TPMS Options for Multiple Wheel Sets (I.e., Winter/Summer, Street/Off-Road, etc.)
Discussion in 'Wheels & Tires' started by Hot Taco, Jan 9, 2013.
  1. Feb 20, 2013 at 4:48 PM
    #41
    Hot Taco
    Hot Taco [OP] Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks Bilstein Shocks/Struts DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    I don't know the answer for sure since I've never tried putting OEM sensors in aftermarket wheels, but I'm pretty sure the sensors will work. After all, it's highly likely that Toyota doesn't actually manufacturer the wheels anyway and so there really isn't much that is special about them.
    I don't think you can use the sensors from steel wheels on aluminum wheels, due to a difference in the angle that the valve stem mounts to the sensor, but I think that a sensor on an aluminum wheel should fit any other aluminum wheel.
  2. Feb 20, 2013 at 6:08 PM
    #42
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    Yes, generally. Keep in mind there's always a small chance of failure when re-using a sensor. This is true even if you are moving a sensor from one set of factory wheels to another. To improve your chances, the mechanic should always use a sensor service kit and torque the sensor to spec with a micro torque wrench.
    One of the OEM sensors started leaking when transferred to my Konig Countersteers. To avoid problems later, I bought four new sensors. Others here reported no problems transferring the OEM sensors to the Konigs.
  3. Feb 20, 2013 at 6:25 PM
    #43
    jokerj80
    jokerj80 Well-Known Member
    Jeremy
    O..H!!
    12 tacoma quad cab
    SS bull bar, K&N air filter, Pioneer avh8400, Kicker amp and sub, window tint, bug shield, T-Rex grille, Hella Ralleye 1000 behind grille, lund genesis bed cover
    I have a question....i bought some trail teams trd wheels for my sr5 and im swapping tires. Does the original tpms go into the trd wheels? The dealership says yes.
  4. Feb 20, 2013 at 7:22 PM
    #44
    KenLyns
    Belly of the Beast
    ^The dealership is correct, with the same caveats as I mentioned above.
  5. Feb 20, 2013 at 9:27 PM
    #45
    jokerj80
    Jeremy
    O..H!!
    12 tacoma quad cab
    Thanks for the reply. I feel better now. Lol
  6. Feb 21, 2013 at 8:30 AM
    #46
    Cobalt719
    Cobalt719 Well-Known Member
    Chesapeake, VA
    '12 4 Banger PreRunner DC
    LED Interior Lights, Tailgate Anit-Theft Mod, OEM Skid Plate, Aftermarket Fogs, Tow Hitch
    Thanks to you both
  7. Feb 21, 2013 at 4:18 PM
    #47
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Guys,
    I just wanted to chime in here. I bought a set of the BFD FN wheels and am planning on mounting the tires soon. I originally sourced a set of '13 steel take-offs with TPMS from a local craigslist and was planning on taking those off, putting them into my new wheels and having them reprogrammed at Discount Tire. My plan was to have the ability to switch back and forth from BFDs to stock whenever I took the truck back to Toyota. However, I found out two things... 1) the TPMS sensors on the steel wheels are at a 40 degree angle so the only way to mount it is "upside down" (ie. 180 degree turn) which is fine until a shop dismounts the tire and would then break off the sensor. 2. Once the new sensors are reprogrammed, the original sensors in the OEM wheels are rendered useless and you will STILL have the TPMS light come on after you swap back to stock.
    I spoke with Dustin @ FN wheels from whom I bought the BFDs from about my dilemna and he told me to check out Schrader international who makes programmable TPMS sensors. I gave my local schrader office a call and he will try to "replicate" my stock sensors and will see if that works. I will prob have all this done next week so I will report back
    Edwin
  8. Feb 21, 2013 at 5:25 PM
    #48
    KenLyns
    Belly of the Beast
    Why?
  9. Feb 21, 2013 at 5:30 PM
    #49
    m32
    Edwin
    2013 DCSB TRD
    I try not to give the dealer a chance to mess up my mods. Been there done that too many times
    Edwin
  10. Mar 4, 2013 at 11:35 PM
    #50
    paxman
    paxman New Member
    08 tacoma base
    New to this forum. A lot of good info. thanks for sharing.
    I have a 2008 tacoma access cab, 5 Lug
    Need some clarification HOT Taco:
    If you get new wheels, you need to get new TPMS sensors. Tire Rack sells the sensors and will install them if purchased.
    My question is if I do go through Tire Rack, I will need to provide them with the factory code so that they can program the new sensor?
    Next question: The reset button under my steering column is for the TPMS. Will that reset the new TPMS sensors when i install them on my truck?
    Thanks for sharing all of your knowledge with us
    paxman
  11. Mar 5, 2013 at 6:05 AM
    #51
    Hot Taco
    Richfield, WI
    That is what I was told in my email correspondence with the Tire Rack. I have not purchased wheels with them recently, so I haven't gone through the process yet myself. This obviously means that you need to know the TPMS sensor IDs which means a trip to the dealer or a local tire shop that has a tool to read the codes (provided that you don't own such a tool.)
    Hmmm... never heard of such a button. My truck is much older and has no such button. Can anyone else with a newer truck chime in?
  12. Mar 5, 2013 at 6:07 AM
    #52
    m32
    Edwin
    2013 DCSB TRD
    On my 13, there is a reset button but I haven't read up on how it works
    Edwin
  13. Mar 5, 2013 at 6:12 AM
    #53
    Hot Taco
    Richfield, WI
    Is the reset button like the one in this article?
    http://www.brakeandfrontend.com/issue/article.aspx?contentid=85735
    If so, it doesn't help us in our quest to get two sets of wheels working with our vehicles TPMS...
  14. Mar 5, 2013 at 1:13 PM
    #54
    Bistineau
    Bistineau Well-Known Member
    Bossier Parish La.
    2013 Prerunner SR5
    Para-bolic mirrors on the outside rearveiws.
    I think that button is used when you want to run a different pressure than what it is originaly set for. Say the tires are originaly set for 35 PSI and you want to run 25 PSI. After adjusting the tires to the new pressure, you press the reset to store the new pressure so the system isn't warning of low pressure, it just resets itself to the new pressure.
    Another solution to the TPMS light problems with a different set of tires and wheels, is to carry the TPMS equiped tires in the bed of the truck when the other wheels are on. You will always then have 5 spares if needed.
  15. Mar 6, 2013 at 6:15 AM
    #55
    paxman
    paxman New Member
    08 tacoma base
    This is exactly what the button looks like and is located. Thanks taco for the clarification. So I still would need to get the code from the dealer for the new tpms.
    Thanks for the info
  16. Mar 7, 2013 at 5:50 PM
    #56
    choyt
    choyt Well-Known Member
    wayne
    new york
    2015 tacoma
    Maybe someone can help me out, first off I have a 2012 base 4x4 with steel wheels and just changed them to 2013 TRD OR wheels and my tpms light DIDN'T come on , is this ok?
  17. Mar 7, 2013 at 7:42 PM
    #57
    Hot Taco
    Richfield, WI
    Do you still have the old wheels? Are they sitting near where your truck is parked? If so, your ECU *may* be reading the signal off the old wheels. However, if you got rid of your old wheels and your TPMS light isn't coming on, I'm guessing it will eventually. If it never does come on, then I'm stumped, too!
  18. Mar 8, 2013 at 1:26 PM
    #58
    choyt
    wayne
    new york
    2015 tacoma
    ^^^ I sure hope it doesn't come on
  19. Mar 9, 2013 at 7:28 AM
    #59
    Hollywood22
    Hollywood22 Wranglin the Badger
    Johnny
    Southern Ontario
    Generation X
    OME Lift, LR UCA's
    Excellent write up.....thanks for taking the time.....cheers.
  20. Mar 9, 2013 at 4:20 PM
    #60
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I ordered a set of these same wheels (love the style!) but they are still sitting in my garage next to a stack of for new DuraTrac tires because this TPMS nightmare. I sure wish Toyota had designed thier TPMS like Volkswagen (I have two sets of wheels/tires and it recognizes either set without a trip to the dealer).
    Which TPMS wheel sensorsdid you purchase? I have to do this soon, hate seeing new wheels and tires just sitting there and my ugly stockers for the word to see on my lifted truck...
