TPMS, New TRD Beadlock Wheels
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bielanskia, Dec 18, 2015.
  1. Dec 18, 2015 at 10:55 AM
    bielanskia
    bielanskia [OP] Active Member
    Adam
    Chowchilla, CA
    2016 Silver Tacoma TRD OR
    Man I am getting the run around. TPMS part 42607-06011
    These are not working on the 2016 Tacoma. Toyota says they will. TRD Wheels need 20 degree stem.
    Light stays on and toyota tech is unable to program them... ideas???!
  2. Dec 18, 2015 at 10:56 AM
    bielanskia
    Adam
    Chowchilla, CA
    He registers them in the computer but ecu do not recognize them. It says Judging on status.
    Just a little annoying!
  3. Dec 18, 2015 at 1:51 PM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    Are these the TPMS out of your factory off-road wheels? Strange, there's been several folks that have switched their factory TPMS to TRD beadlocks with no issues.
    ScTuna likes this.
  4. Dec 18, 2015 at 1:53 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I just had all 5 of mine done yesterday at Toyota for my Bronze Beadlocks without issue?
  5. Dec 18, 2015 at 2:02 PM
    bielanskia
    Adam
    Chowchilla, CA
    Just did that. I switched them. Now i have to go back to Toyota to have them update TPMS back to stock numbers.
  6. Dec 18, 2015 at 2:02 PM
    bielanskia
    Adam
    Chowchilla, CA
    Sounds like dealer is trying to nickel and dime me.
  7. Dec 18, 2015 at 7:29 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    You need sensors with PMV-C015 on them.
  8. Dec 22, 2015 at 5:55 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    What do you mean by this?
    Did they take the TPMS sensors out of the stock TRD Off Road wheels and put them in the beadlocks? If so, that should work. If it is an older set of TPMS without PMV-C015 on them, they will not work. Learned this the hard way myself.
  9. Mar 10, 2016 at 4:02 PM
    hmsailor
    hmsailor Well-Known Member
    Florida
    2015 DCSB 4X4 TRD spORt
    will TPMS from a trd sport 17 inch alloy wheel fit in a trd trail team 16 inch wheel?
    and does it need to be re calibrated?
  10. Mar 10, 2016 at 4:07 PM
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Just put some trd wheels on my 16 and made a tpms pipe bomb and it works fantastic!!!! Threw it in the storage compartment under the small back seats in my access cab! Cost me about $18 in materials!
    Fireme, HARLEY410, andyr562 and 2 others like this.
  11. Mar 10, 2016 at 4:18 PM
    hmsailor
    Florida
    this should take care of the light?
    moe2o4[QUOTED] likes this.
  12. Mar 10, 2016 at 5:07 PM
    moe2o4
    Corey
    Pittsburgh PA
    Yep its out in my truck! Inflated the tube to 32lbs and magic!
  13. Mar 10, 2016 at 5:52 PM
    hmsailor
    Florida
    thats clever but it still doesnt answer my question lol
  14. Mar 10, 2016 at 6:12 PM
    TacoWocko
    TacoWocko Well-Known Member
    Paul
    NC
    2016 White Tacoma OR 4x4 LB
    Husky mats OEM bed mat Mobtown Sliders CustomCarGrill OME 887 w/Dakars LR UCAs SumoSprings
    This is freaking awesome! I don't know why I didn't think about this, but I'm glad you did. :cheers:
  15. Mar 10, 2016 at 6:21 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    I had TRD wheels included as a part of my "deal" when i purchased my truck.
    Tech also said i needed 20degree sensors for the 17in wheels. They installed what they had in stock and it would not "handshake" with the truck (they tried 5 different wheel sensors). They eventually found out the '16 wheel sensors use a different way to measure pressure and had to order new ones from toyota. Once the new ones came in it took about a hour and they had me all setup to go.
  16. Mar 10, 2016 at 6:25 PM
    Mjordan
    Mjordan Well-Known Member
    Michael
    Denver, Colorado
    2015 Super White DCSB 4WD TRD Offroad
    TRD Beadlock Wheels, Bilstein 5100s all around, BFG K02 265/75R16, 20% tint, WeatherTech Floormats, LED Interior Lights, Tailgate lock, Salex Organizers, Shorty 5" Antenna, LED license plate lights
    What's the point in doing this and not installing on the new tires?
  17. Mar 10, 2016 at 6:28 PM
    dwaltdtx
    dwaltdtx Well-Known Member
    David
    DFW, TX
    Saves cost on new tpms if old won't work with new wheels. Keeps light off if you air down for off road.
    moe2o4 likes this.
  18. Mar 10, 2016 at 7:11 PM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    I wish there was a way to turn off tpms or disable the light.
  19. Mar 10, 2016 at 7:50 PM
    ScTuna
    ScTuna Well-Known Member
    Texas
    2016 Tacoma
    It should. All the alloy wheels take the same tpms 20'
  20. Mar 10, 2016 at 9:18 PM
    moe2o4
    Corey
    Pittsburgh PA
    The problem with my case is I went from 16" Steel wheels to 16" alloy wheels and my sensors won't fit the alloys. So decided to do the pipe and it works great. I always check my tire pressure regularly, every few days so I'm aware of what's in the tires and the sensors are useless to me. All it does is keep the annoying light off. Plus if I ever decide to buy another set of tires and throw on my steel wheels for the winter I don't have to screw with the tpms sensors, just get regular valve stems and just swap the wheels at home!
