TPMS light won't reset - checked all pressures inc spare
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gozar, Jun 3, 2019.
  1. Jun 3, 2019 at 8:36 PM
    gozar
    gozar [OP] Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    2007 Tacoma Access Cab Pre-runner
    When I start the engine, the TPMS light blinks for a while (30 seconds or so) then stays on solid.
    Here's what I've tried:
    1. Checked all pressures including spare - all set to numbers on door sticker
    2. Pressed reset button until the light blinked 3 times. When I do this the same thing happens, it blinks for a while (30 seconds or so) then stays on solid.
    3. Took it to Disco Tire, they used their scan tool to check all sensors, all were good.
    4. Disconnected the battery, waited a minute and reconnected.
    Any other ideas?
  2. Jun 5, 2019 at 9:52 PM
    11DBJR
    11DBJR Well-Known Member
    JR
    O'side, CA
    2011 4x4 Access Cab 6-speed manual
    Hey,
    Normally that means a battery is dead on the TPMS sensor itself which makes me wonder why #3 in your list came out all good.
    There's only about an 8 year life on the TPMS sensor battery itself. I've got at least one out now and can't justify the cost to replace them (Toyota wants $200 +, and I don't want to go to Discount just to have them unmount / change sensor / remount a perfectly good set of tires).
    Hope that helps.
  3. Jun 6, 2019 at 4:33 AM
    ownit
    ownit Member
    I had the same thing on my Tacoma happen recently. I had it checked out and the sensors had power, but the right rear was reading 78 psi when only 32 psi was in the tire. There was no visible damage to the sensor, don't know what went wrong...
  4. Jun 6, 2019 at 9:49 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I went through this last year, sensor batteries lasted 12 years which is a good run. In a 2007 model I also would suspect the sensors have gone bad in some way. When Disco Tire said the sensors are good, did they say anything specific? Such as, the sensors are sending a signal but that's all the tire shop could read? The sensors may be sending bad information as ownit says above. Also the sensors have to be matched to the truck's receiver or it won't recognize the signal, so maybe one or more sensors are no longer matched...? I got new sensors for $32 apiece from Rock Auto. The spare wheel may be full size but mine has a different internal contour than the 4 main wheels and requires a different sensor.
    Good luck.
