TPMS Options for Multiple Wheel Sets (I.e., Winter/Summer, Street/Off-Road, etc.)
Discussion in 'Wheels & Tires' started by Hot Taco, Jan 9, 2013.
  1. Jan 22, 2013 at 3:56 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Keep in mind FMVSS No. 138 comes from the TREAD Act, which was passed in response to the Firestone tread separation issues on Ford Explorers. The original intent of TPMS was therefore to prevent tire destruction through prolonged underinflation (i.e. lack of maintenance by the driver), not to detect punctures.
  2. Jan 22, 2013 at 9:35 PM
    PnoyBOS5
    PnoyBOS5 Well-Known Member
    kevin
    CA
    2013 PRERUNNER
    Maxtrac 4'' Spindes -Bilsteins 5100 @ 1.75" - All Pro Expo Leaf Pack - Extended Rear Shocks - PC 5001 wheels - 285/70/17 Goodyear Duratracs - Debadged -Red emblem - AFE Pro Dry-S Filter
    Extremely stupid question that is making my brain hurt even after reading the forum and manual.
    If I replace my tires do I need to move the chip to the new tire, or does this problem only apply when I change my wheels?
  3. Jan 23, 2013 at 4:00 AM
    Hot Taco
    Hot Taco [OP] Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    This only applies if you replace your wheels as the sensor is mounted to your wheels and not the tires.
    When you go to get your new tires put on, the tire shop *should* install a sensor mainenance kit which is pretty much just a new rubber washer to ensure no air leaks.
    Note that the sensors have batteries in them that can last anywhere from 3 to 10 years. If you're vehicle is approaching the 10 year mark, it might be wise to replace the sensors as long as you're replacing the tires so you don't end-up doing that a short time down the road. (The batteries are not replaceable, the whole unit must get replaced.)
  4. Jan 23, 2013 at 4:25 AM
    Dustyroades
    Dustyroades Well-Known Member
    London, Ontario
    2019 TRD Sport
    Can we all agree that the government has created a non-solution to a non-problem, and forced us to become experts on a largely useless system to prevent an annoying light from flashing?
    Kodiak420 and Hayrider like this.
  5. Jan 23, 2013 at 5:23 AM
    Hot Taco
    Richfield, WI
    I'm by no means a fan of"big government" and would like them to leave me alone as much aspossible, but I have mixed feelings about TPMS.
    For one, you have toconsider that the vast majority of automobile owners are not automobileenthusiasts. In other words, it's only a small number of automobile owners that spend a lot oftime obsessing about their vehicles and spend a lot of time online learning aboutthem. The average vehicle owner just gets in his car and drives, and doesn'tthink much about maintenance until something actually breaks (hence the wholeFord Explorer tire issue). So while the TPMS may be viewed as pointless by autoenthusiasts who are typically aware of things like tire pressure, the whole point of the system is to be annoying to anon-enthusiast and force him to go get his car looked at because there actuallyis a problem... and in the case of Ford, a life threatening problem.
    I'm a computer programmerby trade, and the whole point of computer systems (and technology in general) is to theoretically make ourlives easier by performing tasks we don't want to do. One task I don't want todo is check my tire pressure every day, so I'm pretty content with the ideathat my car can check it's own tire pressure and let me know if something iswrong. However, to your point, if the TPMS only checks tire pressure whenthere's a full moon (or whatever), it's usefulness seems quite limited comparedto what it could be.
    I'd like to know how oftenour vehicle's ECU does check the tire pressure. Does it do it each timethe car is started? Or every 5 starts? Or??? The answer is probably on the Interweb somewhere...
  6. Jan 23, 2013 at 5:41 AM
    Dustyroades
    London, Ontario
    2019 TRD Sport
    Does anyone know with any certainty whether TPMS can detect punctures that result in relatively rapid deflation? Perhaps it queries the sensors periodically but if there is a rapid change the sensors send an "emergency" signal?
    Because if it can't, then the system is very close to worthless.
  7. Jan 23, 2013 at 4:07 PM
    KenLyns
    Belly of the Beast
    ^http://www.nhtsa.gov/cars/rules/rulings/tpmsfinalrule.6/tpmsfinalrule.6.html#IV_1
    It can't. The regs require the TPMS to detect a tire that has fallen 25% below the doorjamb sticker pressure within 20 minutes.
    Hyundai's comments during the rulemaking process suggests TPMS sensor sampling takes 3 minutes, and multiple samples are needed to overcome data errors, so a 20 minute grace period is necessary.
    Useless to us. However, most Americans are car-illiterate, don't check tire pressure regularly and don't adjust for temperature variations. The same folks also need a brake interlock to shift out of Park, seatbelt chime, automatic headlights, burnt lightbulb warning... Before you snicker, keep in mind Toyota's business depends on these folks to snap up boatloads of beige Corollas every year.
    NHTSA expects TPMS to reduce traffic fatalities by 119-121 each year in the US.
  8. Jan 24, 2013 at 4:14 AM
    Hot2na
    Hot2na Well-Known Member
    Screw That ! I just went with the PIPE BOMB option ...it works great in all kinds of weather...i check my tire pressure all the time since I air down & up while surf fishing the beaches...
    I plan on keeping the truck till the wheels fall off.....
    It is not DIFFICULT or expensive to make the pipe bomb...
  9. Jan 24, 2013 at 9:34 AM
    KenLyns
    Belly of the Beast
    If they haven't already, the FBI will surely be tracking this site now, what with all pro-gun talks and pipe bomb instructions. :laugh:
    Might as well add a few more buzzwords...
    Al Qaeda
    Obama bin Laden
    Waco Tacos
    Murdered out
    Total chaos
    Crom likes this.
  10. Jan 27, 2013 at 11:59 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Cute, real cute! Now I have to wea my tin foil hat while surfing TW....
    Good thread though, I have a set of new wheels in my garage for 2 months, and 4 new DuraTrac tires waiting to be mounted on them, but the whole TPMS issue is stalling me.
    I will not go the route where I need to visit a dealer or tire shop any time I want to switch to the other set of wheels because in my case the whole issue was a set of wheels for off-road and another set for highway trips and the ability to swap back and forth weekly if I want to. So for Me, if I DO get TPMS sensors for the new wheels they they MUST be programmable to clone the factory TMPS. Thus both sets are ready to run all the time.
  11. Jan 27, 2013 at 12:26 PM
    Hot Taco
    Richfield, WI
    LOL!
    I'm hoping that as more and more people read this thread, they'll start requesting programmable sensors form the various online wheel stores so eventually we can get to the point where the cloned TPMS sensor is easy to get.
    I think it's silly that many wheel shops will sell you "OEM sensors" to the tune of $400 (like at CARiD.com) which also means you'll have to spend a bunch more money getting the dealer to reprogram your ECU all the time... something the wheel shop web sites don't mention.
    It'd be of great advantage to both the wheel shop and the customer if the wheel shop just stocked a few programmable sensors rather than trying to stock OEM sensors for all various brands. Maybe it's going to take the consumers asking for programmable sensors to get the stores to wise-up!
  12. Jan 27, 2013 at 12:36 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good thread... got a question. Has anyone here had to get the sensor batteries replaced yet? Just wondering how much we'll have to shell out for that. :rolleyes:
  13. Jan 27, 2013 at 12:42 PM
    Hot Taco
    Richfield, WI
    The batteries are not replaceable, you have to replace the entire sensor. The programmable Schrader EZ-Sensor sensors are $50 each on Amazon.com where as the OEM sensors are typically much more.
    What would be really fun is if you get new tires put on and then your sensor batteries dies shortly there after. If you've had your car for more than 5 years and you're putting tires on, you might want to just replace the sensors anyway since the battery life is supposedly anywhere from 3 to 7 years.
  14. Jan 27, 2013 at 5:13 PM
    Hot Taco
    Richfield, WI
    FYI, I just got a response from CARiD.com and they do not carry programmable TPMS sensors. That's a bummer because they have a lot of nice wheels.
  15. Jan 27, 2013 at 9:04 PM
    #35
    KenLyns
    Belly of the Beast
    Interestingly, I got the Schraeder EZ Sensor with my Konigs. I think the shop chose the EZ Sensor simply so they can carry just one sensor that works with all the car brands.
  16. Jan 27, 2013 at 9:29 PM
    #36
    OffroadToy
    Nope... when my sensors quit working they'll be replaced with a $5.99 tire gauge.
  17. Feb 16, 2013 at 8:54 AM
    #37
    Dennis7234
    Dennis7234 Member
    Off-Road Package
    My '13 Tacoma came with a full size spare tire on a plain steel wheel. Discount Tire in Austin, TX removed the spare tire from the steel wheel, mounted and balanced it on an aluminum wheel I’d bought from a forum member, and reprogrammed all five wheels for $10. Such a deal!
  18. Feb 16, 2013 at 11:13 AM
    #38
    KenLyns
    Belly of the Beast
    I thought Toyota deleted the spare tire TPMS sensor from 2008 onwards.
  19. Feb 17, 2013 at 10:21 AM
    #39
    chris5255
    chris5255 Me mber
    Renton WA
    12 Tacoma DCLB TRD Sport-'07 FJ Cruiser
    BAMF Sliders Fog light switch mod, Pelfreybilt Front bumper, Warn Zeon10 winch pinstriping for speed
    All 5 wheels on my '12 were stock rims with sensors.
  20. Feb 20, 2013 at 1:34 PM
    #40
    Cobalt719
    Cobalt719 Well-Known Member
    Chesapeake, VA
    '12 4 Banger PreRunner DC
    LED Interior Lights, Tailgate Anit-Theft Mod, OEM Skid Plate, Aftermarket Fogs, Tow Hitch
    Do factory alloy tpms generally fit aftermarket rims?
