TPMS MODULE 4 OR 5 WHEEL MONITORING AND WHY ONLY 4 IF SPARE IS FULL SIZE.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wrench1225, Aug 1, 2016.
  1. Aug 1, 2016 at 9:31 PM
    Wrench1225
    Wrench1225 [OP] Well-Known Member
    jim
    NY
    SR5 4x4 db cab sb
    Rock sliders,total skids,toytec3" lift w adjustable UCA's and O ME,leaf spring pack, w toytec 2.5 rear shocks,diff.drop andBF Goodrich A/T 275 70 R16 (spare fits nicely under bed) Ultra machined Wheels, front camera. Seat covers,Bed liner spray(can't put a scratch in it) currently pricing diff.lockers with heavy duty pumpkin gears. Lastly winch w low profile bumper
    Hello everyone! Once again I'm trying to understand and determine why is it that Toyota gives you a full size spare BUT do not give you a TPMS in that wheel. But it gets better not really sure but if your truck does not have a TPMS in its spare you can purchase one from a dealer can install it on the wheel but can't program it in the TPM module. Dealer is telling me that he can't program my vehicle to take a fifth wheel's TPMS, cause the module will only accept four wheels on a TPMS.
    Ok lets say that's true. So can I purchase a Toyota TPM module for five wheel monitoring, install it in my truck and program it to accept five sensors. Dealer says he doesn't know if its possible. Now why is this ? remove a four wheel TPMS module ( if there is such a thing) and replace it with a five wheel right Or is it such a pain in the butt to do that they are trying to down play its significance.
    One other thing this one really got me.....I currently have no TPMS light on in my truck. Everything is working beautifully,(only 8K on the vehicle), with after market wheels and tires. Go in for an oil change and tire rotation and guess what? Oil change done but refused to do tire rotation due to aftermarket wheels and tires. Doesn't say that in any of their literature. The bs story I got was tires may not be balanced correctly for different axle. Hey guys last time I checked balancing is done with wheel off of the vehicle. Can someone one shed some light on this I'm an ASE TECH and I have never come across this ,and neither has anyone I work with.
    I hope I'm not getting snowballed.
  2. Aug 1, 2016 at 9:48 PM
    Htnswches
    Htnswches Well-Known Member
    E
    Lost Angels
    2006 Precummer Tacoma
    310,000 and counting
    What year is your truck? If memory serves me correct, there is 5 TPMS sensors. I once replaced all 5, and I have aftermarket wheels, changed tires a few times and what not..... Never had an issue with them until one crappes out.... Hence replaced all 5
  3. Aug 1, 2016 at 10:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It may be possible, but I doubt that it is feasible. I am sure there are many differences between the Controllers and the wiring to make it not worth the effort. Besides I seriously doubt Any Dealer would be willing to accept the responsibility for making this change. Get you a tire pressure gauge and check the spare every few months.
    You need to locate another dealer for your service needs. The aftermarket wheels and tires should make no difference, And if they are balanced it doesn't matter what position they are on the vehicle.
  4. Aug 2, 2016 at 5:42 AM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Your right Jmmyh, need to find a real dealer(gonna need luck with that) . What happen with me is I replaced the stock Dunlop spare tire with aftermarket products, thinking I would swap out the TPMS like I did with the wheels and tires that are on the truck . Except there is no TPMS for the spare. So I bought a Toyota TPMS and at this service asked them to install it on the spare and program it. I offered to pay for the install and programming. That's where the problem started. They asked me why bother . Well I do a lot of mudding and if I blow out a tire or wheel have to drive about 500 miles with spare tire before I can swap out TPMS from defective wheel, that would blow out TPMS lite, which is a bigger headache. I don't believe the dealer. I am gonna try to program the spare tire TPMS into its module. If it will not accept it then I will safely conclude there is a 4 wheel and 5 wheel module for this vehicle buy the five wheel, install it ( which is a bitch to get to) and reprogram it ( still a lot easier than trying to replace bulb off of TPMS warning. My current scanner is not compatible with Toyota do you recommend a reasonably cheap but good scanner that can do this . Really don't want to buy a Bartech. Thanks
  5. Aug 2, 2016 at 5:49 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    2nd gen Tacomas had 5 sensors up until 2008 and they went to 4 sensors in '09. Other Toyotas had 5 sensors but I don't know if that is still being done currently. My wife's '09 Highlander has 5 sensors and my 2007 FJ had 5 sensors(loved the 5 tire rotation). I think the dealer is feeding you a line that the TPM can only handle 4 sensors programmed. I would go to another dealer.
  6. Aug 2, 2016 at 5:59 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Just so you know there is no "bulb" for the TPMS.
    The TPMS Indicator is an "LED".
    Oh, For a scanner I use a Knockoff copy of Denso Techstream Software and a VMCI Cable from XHorse Electronics connected to my notebook.
    Check on ebay for information on Techstream.
    http://www.ebay.com/sch/i.html?_fro...chstream.TRS0&_nkw=Xhorse+Techstream&_sacat=0
  7. Aug 2, 2016 at 6:00 AM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    Pretty sure you won't have to worry about the bulb burning out. First, I think it's LED, second, mines been on for like 3 years and 45K miles and hasn't burned out.
  8. Aug 2, 2016 at 6:01 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    TPMS light doesn't "blow out". It can illuminate for months at a time with no issues. Common scenario in the north where you have to swap between regular tires and snow tires every winter. 500 miles is nothing.
    Toyota puts in 4 TPMS sensors because that's the minimum required by regulation.
    If you go off-roading, a tire pump and pressure gauge should be part of your basic kit.
  9. Aug 2, 2016 at 9:18 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Unfortunately my 07 has a sensor in the spare... big pain in the ass. Every winter when the temperature drops the #!*&$%@!! tmps light comes on. When driving the tires heat up but the spare stays cold... just enough pressure change to trigger the #!*&$%@!! light. :annoyed: Toyota probably got tired of dealing with it and decided the spare sensor wasn't worth the headache.
  10. Aug 3, 2016 at 7:55 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Thanks OFFROAD ! Never thought of that and it makes sense. What I am going to do is put the TMPS on the spare put the spare in the tire rotation and program it into the module. The left front wheel that now becomes the spare I will not program its TPMS into the module and just keep my scanner with me in the truck, in the event I get a flat or blowout.
  11. Aug 4, 2016 at 4:58 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Just my .02 cents here but that tpms light would have to literally be on for years before it burns out.... Seems like a whole lot of work for a irrelevant dash light to not be on in the off chance u blow a tire off roading.
  12. Aug 4, 2016 at 5:49 AM
    FooBird
    FooBird Well-Known Member
    Kirkland, WA
    '14 DCSB 4x4 TRD Off Road
    My 2014 has room for 5 tires but only 4 sensors (plenty of experience with something wrong in my system). I'm sure Toyota can add that fifth one on but they'll charge you for it. I think a sensor through them is $200 plus mounting. Also, the steel spare would require a different sensor than the rest of the truck.
    Personally, I'd rather have zero sensors and do it like people did for 100 years - be responsible and periodically check your pressure. Eliminate the expensive nanny system and let me do what I will.
    rmepilot likes this.
  13. Aug 15, 2016 at 1:55 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Got pissed off at Toyota borrowed an Autel 601 scanner put the full size spare w Ulta wheel and Toyota sensor in the rotation. Got the ECU to accept 4 wheels , left the spare position blank in the ECU and it works. After all Toyota initially gave me a factory TPMS less spare tire . After talking with several tech's , the consensus is the spare tire gives Tacoma most headaches because the temperature of that wheel is always lower than the other four , especially in the winter. Remember Tacoma's TPMS is a direct system meaning it measures air pressure , temperature and (purportedly) wheel speed from ABS sensors and module. So now I have a full size spare w a TPMS in it ready to go should I need it and I can include it in the rotation all I have to do now is hit the reset button cause the ECU knows all my sensors.
  14. Aug 15, 2016 at 2:21 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    If you want that spare to be monitored by the TPMS system (whether in use or as a spare), you need to program that 5th slot in the ECU. If the ECU has a blank 5th slot, it won't monitor that slot.
  15. Aug 15, 2016 at 2:39 PM
    Wrench1225
    jim
    NY
    SR5 4x4 db cab sb
    Correct can have ECU monitor spare but declined. Too much of a headache by this systems faults
