TPMS Not Syncing After Tire Rotatuon
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baltimorebirds2, Mar 20, 2023.
  1. Mar 20, 2023 at 5:59 AM
    baltimorebirds2
    baltimorebirds2 [OP] tacomama
    Brooks
    Maryland, United States
    2018 MGM Tacoma TRD Sport DCSB 4x4
    TRD Pro 17” Wheels, Toyo Open Country AT3 33s” (255/80/R17), Hooke Road Offroad Roof Rack, LEDs (Low Beams, High Beams, Fog Lights, Interior Lights, Reverse Lights, License Plate Lights), Diode Dynamics SS3 Sport Fog Lights (Yellow), Sequential Turn Signals, OME Nitrocharger Plus, OME 4004's & HS 0.5 Spacer for 3" Lift, JBA UCA, Icon RXT Option 2 Leaf Springs 2.25" Lift, Yukon Clamshell Bushing, Alpine ILX W-650 Stereo, Infinity Primus 6004a Amplifier (140w*2), Sound Ordnance M75-4 Amplifier (75w*4), Infinity Kappa 693C Component 6x9 Speakers, Infinity Kappa 63XF 6.5 Speakers, TRD Shift Knob, Black Emblem Overlays, TRD Grille Badge, OEM Door Sill Protectors, Driver’s Seat Jackers, Pop and Lock Power Tailgate Lock, AJT Designs start button and trim, 4x4 knob, shifter trim, and cupholder trim, MESO Customs Vent Rings and Door Handle Covers, Gasshole, Drop Stops, AC Drain Mod, Bed Lights, Rough Country Roll Up Tonneau Cover, Window Tint, KDMAX Tune
    Hey all, have a quick question for you guys. So when I got my Toyo AT3’s and wheels I had them install new tpms sensors in the new wheels, because I wanted to sell the old wheels and tires together. So once they programmed the new sensors they’ve been great for the past 5000 miles. Then I rotated the tires when I did my oil change, and now the sensors aren’t reading/syncing. And to clarify, I am aware of the TPMS set button. With the truck running on park I press and held the button for a few seconds. TPMS light flashed 3 times. Then continued to drive some and nothing. Wondering if I have to drive further. Anyways, am I missing anything in the re-syncing procedure after rotating? Thanks,
    Brooks
  2. Mar 20, 2023 at 6:02 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, sometimes it take pretty long drive for them to read.
    musicisevil likes this.
  3. Mar 20, 2023 at 6:15 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Since I do a 5 tire rotation, I just have Discount relearn each tire/TPMS location for the 4 tires rolling.
    Then when I get home, I toss the spare in the garage and go for a spin. Sometimes it takes 5 miles, sometimes 20 miles. Eventually all is sync'd and I can put my spare back up under the truck for another 5k miles.
    baltimorebirds2[OP] likes this.
  4. Mar 20, 2023 at 7:14 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Try the button with the truck on but not running. Then be patient and drive.
    If after a long time nothing comes back the locating functionality is likely broken and you can choose to replace them or manually program their new locations.
  5. Mar 20, 2023 at 7:31 AM
    baltimorebirds2
    Brooks
    Thanks for the input. By saying you’re having discount reprogram them, are you meaning that you have to get them to reprogram each tire’s new location after you rotate? Like your tpms button in your truck doesn’t fix it?
  6. Mar 20, 2023 at 7:32 AM
    baltimorebirds2
    Brooks
    I’ll have to try the button again and drive a good bit and be patient. I think I remember the sensors taking a good while to register when I first got them put on. Hopefully no big deal here.
  7. Mar 20, 2023 at 7:37 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Are you not seeing the TPMS window in the dash showing 4 psi values?
    When I rotate all four wheels my truck sees all four sensors and shows PSI on the dash.
    Yes.
    Please read the correct procedure in the OM, after that procedure it does take some time for the truck to see the
  8. Mar 20, 2023 at 7:48 AM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Make sure the engine is not running when pressing the reset button.
    Assuming your sensors did not die.. After reset, sensors are in Judging state. Sensors position should be determined within 10-20 miles of variable speed driving.
  9. Mar 20, 2023 at 9:04 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    This doesn’t necessarily address your initial question but this one^:
    3rd gens can only store 4 sensor IDs. The guy you quoted does a 5 tire rotation, so each time he rotates he has to remove the ID of the tire becoming his new spare from the ecu and add the ID of the tire coming out of spare.
    The TPMs button under the dash simply learns location. Works for 4 tires but not 5
  10. Mar 20, 2023 at 9:59 AM
    baltimorebirds2
    Brooks
    Thanks for clarifying. Would you happen to know if our trucks’ spares come with a tpms sensor in there from the factory? Because if not then that shouldn’t be an issue here because I didn’t have them put a sensor in the spare tire, to my knowledge at least. That tire is stock size and I have 33s” anyway, so not like I’d use it unless if there’s an extreme emergency, but in the front end only.
  11. Mar 20, 2023 at 10:13 AM
    na8rboy
    WI
    None in spare, system only supports 4 sensors.
  12. Mar 20, 2023 at 10:16 AM
    baltimorebirds2
    Brooks
    Gotcha, thanks.
  13. Mar 20, 2023 at 12:33 PM
    musicisevil
    Alaska
    2019 TRD Sport
    Yea the spare definitely isn’t part of your problem. I already have this page uploaded to Imgur from a previous comment, so I’ll just add it here too.
    I’d try everything step by step again and try and find a neighborhood to scoot around in to maintain 25mph.
  14. Mar 21, 2023 at 3:55 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    Although you probably won't have too much of an issue if you ran your stock sized spare with your 33s, I personally wouldn't run it on the rear or while in 4wd as a mix.
    I would however suggest looking into 33" tire for your spare at some point.
    I dropped the dime upfront for 5 matching tires, wheels, w/TPMS so I could maximise my tire life by rotating in a 5th tire. And of course, this spare makes no difference to the truck when in use.
  15. Mar 23, 2023 at 9:53 PM
    baltimorebirds2
    Brooks
    Thanks for the help guys. Sensors finally synced and are reading now. Just need to reset it when tires are at cold pressure. Thanks!
