TPMS light stays on no matter the actual tire pressure
Discussion in 'Wheels & Tires' started by L[]w- []iL-T££/ T£AM1, Feb 4, 2025.
  1. Feb 4, 2025 at 10:07 PM
    L[]w- []iL-T££/ T£AM1 [OP] New Member
    William Branch
    Hot Springs Arkansas
    black 2012 Toyota Tacoma TSS sport series pre runner
    just got my truck 1 month ago no mods yet but I the 1st thing i am going to do is put a spoiler up on the top I got at a wreck site from a honda civic
    light on instrument panel stays on all the time no matter what pressure the tires psi is ,
    my inside driver's door jamb sticker says all tires at 30 psi cold and that's what they are now ,, they might be a half pound or even 1 psi under or Iower,, is this sensor so sensitive that all 4 tires have to be exactly 30.0 psi ?
  2. Feb 4, 2025 at 10:09 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does it flash for a few seconds and then remain on or is it just on?
  3. Feb 4, 2025 at 10:11 PM
    Bishop84
    Bishop84 Well-Known Member
    Toyota TPMS can read really low, my gauge shows 33psi and they will read 30psi on the TPMS computer.
    To eliminate error, set them all to 35psi and see if it clears.
    As DM93 mentions, the state of the light matters as well.
  4. Feb 4, 2025 at 10:17 PM
    mit88
    mit88 Well-Known Member
    Planet earth
    Might needs to check for TPMS operating condition.
  5. Feb 4, 2025 at 10:23 PM
    William Branch
    I'm not sure if I'm in the right place , I'm new here this is my first rodeo but this is in response to Dm93 does it flash for a few seconds or just come on ? it flashs for a few seconds then comes on
  6. Feb 5, 2025 at 1:17 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Flashing TPMS light typically means there is an issue with one or more of the sensors, likely a dead sensor.
    TPMS sensors on average last around 8-10 years so if they are original it's not surprising one or more have died, most tire shops should have the tooling to test the sensors and program new ones if you choose. Many tire shops sell sensors although some are overpriced, you can buy the sensors yourself from rock auto some tire shops will install and program them for free when you buy new tires from them so it may be worth waiting until you need new tires.
    eurowner likes this.
  7. Feb 5, 2025 at 3:22 AM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    Toyota used to have a sensor in the spare, but took it out at some point - I don't remember the year of the cut off. I know that my 2007 Taco has one, and the spare has to be inflated to spec with all the others to satisfy the TPMS system. Might be something to look into...
  8. Feb 5, 2025 at 3:39 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    could be the spare
    could be a dead sensor, og from a 12 would be past expected batt life
  9. Feb 10, 2025 at 1:18 PM
    69 Jim
    69 Jim 4-word Jimmy
    PNW
    2013 Standard Cab 4x4
    Just take it to the local tire shop since you seem to be clueless. They'll fix you right up.
    RIX TUX likes this.
  10. Feb 14, 2025 at 3:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    To tag someone you can do it like @'screen name'.
    2009. Rumor has it that it occured mid year, so some do, some don't. Cannot verify never having had an '09
    Not on his 2012.
  11. Feb 14, 2025 at 3:21 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm thinking 07 or 08 was the last year they were in the spare. There is one in my 07.
    You most likely have one or more bad sensors based on your trucks age. They run $40-$60 for a 4-pack on Amazon. That's less than the cost of a tank of gas every 7-10 years.
    I don't wait for mine to die. I replace them every other time I buy new tires. That works out to once every 6-7 years. They might last for a 3rd set of tires but it's a lot easier and cheaper to replace them at the same time you buy new tires. No additional charge at that time. If they install new sensors and you're not buying new tires it's $10-$15 each.
