
  16. Nov 17, 2011 at 7:52 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
  17. Nov 17, 2011 at 7:59 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    Also. Will it reset itself after I fill the spare? If the spare isnt the case will it turn off after I drive it for a bit?
  18. Nov 17, 2011 at 8:01 AM
    Pugga
    Massachusetts
    F-150 Mod
    I don't believe it will reset itself, just use the SET button under the steering column, that's what it's there for.
    As far as your 44 PSI question, someone else will have to chime in, I don't know how it will deal with pressure differentials between the 4 main tires and the spare. My question still stands though, why are you running 44 PSI on a Tacoma?
    SamGoingHam likes this.
  19. Nov 17, 2011 at 8:09 AM
    PhilRR
    PhilRR [OP] Member
    Phil
    2007 Tacoma
    I did the set button. But, do I still need to drive a bit? Or no? Do you just hold it till the light blinks 3 times and your good?
  20. Nov 17, 2011 at 8:29 AM
    Pugga
    Massachusetts
    F-150 Mod
    99% sure it's just reset using the button and you're good. I don't have my owner's manual in front of me for the process but I don't remember having to drive to make the light shut off.
