TPMS Options for Multiple Wheel Sets (I.e., Winter/Summer, Street/Off-Road, etc.)
Discussion in 'Wheels & Tires' started by Hot Taco, Jan 9, 2013.
  1. Mar 12, 2013 at 9:10 PM
    #61
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Just do as I did and bite the bullet for the EZ sensors. At least you go into it knowing it will be a problem as opposed to when you throw the winter set back on the taco.
  2. Mar 17, 2013 at 7:52 AM
    #62
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Awesome post. +1 OP
  3. Mar 17, 2013 at 10:08 AM
    #63
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  4. Mar 19, 2013 at 1:00 PM
    #64
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Thanks for the advice guys. I want to get the Schrarer TPMS.
  5. Mar 24, 2013 at 8:45 AM
    #65
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    I have a question. I have a set of original wheels and tires off my 2010 17" trd sport for sale. A member that has stellies wants to buy my wheels and tires and use his tpms. Dealership told him that the tpms that come in the steel wheels won't fit on the TRD 17" wheels.
    :notsure:
  6. Mar 24, 2013 at 11:57 AM
    #66
    KenLyns
    Belly of the Beast
    ^Correct
  7. Apr 13, 2013 at 11:16 PM
    #67
    hoarder23
    Shay
    NJ
    Scratches
    After dealing with getting a set of EZ Sensors for my new wheels I would say before you get these do some research on which shops locally can program them. I got the wheels mounted and balanced at Firestone where I have a lifetime alignment, but they were unable to program the sensors. After going to the dealership and a few other local places and making some calls I was unable to find a shop with the equipment to clone the stock set. I went on Bartec's website and emailed them, within a day I got a call from Michael, their product manager. After explaining what I was trying to do he told me to go to WhyTPMS to find a local dealer and call him back if I had any more issues. The website led me to a local shop that was able to clone the sensors with no issues.
    Bottom Line: If you are going to clone your TPMS with a programmable set, find a local shop that is capable of programming them prior to buying and if possible get the serial numbers of your current sensors prior to purchase and have the sensors programmed by the seller.
  8. Apr 16, 2013 at 5:12 PM
    #68
    CJBro
    CJBro Member
    Bozeman, MT
    '07 Black SR5 4x4
    Stawk
    A few things I'd like to add as an employee of a tire shop in montana. I'd pretty sure it's illegal to tamper with the TPMS system in any way, including removing the TPMS light bulb on the dash, and it just recently became illegal for tire shops (at least here) to mount up a set of tires to wheels without TPMS sensors AND put them on a vehicle that has a TPMS system.
    That being said, depending on the OEM wheels and the second set of wheels, we can often swap the TPMS sensors over, and we can certainly reprogram your vehicle's ECU to read new sensors, provided they are compatible. We provide the latter service for free and only takes a couple of minutes.
  9. Apr 16, 2013 at 5:21 PM
    #69
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Do the sensors have fit problems with some wheels or valve stems? When I swapped my rims, the guy told me there was a possibility that the sensors might not fit the new wheels. I have the original stems in the new wheels right now.
  10. Apr 19, 2013 at 9:43 AM
    #70
    Butl3rM0nk3y
    Butl3rM0nk3y Well-Known Member
    Brandon
    Loveland, CO
    17 Inferno TRD OR 4x4
    Soft-Topper Bed Mat Bed bolt D-Rings
    I ordered some new wheels from Discount Tire and while speaking to the service writer, he told me they have a new tool for doing the programmable TPMS sensors in which they dont need to read the codes from the inside of the old rim first, he can read them with the tool. That allows them to reprogram the EZ-Sensors on the fly during the install of my new wheels with my summer tires on them and not have to disrupt the stock set that already has the snow tires.
  11. May 18, 2013 at 1:32 PM
    #71
    Hot Taco
    Hot Taco [OP] Well-Known Member
    Richfield, WI
    2013 Base Regular Cab
    Beefed Taco 3" Lowering Blocks DJM 3" Front Lowering Kit Custom C-Notch Intermittent Wipers LED tail lights
    It's been about 5 months since I wrote the original post regarding TPMS sensors and last week I finally got some new summer wheels that needed tires. I ordered tires from Discount Tire Direct, which is about an hour from my house, specifically because I was told they can "clone" sensors. (I was told this by one of their online reps.) Unfortunately, that isn't the case... at least not for the store I visited in Waukesha, WI.
    To make a long store short, neither the manager nor the two technicians that installed my tires knew what cloning is. Although everyone was very nice, they seemed to treat me like I was just another customer that read something on the Internet and didn't know what I was talking about.
    Instead of the Schrader EZ-Sensors I asked for, they installed VDO Redi-Sensors. The VDO sensors are not programmable. I didn't realize what they had done until after they had already mounted the tires and I asked the technician to show me the tool he used to clone the sensors (at which point he was clearly confused about what I was asking because he didn't understand.) Feeling like I wasn't getting through to them, I pretty much had no choice but to go home with sensors I didn't want and a sensor issue I was trying hard to avoid.
    I called Discount Tire's help line a few minutes ago and they're going to have a regional manager call me to discuss the issue. Being late in the day on Saturday, it probably won't be until Monday that I hear from them.
    Sensor issue aside, the rest of my experience at the Discount Tire location I went to was good. The shop was very clean, service was fast and friendly, and the prices seem competitive. I'm just miffed that now I still need to figure-out a solution for keeping my TPMS light off when I swap wheels :mad:
  12. May 19, 2013 at 1:17 AM
    #72
    hoarder23
    Shay
    NJ
    Scratches
    www.whytpms.com will point you towards the shop near you that can clone sensors and discount should be good about fixing the issue
  13. May 19, 2013 at 2:10 AM
    #73
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    diable the whole system. easy and works great. no light, no sensors, no hassle.
    Hayrider likes this.
  14. Jun 4, 2013 at 6:16 PM
    #74
    YotatechMatt
    YotatechMatt Active Member
    Moncton, NB
    Toyota/Lexus does have a switch on some higher end models that allows you to change between 2 sets of registered wheel/sensor assemblies.
  15. Jun 5, 2013 at 4:15 AM
    #75
    Kilted Taco
    Kilted Taco Member
    Woodbridge VA
    2009 Speedway Blue XRunner
    Do you know which models?
    If we could figure out the part # for the upgraded modules we could all order them and switch them out and not have nearly as big an issue.
    G.T. likes this.
  16. Jun 5, 2013 at 5:16 AM
    #76
    merkman
    merkman Well-Known Member
    Etna, NH
    2012 green
    Hey Mike,
    How do you disable it? That would make the most sense to me...thanks
  17. Jun 5, 2013 at 5:23 AM
    #77
    Hot Taco
    Richfield, WI
    I'm sure it wouldn't be that simple. The ECU (computer) in the Tacoma isn't likely equipped with whatever port or capability that the other models have.
  18. Jun 6, 2013 at 5:50 PM
    #78
    Hot Taco
    Richfield, WI
    An update on my Discount Tire experience...
    I was finally able to get back to Discount Tire today to have them swap-out the VDO Redi-Sensors that they incorrectly installed with Schrader EZ-Sensors. Everything went smoothly as far as I can tell and as it turns out, the Schrader sensors are considerably less expensive than the VDO sensors (probably because they don't have metal valve stems). Because of that, I got money back for the sensors and Discount Tire compensated me for my gas because I live pretty far away.
    The manager was concerned that my TPMS light might go on during my trip home since I now have two sets of tires with the same sensor IDs, but the light didn't come on.
    Despite the original issue, Discount Tire's customer service is top-notch and at least I've finally confirmed that they can clone sensors! :D
  19. Jun 7, 2013 at 9:26 PM
    #79
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Ok, from what I understand, the truck ECU stores 5 codes or numbers only for one set of tires....
    The truck only checks every 20 or so min, so it does not help you at all to have them, if you hit a nail the tire will be flat before the ECU tells you something.....
    That good are they, Not much....
    SO if you run into problems, batteries or anything, maybe change to a different set of tires you are forced to reprogram them or spend money....
    So my thinking is, can you program the truck for One TPS only?
    Doing so would let you use a smaller pipe for one, also if you need to replace them due to age, you could buy one only and program it.. Less cost, less time and less to worry about. Only one TPS not 5.
    When they die (batteries) only forced to get one, less time and money across the board.
    Any thought on programing the truck to one and using one inside a pipe?
  20. Jun 7, 2013 at 9:27 PM
    #80
    Mr.Gadget
    NC
    Or does anyone make a program, chip, or programer that you can turn the light off, fool the system or just cut it out as an option.
